Question about Arris SURFboard SB4100 Modem
How can i change my modem SB4100 MTU settings for i can be able tp play xbox live
4 Suggested Answers
myob247
  • 1342 Answers
SOURCE: Changing the MTU setting
Log into modem using 192.168.2.1 in your browser and go to modem utility through browser.
Posted on May 18, 2008
  • 115 Answers
SOURCE: My Motorola SB5101E Cable Modem does not have
Can't do it from the Modem. You have to change it in your router orWindow. Download the TCP Optimizer, run it and change your MTU. Linkhere http://www.speedguide.net/downloads.php
Posted on Nov 01, 2009
DINSPIRED1
  • 15 Answers
SOURCE: Setting up xbox live
ARRIS modem is a phone/hsi modem. What youll need to do is first turn power off on xbox then unplug the power supply from the back of the Arris modem and unscrew the coaxil/cable wire from the back of the modem for about a minute. Then plug in the power cord to the modem wait another half minute then screw in the coaxil/cable wire....wait for the lights to come back on make sure the online light is solid green not flashing and follow the ethernet cable (Looks like a thick telephone wire) and make sure you have that ethernet cable seated/snapped into the ethernet port on your xbox. Then turn the xbox on and do connection test. FINISHED..IF it's still not working make sure you have Internet service from your provider and if using a router bypass it at first see if you can get onto xbox live without the router. If you can with just connected directly to your arris modem without the router involved. If you do want to use wireless contact your router manufacture and or xbox support at 800-469-9269.
Posted on Apr 25, 2010
Change MTU settings on an RCA DCW 725
  • There are no user configurable options to cable modems, everything is based off the configuration file that your ISP pushes to the modem during registration.
  • Try connecting your XBOX directly
Apr 07, 2010 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
I'm trying too get connected to xbox live but it's
This mainly depends on your internet modem, I use linksys when I play xbox live. Also I use wireless adapter, sometimes an ethernet cable as well to plug straight from my xbox to my modem. Make sure your modem is connected to the internet, and that if your xbox has a signal, or properly connected to it.
Hope this helps a little. Good Luck!
Jan 02, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Trying to set up xbox live.
you need to make an xbox live profile not mtu for offline. You have to make a new profile.
Jun 23, 2009 | Microsoft Xbox 360 Console
Mtu settings
Two things needs to be cleared:
1) Which connection did you talking about LAN/WAN?
2) Xbox live may not be up yet, can you verify it?
Most home gateway routers can only change WAM MTU for certain connection type (PPPOE), and cannot set MTU for LAN and other WAN connection.
To change MTU for PPPOE, going to WAN connection setting, and you will see the MTU options box. But do not change it unless your ISP told you to do so.
So make sure Xbox live is online -- I am no Xbox fun so I have no idea how it works, but just guess from your message.
Jun 19, 2009 | Belkin (F5D7633UK4A) Wireless Router
My x box says change mtu to auto or 1364 how do i do this
My MTU is at 1500 and I get the same message. I don't think it's up yet.
Jun 17, 2009 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Mtu setting
In some cases, MTU is not necessary to adjust. Its always automatic and defaulted to 1500. The router model that you have doesn't have MTU settings. You can download the User's Manual HERE. You must do port forwarding and open the xbox live port so you can play xbox live. If it keeps on telling you about MTU, you must set static IP address on your xbox's settings and power cycle your devices.
Jun 02, 2009 | Zhone (6218-I2-200) Router
Have the n+ wireless router/modem trying to connect via a cable to xbox live but keep gettin insufficient MTU even though the actual MTU of the router is higher than required
You may have to use trial and error to find the best MTU fit:
MTU Default of 1500 to 1492
Tart the setting the MTU @ 1400
MTU setting. Xbox LIVE requires a minimum MTU setting of 1364.
The information your console sends and receives is broken up into "packets" for transmission over your network. MTU is a setting that controls the size of these packets. If it's too small, you won't be able to connect to Xbox LIVE.
Top Solutions Try these solutions in order. If you give each one a shot and you still can't connect, contact Xbox Customer Support. Note that they will ask you try the suggestions on this page first.
Solution 1: Check your router MTU settings Xbox LIVE requires a minimum MTU setting of 1364. Usually, you can change your MTU setting from your router configuration web page, which is supplied by your router manufacturer.
Learn how to find and use your router configuration page
Look for the MTU setting on the router configuration page. When you find it, set it to Auto or 1364 (or higher), save your settings, and then try to connect to Xbox LIVE again on your console.
Solution 2: Connect directly to the modem If your router's MTU is set correctly, try bypassing it by connecting your console directly to the modem. This will help determine whether there's a problem with your router or something else on your network.
Note
This may require you to move your console to a location close to your modem. This is a temporary arrangement, meant only to troubleshoot your connection. If your console is connected wirelessly, you'll need an Ethernet cable for this step.
To connect your console directly to your modem (wired connection):
  1. Find the Ethernet cable that runs between your console and the router.
  2. Unplug the cable from the router, leaving it connected to the console.
  3. Find the Ethernet cable that runs between the router and the modem.
  4. Unplug the cable from the modem, and plug the cable from your console in its place.
To connect your console directly to your modem (wireless connection):
  1. Unplug the USB connector for your adapter from the console. The adapter can remain attached to the console.
  2. Plug an Ethernet cable into the Ethernet port on the back of the console.
  3. Find the Ethernet cable that runs between your router and the modem.
Try to connect to Xbox LIVE again. If it works, there may be an issue with your router. Double-check the MTU setting in solution 1 above. Also confirm that you're using a compatible router, and make sure it has the latest updates from the manufacturer. If the problem persists, you may want to try a different router.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 06, 2009 | Belkin N1 Vision Router
Xbox live is not working it keeps coming up with 'you need an active connection to play online or system link matches' but my connection is fi and none of my friends can play as well?
Suggestion: <b>MTU Error</b>
This issue occurs if your router or the gateway is incompatible with Xbox Live, or if your router or the gateway has an incorrect MTU setting. Note: Xbox Live requires a minimum MTU setting of 1364. We recommend that you try out the steps shown below.
Things to try:
1. Ensure that you have properly setup your connection to Live by using the Connectivity Wizard http://www.xbox.com/en-US/support/connecttolive/xbox360/connectionmethods/webconnectivitywizard.htm
2. Visit the following Web site to determine whether you have the correct firmware version that has been certified as compatible: http://www.xbox.com/en-US/live/connect/routerlanding.htm
3. See the router or gateway instruction manual for information about how to change the MTU setting to 1364, to do this, or to determine whether your router supports this feature, see the router support documentation or contact support for your router device.
4. If you share a connection with a router and a modem, try a direct connection without the router.
For additional information on this topic refer to the following KB article: http://support.microsoft.com/kb/908882/
Sep 30, 2008 | Video Game Consoles & Games
Mtu failing
ther is no probs with ur xbox it will com on today
Sep 30, 2008 | Microsoft Xbox 360 Console
May 18, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Arris SURFboard SB4100 Modem Logo
388 people viewed this question
Top Arris Computers & Internet Experts
bobkoure
Level 1 Expert
Jerry
Jerry
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
