Question about HP Officejet Pro L7680 All-In-One Printer
My feed tray on top of the printer will not pull papers into it. It whirs and makes noises, but usually won't pull paper in. It trys for a while and then tells me to reload. If I mess around with it a little an pop the cover up and down it will eventually work, but most times won't do so consistently. I suspect the little roller is not coming down to contact the paper, but am not sure. Help?
    President:
  • 2,306 Answers
Many times the rollers are just glazed and you can clean the feed rollers with a little alcohol on a towel, other times the swing gear assembly in the back is not engaging the drive gears. You should also look down the throat where the paper goes and make sure a paper clip isn't lodged in there stopping the paper. You can see the roller assembly when it runs to see if it comes down, there's also a flap inside that has to pull up to allow the paper to advance. I would try cleaning the feed roller first.
Posted on Jan 31, 2010
Printer wil not feed paper in -keeps trying but paper will not move in.
Hi Jamieos,
Turn the printer off and on.Solved?
Turn the printer off and disconnect from PC.Unplug from power.Reboot the PC.
Remove the papers from the feed tray and look through the paper path for any obstructions.
Load the print papers and make sure they are correctly aligned on the feed tray.
Cear any print queues on your PC.
Connect everything now and start the PC.
Try printing.
Hope this helps.Thanks!
Please rate this answer.
Dec 14, 2011 | Epson Stylus 1400 InkJet Photo Printer
Printer makes a high pitched whirring sound, paper will not feed and orange light stays on
clear paper feed roller whit wet cloth or alcohol,
1. remove paper tray
2. look for paper feed roller just in bottom of printer.
3. clear it as i said early
4. Enjoy
Good luck!!!
Jan 17, 2011 | HP LaserJet 2200dn Printer
Will not feed paper. Can print with manual feed in center of printer, but will not pick up paper in tray. It tries three times and can hear the motors whirring, but then stops trying and the attention...
When you look into the tray with the flashlight, you say the top rollers are spinning, are they touching the paper?
Pull open the tray and while you look from the back with the light, close the tray and see if the paper is being lifted to meet that top roller. Take out all the paper and watch it again. Make sure that the platform that the paper sits on in the tray is free to move up. Sounds like it is jammed.
Also check that roller that isn't spinning. Try to GENTLY rotate it with your fingers. If it does rotate, replace the tray. If the paper in the tray doesn't lift, replace the tray.
Oct 30, 2010 | HP LaserJet 1320 Printer
The printer ask for paper and then OK, but then
a friend helped out. A little piece of paper got stuck somewhere. Thanks for your assistance
Dec 16, 2009 | Canon PIXMA MP530 All-In-One InkJet...
When asking to print keeps saying load MP feeder cardstock A4 although computer set up to print from tray 1?
depends on the printer, normal home use printer have only 1 tray.
office printer usually have multiple trys. and usually the default for that is tray 2. tray 1 is manual feed.
May 14, 2009 | Office Equipment & Supplies
Canon PC920 paper feed "clacking" & not working.
check the tray and make sure the guides are set correctly, clacking sound is usually because the tray is set for Legal and has Letter, the paper is towards the bac of the tray and the pick up assembly is making the noise,
otherwise the tray is either not going up (broken gear, )
Aug 22, 2008 | Canon PC-920 Black and White Copier
HP PSC 1315 Problem
Glad to know that your problem is solved.
Thank you for using fixya..
Jun 23, 2008 | HP PSC 1315 All-In-One InkJet Printer
Will not feed paper
Sounds like the gears are out of alignment for the paper pick up tray.
May 28, 2008 | Brother HL-2070N Laser Printer
Paper won't feed
Pull out the paper tray and push the paper feed roller towards the machine. Try to turnaround the paper feed roller by hand. Reinsert the paper tray.
Nov 02, 2007 | Brother MFC 420CN All-In-One InkJet...
Paper not feeding
Is this a top feed - that is paper loaded on top at the back bottom feed from a tray underneath? Top feed take one sheet of paper and gently push it down whilst the printer is trying to grab it. Tray feed - take tray out make sure no paper fragments are in the tracks and find a nail board and gently abrade the pick up rollers.
May 13, 2007 | Brother MFC-620CN All-In-One InkJet...
HP Officejet Pro L7680 All-In-One Printer Logo
24 people viewed this question
Seeker5211
Seeker5211
