Question about Epson Stylus CX4600 All-In-One InkJet Printer
EPSON CX4600 clogged
How do you remove and clean the printer head on the EPSON CX4600?
    Problem Solver:
  • 5 Answers
I have only just joined the forum but thought the attached may help.
I don't know the CX4600 so I'm only offering an idea.
www.hardwaresecrets.com/article/178/1.
Hope it helps
Posted on Mar 30, 2008
I have an Epson Workforce 600 printer that won't print black ink. I have replace all the cartriges with new and still no black ink. I've done nozzle clean several times. Only a very faint line on test...
You may have to clean your HEADS. I found this on the Web. Hopefully this will help. Pls rate me.
Good Luck
Found this on the Web:
http://www.fixyourownprinter.com/forums/inkjet/14116
Epson Stylus Head Cleaning Solution Plus
Re: Epson printer problem
You will want to press the button that you use to change the ink cartridge (the 3rd button). Once the carriage is in the "cartridge change position" you can unplug the printer. Then you are ready to flush out the heads. Click here for cleaning instructions http://www.wesesweb.web1000.com/printhead.html
The instructions are fairly easy to follow. If you need the head cleaning solution click here .http://www.fixyourownprinter.com/kea0.html
Repairs: All Epson Stylus printers (except for the C64-C86, CX4600-CX6400 series) which don't print, or print choppy in black or color. For the other printers, as well as Canon BJCs, use the other repair kit.
Description:
  • This is the same chemical used by Epson in their service department
  • Easy to use, no disassembly required
  • Gently dissolves even the most stubborn clogs and restores output to dried out print nozzles and clogged printheads
  • In our testing on an Epson 600 that sat unused for several months, it 100% restored a head that had no output, with one application (Individual results may vary)
Note: This is not alcohol or Windex; it is an ink-specific solvent that has proven to be safe and effective for use on Epson printheads. Do not use alcohol or Windex, they will very likely ruin your printer.
Kit Includes:
  • 1 oz bottle Epson Stylus Head Cleaning Solution (enough to fix several printers)
  • 1 syringe applicator for dispensing solution
  • Simple directions for use
Price: $9.99 order form on link below
http://www.fixyourownprinter.com/kits/Epson/K89
Feb 25, 2010 | Epson WorkForce 600 All-In-One InkJet...
I just installed a new black ink but it doesn't print black, only printed colors. I thought the ink was a defect so I changed another new ink but it is still not printing. Now, the color stopped working as...
your print heads might be clogged. clean it the hardware way. not the software way. to do this, simply buy a print head cleaning solution for Epson Printers. now pull out all your print cartridges and put a small drop of cleaning solution to the pin-like plastics in the base where your heads are seated. drop and drop cleaning solution to dilute clogs. you can use syringe to sip out the solution from the area. after this hardware cleaning, do a software cleaning through performing a cleaning print heads in the epson tools under maintenance tab
Oct 15, 2009 | Epson Stylus CX4600 All-In-One InkJet...
Epson CX4600 printer - will not print color at all
no it should work at it is. if you installed the plug and play printer driver. have you removed the protection tape from the inc tubes?
Oct 12, 2009 | Epson Stylus CX4600 All-In-One InkJet...
Epson Tylus CX4600 ink light
If any ink cartridge is empty, you won't be able to print until you replace the empty cartridge. Leave any empty cartridge installed in the device until you have obtained a replacement.
The print heads will clog up in a week or two. So you also won't be able to print until you clean the print heads.
This is a utility to manage your ink. Gives an accurate count of how many ink shots are left in each cartridge. The printer told me I need a new magenta but this program says I have 13% left. It also has separate routines for cleaning the black and color (unfortunately not individual cartridges)
http://www.ssclg.com/epsone.shtml
May 18, 2009 | Epson Stylus CX4600 All-In-One InkJet...
Epson cx4600 tubes are clogged
hi there
first you can try cleaning the heads of the cartridge with the software which has come along with epson this will solve your problem if dont then please change the cartridges or call epson service center they provide u onsite warranty
Nov 08, 2008 | Epson Stylus CX4600 All-In-One InkJet...
Epson stylus cx4600 all in one
remove the printer inks & use soft issue paper to clean the printing head. how long have u be using this ink on the printer?. check for the ink level if its too low, the output will be very faint.
thanks. let us know if we should add more tips.
Oct 05, 2008 | Epson Stylus CX4600 All-In-One InkJet...
Paper comes out blank
epson cx4600 prints blank paper replaced ink cartages .same problem
Dec 02, 2007 | Epson Stylus CX4600 All-In-One InkJet...
Cx4600 epson
Jets are clogged Needs deep clean. 1st try -www,ssclg.com The Epson utility. Run the program- select your model- right click on the icon on the bottom task bar. 2nd Take a look at www.fixyourownprinter.com. 3rd make your own cleaning tool as here
May 18, 2007 | Epson Stylus CX4600 All-In-One InkJet...
Epson Stylus CX4600 all in one printer, scanner
Under Maintainance in the properties of the printer it gives you the option to clean the print heads. Should work
Feb 19, 2007 | Epson Stylus CX4600 All-In-One InkJet...
Printer won't print color
when you change the ink cartridges you are NOT changing the print head. The print head is in the carrier. If the print head has become clogged or worn then usually it needs to be replaced. Unfortunately it us probably cheaper to buy a new printer.
May 05, 2006 | Epson Stylus CX4600 All-In-One InkJet...
Epson Stylus CX4600 All-In-One InkJet Printer Logo
169 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
