Question about KitchenAid Dishwashers
Model no. KUDD01DPPA SERIAL NO. 52882478573754 THE PROBLEM IS THAT THE "FLOOD SWITCH HAS BEEN ACTIVATED"
  • 2 more comments
  • emaho2 Jan 31, 2010
    there is no manual reset button and the power supple was turned off for 10 minutes and Still the same problem showed up.
    What else can i do to reset the machine?
    The breaker was turned off for 10 minutes and the same problem came back. the rinse light come on indicating that the flood switch is activated.
    What to do?
    The trouble came due to some mistake ... instead of powder soap...
    i put some dishwashing liquid... which bubble too much !...
    so the flood switch has been activated !....
    thanks for the answer
    Have no Replay from Mister Shastalaker7
    since two hours !...
    Our two dishwasher Have the same Failure !...
    the Flood switch has been activated...
    How to reset the machines ? ...
    We removed for 10 min. the electric power !...
    without success !...
    The error code is the same "Rinse light on"
    The trouble started with dishwashing liquid instead of powder
    too many bubbles and the machine stopped !...
    Thanks for your replay...
    President:
  • 547 Answers
The problem now is that the flood sensor is still wet, so it's still activating even after your 10-minute reset.
Remove the lower front panel (below the door) and wipe out under the machine with paper towels. You may have to set up a small fan to blow air under the dishwasher to dry out the area.
Once it's totally dry, THEN repeat your 10-minute-circuit-breaker-reset procedure and you should be all set.
Word of caution -- there are sharp metal parts underneath the washer. Be careful as you're drying that you don't cut your hand.
Posted on Jan 31, 2010
    President:
  • 1,515 Answers
Hi, If there is not a manual switch to reset this flood switch, I would go to the circuit breaker and shut off the power to the unit for 5 minutes. Reset the breaker and see if this has solved you're problem. You can also unplug it if it is easy to get at. Please let me know if this does solve the problem. If not, we will go further into solving you're problem.
Sincerely,
Shastalaker7
  • Robert Horton
    Robert Horton Jan 31, 2010
    Mister Shastalaker7 has been busy at work as I am on call doing H.V.A.C. repairs for hundreds of other folks 24/7. Looks like you have this problem locked out to another expert!
    Shastalaker7
  • Robert Horton
    Hi, It could be the liquid dish soap instead of the powder that caused this problem in the 1st place.
    Best of Luck,
    Shastalaker7
SHE44 pump keeps trying to empty but there isn't any water
she44-pump-keeps-trying-empty-but-isnt-3dor230cw2fd2t5j4bvk0sa4-4-1.jpg Hello. First, when looking up info on your model, I came across this recall on the SHE44C unit. Check your model number and serial number to verify if your unit falls into the recall range. (fire hazard)
Next, study the schematic diagram for your unit--the drain pump is connected directly to the main board--the fact that it's running even with the door open suggests that the main board might have a stuck relay and will have to be replaced if that is the case. The part number is 444813. The drain motor (see close-up, pic 4, is designated M3) has one side wired to the board, the other side goes through the on/off switch to incoming power, (see pic 3, lower right corner). I hope this helps you!
Sep 26, 2015 | Bosch Dishwashers
Flood switch activated on dishwasher DW60CSWI
Please clarify the model number. i am assuming you have a standard height single door dishwasher. It is likely the flood switch assembly itself is faulty and giving false results. Check the base of the dishwasher - item 95 in on page 10 in this manual. The microswitch could be faulty or the spring might be stuck.
Jan 21, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
How to reset the flood switch on a fisher & paykel
Hi - unfortunately my good friend it cannot be reset as one would like quite easily anyhow... water has found its way to the base of the drwaers and have activated the flooding switch - one could pull it apart to dry it - tip the water out from the base but if the leaks not repaired you will have the same problem later and will be on-going.
5 Fault Codes
Fault Code LED Display Fault Possible Causes
F1 ----#
The flood switch has been activated.
A leak has occurred in the base of the dishwasher.
Cause
 The fill valve has failed open.
 The flood switch is faulty.
 Excessive water has been added to a wash sub cycle, indicating leaking seal or siphoning.
hope this is useful tp you - let me know if you require further asspstance...
Jul 16, 2011 | Fisher and Paykel DS602 Dishwasher
Flood switch activated, intermittent beeping, motor will not turn off
Please confirm if it is a single or a double drawer.
How do you know the flood switch is activated? Do you have a display on your dishwasher and what is it showing? If no display then which lights if any on the panel are on?
Motor will not run if flood switch is activated in the fisher paykel drawer dishwwasher.
Nov 20, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
Bosche dishwasher serial no, SGS 456 . The machine won't admit water, but it makes all the washing sounds
Are you please able to provide the actual model no. of the bosch dishwasher. The serial no. is not much help.
The reason it may not be admitting water is because the flood switch may be triggered. This means it will not take any more water and the sound you hear is the pump running to empty the dishwasher. YOu will have to find why the flood switch is turning on. Are you using the AquaSafe circuit in the dishwasher inlet circuit? If water is leaking then this circuit will trigger and stop water from coming through inlet. But then you should also get some alarms on the display.
Please provide the model no.
Sep 30, 2010 | Bosch Dishwashers
My d1716 continues to run, but does not move forward in the cycle. I can even open the door and it continues running. If I didn't unplug it, the motor would likely burn out. Do I need a new dial? Thanks.
Hi
I would suggest that your flood switch has been activated. There is a float on the bottom plate or base plate of the machine. If there is a water leak, the float rises and triggers the flood switch.
Once the switch has been activated, the machine will go on a continous pump.
Disconnect the power and the hoses from the machine. Pull the machine out and lay it on its back.
If there has been a leak, you will notice water pouring out the back.
See if you can open the bottom plate, and reset the floater and flood switch. Sometimes you can access this by openning the front kick plate or front bottom plate.
Try the machine again. Leave the front bottom plate out and look into the bottom as the machine is working. If you have a water leak, this will happen again and you may be able to notice where the leak is from.
Be carful not to touch the live wiring while you are monitoring the machine.
Good luck
Ash
Nov 20, 2009 | Asko D1716 Built-in Dishwasher
FI error message from both drawers. We had a
F1 indicates flood fault. There is no reset, machine thinks it has flooded. If machine was running OK until electrical storm, then it could have shorted the mains filter control board (DD603 models-this mains filter board also acts as flood switch), although this is unlikely to have shorted. More common is dishwasher has had a leak causing F1 fault, or corrosion on mains filter board . Open bottom drawer and shine torch underneath to see if there is any water in the base of the cabinet- if yes, machine has leaked and activated flood switch. If not, flood switch board may be faulty.
Unfortunately, access to this flood switch control is permitted only by removal of the bottom drawer- recommend calling technician unless very keen!! If keen, read on!!
-To remove drawer- there is a tag at the bottom front on each side of drawer when you open it -just below the round plastic plug. You need to push this tag in and slide backwards on each side, then drawer will lift out-Careful as hoses and wiring still attached, but long enough to allow access. Mains filter control board is located under plastic cover at left rear- press tag on plastic cover and slide to the right- you will now see small electronic board. This is the mains filter board that doubles as the flood switch. It is held in place by 1 screw- you need to remove wires from board before removing it). Check circuit board for corrosion or evidence of short circuit- if so, replace circuit board.
Good luck, but advise seeking professional help unless you very confident!!
Aug 10, 2009 | Fisher and Paykel Dishwashers
The flood switch has been activated on my dishwasher
Remove the bottom drawer by pressing in the tabs on either side of the drawer (bottom edge towards the front).
Dry out the compartment with towels and let air dry.
Apr 11, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher-Paykel DD603 DishDrawer shows F1 fault code. The Flood Switch has been activated. I need instructions on how to re-set the flood switch. I have two drawers that are possitioned one above the...
Fisher-Paykel DD603 DishDrawer shows F1 fault code. The Flood Switch has been activated. I need instructions on how to re-set the flood switch. I have two drawers that are possitioned one above the other and the are both giving the error of the activated flood switch. Any advice or instruction is greatly appreciated.
Jul 22, 2008 | Dishwashers
Dishwashers Logo
55 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
