Question about Dell Inspiron 1501 Notebook
Hello, I'm getting a code of "2000-0142 Drive Self Test Failed Status byte=70" during a PSA test. Can you guide me to what may be the problem ? This is a Dell Lattitude D630. Also, what started the diags was my mouse pointer is not working and the mouse pad has an error. I've tried to delele/reinstall and even a usb mouse, still not working. Help Please
  • 3,940 Answers
2000-0142 is a hard disk drive failure.
You will need to replace the drive to resolve the problem
Posted on Jan 31, 2010
Error code 2000-0142
Drive Self Test failed. Status byte = XXh.
Start by following the directions on this site;
http://www.dell.com/support/troubleshooting/us/en/19/KCS/KcsArticles/ArticleView?c=us&l=en&s=dhs&docid=266787#HDD
If a scan for errors doesn't work then your HDD may have failed.
Oct 29, 2013 | Dell Studio XPS 1640 Notebook
Error code 0142 message error code 2000-0142
My computer did boot up to the desktop, but was completely unresponsive from there when trying to open anything. I ran a system diagnostics and got this error with the status byte of 70. I rebooted into Safe Mode and was then able to open files. I backed up my stuff to a flash drive and then ran Error-Checking in the HD Properties which runs the CHKDSK function the next time the computer is rebooted. That found 2 bad file clusters and repaired them. One was a file called Windows.edb, which does the hard drive search indexing for Windows and was most likely my problem with the lockups. The other was a Napinsp.dll file. After these were fixed and the computer was rebooted, everything worked normally.
This HD is only 9 months old, but if this happens again, I'll replace it again.
Apr 21, 2012 | Dell Inspiron 6400 Notebook
Dell 1558-2182 boots about 1-3 hours. It hangs on screen "Welcome" for 1-3 hours. Safe mode runs ok When I try to log on guest account laptop reboots When I run PSA (Pres-boot System...
before changing disk, you can try reformat and re install.
The disk may be okay and you are having windows problem especially
because safe mode works okay.
Aug 03, 2011 | Computers & Internet
Dell studio windows failed to start. error code 2000-0146
the Error code was sited below as the (Disk Self Test) DST Log contains previous error(s)
in case of your error DST log contains previous error(s) doing a
chkdsk /r or a repair reinstall of xp might resolve the issue.
to resolve issue...
Error Code Error Message 1000-0141
or
2000-0141 No Drive Detected 1000-0142
or
2000-0142 Drive Self Test Failed Status Byte=XXh 1000-0143
or
2000-0143 Drive Smart Read Command Failed 1000-0144
or
2000-0144 No Support for Drive Self Test Error Code Error Message 1000-0145
or
2000-0145 Timeout waiting for Drive Self Test to complete 1000-0146
or
2000-0146 DST Log contains previous error(s) 1000-0147
or
2000-0147 Unit (x): IDE status failed. Status byte = (x) Control Code = (x) Msg = (s) 1000-0148
or
2000-0148 IDE ERROR: status (x) (s)
Aug 07, 2010 | Dell Studio 17 Laptop
Hard drive crash
Try to use the dell system utilities(set bios to boot from CDROM,inset the disc) and this include system utilities that restores the system volume information of your hard drive.If the the drive will not work you can say bye bye to your beloved hard drive.
Sep 23, 2009 | Dell Latitude D430 Notebook
DST Short Status Test Failed
MY DELL NOTEBOOK IS SAYING DST CAN YOU HELP ME
Jun 26, 2009 | Dell Inspiron 9300 Notebook
D610 DST Short Status Test Fail
It appears your hard disk has died and it may not be possible for you to retrieve your data.
Remove your hard drive from the laptop and insert it into an USB harddrive adapter, (they are not expensive and you can use it later as a external hard drive). Then plug it into the USB port of a working computer. The computer should/may see it as an external drive, if you are lucky you will be able to copy your data, if not, you are out of luck.
There are companies that can recover data from faulty hard drives, but it will cost you an arm and a leg for their service.
Feb 17, 2009 | Dell Latitude D610 Notebook
PC wont boot to windows xp
This seems to Be a common problem with dells, The only way to fix it is to buy a new HD, And all data is Unrecoverable. Sorry for your loss
Jan 11, 2009 | Dell Inspiron 9300 Notebook
Dell Inspiron 1420 freeze at starting
This is an easy one.
You hard drive has DIED.
Call or chat with Dell tech support and get a replacement drive
http://support.dell.com/support/topics/global.aspx/support/chat/hardware_chat?c=us&l=en&s=gen
Since the system is less that a year old, you can request a replacement drive witht eh factory image on it too.
Jul 14, 2008 | Dell Inspiron 1150 Notebook
DST Short Status Test (Error detected)
DST stands for Drive Self Test, it means your drive is failing.
I would get a new hard drive and USB enclosure, install new drive in laptop and install windows, then take the old drive and install it in the USB enclosure so you can connect to your laptop when windows is running and restore your files, assuming the drive is not completely dead.
thanks for rating
Jan 10, 2008 | Dell Inspiron 6000 Notebook
Dell Inspiron 1501 Notebook Logo
378 people viewed this question
Alun Cox
