Question about RTO Garden Sun Stainless Steel & Green Outdoor Table Top Patio Heater 44,000 BT
New T35PHLPTable Top Heater. Used twice. Now
New T35PHLPTable Top Heater. Used twice. Now when I insert the propane tank and turn to pilot no propane at the top. Same for full open. Reseated tank,chamged tank, same problem.
  • 2 more comments
  • dphillipd Feb 01, 2010
    No problem with stoppages. Worked fine several times yesterday but no propane today. Nothing. New propane bottle (tried two new ones). Actually took the top off the burner and tried direct fllame. No luck.Is there some kind of trip over switch? There is a small part by the regulator that has two connections coming out. Could that be the problem?
    Could you e-mail answer to dphillipd@msn.com?
    Thanks
    Feb 01, 2010 - No problem with stoppages. Worked fine several times yesterday but no propane today. Nothing. New propane bottle (tried two new ones). Actually took the top off the burner and tried direct fllame. No luck.Is there some kind of trip over switch? There is a small part by the regulator that has two connections coming out. Could that be the problem?
    Thanks
    Thanks
  • dphillipd Feb 02, 2010
    no propane tto the pilot
  • dphillipd Feb 04, 2010
    Disconnected regulator from heater. Connected gas bottle to regulator gas flow. No gas to top of heater.
    President:
  • 2,976 Answers
The nib that goes into the gas bottle has a built in filter.  Quite often, it looks like tiny brass beads.  Moisture gets into the filter and causes corrosion.  The heater can work one day and not the next, depending on how much moisture got in.  The weather conditions alone, or the condensation from changing bottles is enough to swell the corrosion to the point of totally stopping the gas flow.  Try soaking it in a tarnish remover like Tarn-X.  It might or might not work.  Another liquid to try would be pure white vinegar.  It will need to be blown out with high pressure air and thoroughly dried INSIDE, before reinstalling it.
Posted on Feb 06, 2010
    Brigadier General:
  • 4,090 Answers
Not sure where you are in the world. But where i am we have to use regulators on all propane units. If you have one fitted remove it and do a direct connect. This should eliminate a faulty regulator if propane is getting through now.
Also at the pilot jet, check that it is not blocked by carbon. use a "pricker" to clean the jet.
Thanks for using FIXYA
Posted on Feb 03, 2010
  • 2,176 Answers
This is a multiple part answer, is this the first time this year you have tried to use it? And when it was stored did you store it with the tank on it? If Not what might have happened is that there is dirt or possibly some insect has tried to make a nest in the nozzle of the heater, I would try and clean after inspecting it for contamination. I would use a cleaner that dries and if you have compressed air all the better to blow out afterwards. This would be the cheapest way to first try and fix if not then the control assembly would possibly have to be replaced. Also you are sure that the tanks being used do have fuel in them and they are seated fully? When you turn to pilot are you making sure to push in the button to light? Let me know and I will try and help further.
Posted on Jan 31, 2010
  • David Ford
    David Ford Feb 02, 2010
    I am not allowed to respond directly, I am thinking that the regulator or the 2 items you mentioned are the problem, I have not been able to find a schematic or owners manual for this unit I am just going by what I learned in school for the possible solution.
Propane tank top heater wont stay lit
Try replacing the thermocouple , and clean pilot .
Dec 16, 2016 | Heating & Cooling
Big buddy Heater - 20 lb tanks won't keep pilot lit,
I had the same problem I called tech support and they said to turn the valve on the 20# cylinder on very slowly for the first 1/4 turn then all will be fine. There is an excessive flow check valve that causes restricted flow when the valve is opened quickly----------mine works fine now
Apr 09, 2013 | Mr. Heater Mr Heater Portable Buddy...
Kozy world propane wall heater pilot will not light
This can be caused by several things:
1. The inline gas valve running to the the heater is OFF. Turn the valve ON.
2. The gas control knob on the heater is not exactly in the PILOT position. Unless the knob bottoms
out and you feel strong pressure (other than spring pressure) pushing back at you. It's not exactly
in the PILOT Position. Once the pilot lights, hold the control knob in for 30 seconds to 60 seconds
to allow the Thermocouple to full heat.
3. The pilot is dirty and needs to be cleaned, as do the burners.*
4. The LP Gas Tank is empty or to low to maintain te proper gas pressure.
* Here is a link to a demonstration on how to properly clean the pilot & burners.
http://www.desatech.com/techDocs/Cleaning%20Demonstrations.pdf
I hope this helps you to troubleshoot & solve the problem. Thanks for choosing FixYa.
Sep 23, 2011 | The Companion Group Kozy World Portable...
Lights while holding primer/pilot button then runs out of propane within seconds. If you wait a minute it builds up then does the same thing like the propane tank is empty but it is full.
Turn off the propane tank and disconnect the heater hose from the tank. Wait 5 minutes and reconnect the heater hose/regulator to the propane t. Turn the tank valve on very, very slowly until it's completely open again. Now, try lighting the heater. If you are using a 20lb LP grill type tank, that should solve your problem.
Hope that helped.
Feb 12, 2011 | Reddy Heater-30-55,000 BTU Variable
Coleman heater model 5445c700 propane camp heater wont light. It did work fine. When I hold the knob in the light position you can hear gas but it barely ignites then goes out. I've tried new gas and...
If you're using a 20lb propane tank (Gas Grill Tank), that may be the problem. Turn off the propane tank at the tank valve and disconnect it from the tank. Wait 5 minutes and reattach the heater hose to the tank. Turn the propane tank valve on very,very slowly until it's all the way open. Try lighting your heater now. If the pilot flame height returned to normal, that was the problem.
FYI - The Thermocouple has nothing to do with the length of the pilot flame. It's a safety feature that stops the gas if the pilot flame goes out for any reason.
Hope that solves your problem. Please let me know.
Rich
Feb 07, 2011 | Coleman Heating & Cooling
When commected to 20 lbs tank the pilot light does not stay on; however, when connected to a 1 lb propane bottle everything works propertly. I have replaced the fuel filter, I have tried using different...
The new 20lb LPG cylinders now have what called an OPD Valve. Reconnect to a 20lb cylinder and turn the tank valve on very very slowly, This will help prevent the OPD Valve from locking up the heater's regulator. Your 1lb cylinder is not required to have this OPD Valve.
By the way, this happens quite frequently with LP Gas Portable Grills.
Jan 25, 2011 | Mr. Heater Mr Heater Portable Buddy...
This is a new unit - used 4 times. The gas will no longer flow and light the unit. Sometimes I can get the pilot to light but when I turn the valve to light the heater the pilot goes out and nothing. The...
Sounds like the thermocouple is not working or you are not keeping the start or pilot button depressed long enough before turning gas valve to on position. Check to see if thermocouple end hasn't come loose, the pilot should be hitting it. This produces the small electrical current necessary to open gas valve. Hope this helps.
Oct 02, 2010 | Stainless Garden Sun Steel Propane Patio...
Propane heater wont work
I'm not sure about that model, but I think you have to hold that button down for a minute or more to "prime" it.
I have a different model coleman propane heater that sits on the 20# tank. Mine is probably getting rusty, last time I used it I had to hold that button down for a long time.
I'm looking for a new heater now myself, as mine won't stay lit outdoors in much wind.
Dec 22, 2008 | Heating & Cooling
Endless Summer Patio Heaters won't stay lit
Hi ColdinSF,
You need to remove the covers from the unit and blow out the gas lines with compressed air. If you can remove the gas lines blow out the lines and what they connect to like the pilot light and main feed line to the burner. Usually they gunk up with use and just need to be blown out with compressed air to clear the lines again. Maybe you have some dirt or foreign object from your gas tank which has clogged the line. Also check the igniter electric lines as well and make sure everything is connected properly. Especially make sure you tighten the gas lines you remove. Hope this helps.
Regards
Bryan
Oct 19, 2007 | Endless Summer gwt501a Open Flame Patio...
RTO Garden Sun Stainless Steel & Green Outdoor Table Top Patio Heater 44,000 BT Logo
56 people viewed this question
Top RTO Pool & Spa Experts
john h
old fart58
Craig Butler
Craig Butler
Are you a RTO Pool and Spa Expert? Answer questions, earn points and help others
