Question about Toaster Ovens
HOW TO REPLACE OVEN ELEMENT - Toaster Ovens
  • 234 Answers
Depending on how it is made, you need to remove the sides or remove the entire metal casing and you will see the ends of the element held in place by a clip or ring that must be removed, and of course you need to remove the electrical wires from each end of the element. Goodluck, Macgivor
Posted on Jan 31, 2010
The heating element on my Hamilton Beach toaster oven 31134 has a hole in the covering and smells when I use it. Is that safe? Can I replace the heating element?
The element is failing and while it will probably not catch fire, it is better to be safe than sorry and just replace it. Does not look like a replacement element is offered. Sears has this toaster oven for $22.49 + $6.99 shipping.
Dec 10, 2016 | Hamilton Beach Toaster Ovens
Heating element on toaster oven have mercury in them
No they don't. If they did it would be online and they would never get through inspection anyway. Mercury is expensive, but you do find mercury in all florescent tubes and compact florescent lamps in very small quantities. Toaster oven elements are radiant and have a metal element inside a ceramic glass tube.
https://www.google.ca/search?q=Heating+element+on+toaster+oven+have+mercury+in+them&sourceid=ie7&rls=com.microsoft:en-CA:IE-ContextMenu&ie=&oe=&gfe_rd=cr&ei=bokqWOz-NoWN8Qe66IegDw
Heating element on toaster oven have mercury in them Google Search
Nov 15, 2016 | Toaster Ovens
What part needs to be replaced when the lcd and controls work but no heat?
Most likely suspects in this scenario would be the heating element or the temperature sensing rod. Not sure what the sensing rod setup on this oven looks like, but it is generally a few inches long, similar diameter to a charging cable for your phone, attached to the back wall of the oven and sticking out directly toward the oven door. If it goes bad, the oven may think it has reached the set temperature and turn off, but generally, it is the opposite (it allows the oven to get too hot). My guess is heating element, but the sensor generally costs a lot less to replace, though maybe not with a small toaster oven. Good luck!
Jul 18, 2014 | Breville BOV800XL 1800 Watts Toaster Oven...
Need heating element (upper) for GE168947 toaster oven
You should be able to install a new replacement element or a used element from another GE168947 toaster oven.
Jul 03, 2012 | Toaster Ovens
Bottom heating element warped then stopped working
can you get in to replace the element?then do so if you can it is easy just look how it was put in as you take it out to replace it!
Sep 28, 2010 | DeLonghi AD699 Airstream Digital 1500...
Heating units bottom stopped working. Then the top heating bars stopped working. It's a radiant oven.
it is several prosibilites for your problem:
1) the wire of the oven is damaged;
2) the thermostat is decalibrated or damaged;
3) one or more heating element is intrerupted or burned.
solution's:
1) check the wire an replace or repair where is posible whit similar heat resistant wire;
2) replace the thermostat whit similar one;
3) replace the heating element
Feb 21, 2010 | Oster 6239 Toaster Oven with Convection...
Sunbeam toaster oven upper heating coil not working
the part (element) cannot be bought , its connectors are welded into place ........ if you realy love your oven , you can get one by shopping in a goodwill store for a used oven and cut the element out and cut and weld the element into your oven ........ this does work ,i have done it
Feb 25, 2009 | Sunbeam 6198 Toaster Oven with Convection...
Black & Decker Toaster Oven Model TR01000-TRO4000
I honestly believe that the burned element in my toaster oven is replaceable
like a burned out oven element or dryed element. I thought someone would
show me how to replace the element. That didn't happen. I am dubious
about the need for experts via a commitment to a specialists' plan.
Peter Olevnik
Dec 15, 2008 | Black & Decker TRO360 Toast-R-Oven Toaster...
Delonghi upper element warped
We had a Hometek toaster oven with the same issue. OEMs won't send you spares for health and safety reasons. With care you can bend the element back into approximate shape, take care not to let the element touch any other metalwork in operation.
Aug 17, 2008 | Toaster Ovens
Toaster Ovens Logo
680 people viewed this question
Top Toaster Ovens Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dave
Dave
Are you a Toaster Oven Expert? Answer questions, earn points and help others
