Question about Kenmore 72073 Top Freezer Refrigerator
Fridge side not cooling
I found my freezer coil frozen (icing up) this is the second time in less than a month. The last time it happend all I did was defrost it with a hair dryer.
  • Kenmore Master
  • 2,651 Answers
You have a defrost issue, posslble heater, defrost thermo, or a defrosttimer, something not working correctly as of now you have a manual defrost refrig
Posted on Mar 01, 2008
I have a national NR-302TE-X fridge for the past 4 months the fan in the freezer gets frozen and stops due to this the fridge does not cool and a lot of water is defrosed and there is water inside the...
there is a temp, sensor in side the fridge that turn on a heater rod and stops compressor that melts the ice at back of freezer and fan.
or toy can open rear panel in side freezer and pure hot water (not boiling ) on frozen ice on condenser coils, this will help you for on week and then you have to repeat it again
you need a good tech person to solve that problem
hope toy under stand
?Adnan :
Nov 13, 2010 | Refrigerators
Fridge coil is frozen but the fridge is not cold. Freezer coil is not frozen but freezer is cold. Icemaker doesn't produce ice and the water in the ice maker is not cold. What do you think?
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
Jun 12, 2010 | Samsung RS267LBBP 26.1 Cu. Ft. Side by...
Repeated ice over the coil
The defrost cycle is either failing to start (problem with defrost timer) or is not heating the defrost coil (most often defective defrost thermostat.)
When you defrosted did you remove the panel at the back of the freezer to defrost the drain hole for the defrosted water to drain out?
Sep 08, 2009 | Jenn-Air JCD2389G Side by Side...
Buyers Beware!
go to sears
Aug 14, 2009 | Refrigerators
GE side by side. Freezer cold, fridge kinda cool
Generaly the control board controls everything sometimes you have a bad thermister GE has a help line I beleive it costs 20.00 bucks but you will need a meter and know how to use it and they willl talk you thru the repair .
May 30, 2009 | Refrigerators
Maytag Widey Side not cooling enough
Check to see if you have frost on the back panel of your freezer in your fridge. If you do your coil is frozen over and you'll have to defrost your freezer. I just did mine cause mine wasn't cooling properly on my fridge side. If it is that it's going to fill the pan under your fridge and overflow.
Apr 19, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Maytag wide by side not cooling. just prior to this frost build up on top of freezer. Compressor not running.
Check to see if you have frost on the back panel of your freezer in your fridge. If you do your coil is frozen over and you'll have to defrost your freezer. I just did mine cause mine wasn't cooling properly on my fridge side. My coil was solid ice.
Apr 05, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
GE Frigerator has intermittant Freezing
It sounds like the defrost heater is burned out. Remove the inside back cover in the freezer to see if the coils are frozen up. If so, more than likely your defrost heater has bit the dust. It is located at the bottom of the inside coil of the freezer.
Also, you could be have a clogged condensor coil. It is located on the out side back of the Fridge. You need to remove the panel from the lower part of the fridge and do a thorugh cleaning.
Nov 01, 2007 | Refrigerators
Kenmore 72073 Top Freezer Refrigerator Logo
94 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
