Question about Hotpoint WMA33 Front Load Washer
I need to replace the 2.5m grey overflow pipe on my Hotpoint WMA33P
    Sergeant:
  • 215 Answers
Any good diy store should have this. access is through bottom rear panel
Posted on Feb 10, 2010
My hotpoint wmd962 smells of stagnant water and the clothes come out smelling worse than when they went in?
By the sound of this, the waste pipe is probably connected under your sink. If this is the case then water flows back from the waste pipe and u bend. Just check and ensure your grey waste pipe is raised above the level of the u bend this should stop the problem. Also use a little soda crystals to clean pipes. Hopefully this will resolve your problem.
Aug 13, 2011 | Washing Machines
Please help the washer fills up and turns the
Seems like a blockage or maybe pump worn out. Fill machine and take grey outlet pipe on rear of machine. Place this pipe as low as possible into a bowl. If water flows free from this pipe then your pipes are not blocked and most likely you will need to change your pump. Before you try this just put machine onto spin and ensure this will work when machine is almost empty
Mar 12, 2010 | Hotpoint Aquarius WF220 Front Load Washer
HOTPOINT WASHER OVERFLOWS ON ALL CYCLES
This is most likely a damaged pipe going to the low pressure sensor. This sensor determines when to turn water off by the pressure built up in a tube. If there is a damaged pipe - it wil overflow.
Turn off and disconnect machine, then remove access pannel to inspect all small bore pipes for damage. Check pressure valve for correct operation.
If it leaks at times other than filling, and water level seems ok, then it could be a damaged top or bottom seal that needs identifying and replacing.
If it leaks constantly it could equally be a damaged rubber pipe between drum and pump.
You really need to remove an access pannel - and just observe operation without putting your fingers in thereto spot it.
Sep 08, 2009 | Hotpoint VBXR1090D Top Load Washer
Hotpoint - Drainig Issue
if you have a garberater you need to remove the drain pipe and clean out
Feb 19, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Washing machine not working
This normally indicates one of two problems.
1), the overflow pipe that goes into the sump is blocked and needs unblocking. (make sure that you have a bucket and towels at hand)
2) the carbon brushes in the motor have worn down. If the motor is on top of the machine which I believe it is on this model they are fairly cheap and easy to replace. Most washine machine repair shops sell these as spare parts.
I hope this helps
Feb 11, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
I have an FFA70 fridge feezer thw fridge does not drain propery
turn fridge around at bottom you will c a round black cooling pot the fridge overflow pipe leads to here so water can drip on it and evaporate with the heat from it take off pipe give it a blow to remove foreign objects it should sort problem
Feb 03, 2009 | Hotpoint FFA70 Bottom Freezer Refrigerator
Hotpoint WD440 Drawer overflowing
Hi.
I would check the inlet hose from the bottom of the soap dispenser where it goes into the drum for a soap blockage.
undesolved powder can build up here and prevent the water entering the drum
You can access this hose by removing top cover.
the hose is on the left side front.
This should solve your problem.
Please leave feed back.
Thanks.
Nov 25, 2008 | Hotpoint Aquarius WD640 Front Load...
Where is the filter on a WMA32
the rear of the machine has a metal plate with 4 screws the overflow pipe goes in there take this off get some one to tilt the machine forward the overflow pipe goes to the pump then another pipe goes the the filter large clip removes the filter inside is a cradle and a ball anti return for water clean it all and job done .hope this helps all regards george
Aug 22, 2008 | Hotpoint WMA32 Front Load Washer
Hotpoint dryer
two pipes on the back (white + grey about 8mm dia) dissconect and blow down them both. May be blocked.
Jan 24, 2008 | Dryers
Hotpoint WMA33 Front Load Washer Logo
48 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
