Question about Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool Duet washer started banging during the spin cycle and the plastic rim on the drum has broken. What do I need to do?
  • 15,935 Answers
It appears your vibration damper has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 30, 2010
Drum is loose during Spin and Rinse cycle and banging against side of washer
If it is under warranty, call Whirlpool at 1-866-698-2538. If it is out of warranty, try running the washer with no clothes in it in spin cycle. If it runs fine empty, it may be that when you had clothes in it they were not balanced evenly in the tub. If it runs off balance when empty, then a spring may have broken or come off. Contact an appliance repairman.
Oct 31, 2013 | Whirlpool WTW4880AW 3.4 cu. ft. Top Load...
Whirlpool duet banging on spin
with the door open,take your hands at 3 and 9 o'clock in the drum and try to move it back and forth,then try 12 and 6 o'clock try moving up and down if you can move it either way,the spider that holds the drum is broken behind the drum and needs replacing
Apr 27, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Washer Model WFW9400SZ00 bangs only during spin cycle.
Yes you are exactly right, these bearings have failed & are causing the noise very common problem with whirlpool front loaders. very expensive to repair worth while looking into replacing instead of repairing as it will just happen again.The new LG machines are the best in my opinion.
Feb 06, 2012 | Whirlpool duet Washing Machines
During the spin cycle it sounds like the drum is about to come out of the machine and there are little grey plastic pieces in the clothing.
Sound like the basket has broken away from the spinning support coming of the back of inner drum, Gray plastic is the front ring the inner tub is now rubbing on. This has been making noise for a while. Phil 1-800-559-1411 www.phils.com any help I can give you.
Aug 21, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet makes an awful banging noise when a load of laundry is in the spin cycle. It is completely level and I cannot figure it out.
reach inside drum that turns and try to move it up and down. If there is any movement the spider at the rear of the drum is broken. Will need inner drum and outer rear tub with bearing and seal.
Nov 04, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Duet GHW9150W0 Washer - Stainless Steel Washer Bin Arms Broken
I HAD THE SAME PROBLEM. I CALLED THE 800 NUMBER AND HAD WHIRLPOOL SEND ME ALL OF THE PARTS THAT WERE STILL UNDER THE EXTENDED WARRANTY THAT I PURCHASED. WHIRLPOOL SENT ME EVERY PART, INCLUDING THE STAINLESS TUB, THAT WAS STILL UNDER WARRANTY. I NOW HAVE REPLACED ALL INTERNAL PARTS EXCLUDING THE MOTOR.
Jun 07, 2009 | Whirlpool GHW9150 Duet Washer
Washer sounds like off balance during spin
old duets have nut on rear pulley that becomes loose. remove rear panel and tighten nut. check while spinning by hand if pop is felt. if it rotates smoothly then you may need new shocks on tub
Mar 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sport Washer Banging During Spin Cycle
If the the drum feels loose in any way, there are three possible reasons:
1. The pulley nut has come loose. (easily repairable from the rear)
2. The bearing is bad (part of the rear tub).
3. The spinner has come loose from the basket (what you describe)
In cases 2 and 3, the entire drum/tub assembly will have to be removed, disassembled and repaired/replaced.
Check your owners manual for possible limited warranty. Contact Whirlpool for potential warranty repair concessions for case 3 if not covered under limited warranty.
Regards
reg501..The FixYa Team
Jun 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Loud Noise during spin cycle
drum bearings are gone,it would cost too much to repair,the drum shaft would to be repalced as well.Sorry
Dec 15, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
144 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
