Question about Kicker DX350 Car Audio Amplifier
My amp goes into protection mode at high volume
I have a kicker amp running two 12's. the system plays but if i turn it up too loud the amp goes into protection mode. can u please help?
  • tdhesseltine Nov 04, 2008
    i have a kicker zx1000 amp running on two 10" kicker L7 and when i turn the volume up the amp shuts off after a few seconds and goes into protect mode... why???
  • 24 Answers
Need more info, make and model of amp and subs please
Posted on Feb 21, 2008
  • cord3r19 Feb 03, 2011
    can u help me out message cord3r19@yahoo.com got a kicker kx 700.5?
    New Friend:
  • 12 Answers
Hi does the amp return to normal operation once the volume is lowered? If so it sounds like the amp is seeing too low an ohmage due to the way the subs are wired & they are drawing too much current so the protection circuit intervenes to prevent damage.The minimum ohmage this amp must be operated at is 2 ohms so if you are running at 1 ohm this will cause the problem you are experiencing.
Cheers, acbva.
Posted on Nov 15, 2009
Jl 1000/1 goes into protective mode with low frequency
Do you have a capacitor????? If not, when its up loud and hitting hard it might be going into protection because of a voltage sag....If it goes below 11.8v they will usually do that.....Get a multi meter and put on the hot and ground of your amp when its playing loud and see what the voltage is dropping to.....If its going below 12v, thats your remedy...gd luck....
May 02, 2012 | Jl Audio 1000/1 Car Audio Amplifier
My amp started to smoke, and cut off,had a real loud burning smell,has not worked since.
Sounds like it was playing? If it was your voltage dropped and the mosfet power supply got toasted. These amps are notorius for burning up at low voltage. Kicker did not put a low voltage shut off on it.,
Sep 08, 2011 | Kicker ZX15001 1Channel Car Amp
My sub woofer will stop working if i put the bass up to loud, ill have to turn my car off and on to get it to work again. What could be the problem?
Seems like your power amp for the sub woofer may be going into protect mode/thermal overload when you push the volume too much. Therefore it shuts down. I am surprised the speaker hasn't blown yet.
As far as turning car off/on to get it to work, it's as if your car is the power switch.
Amp and speakers may not be wired correctly, as you want to make sure your amp/speaker ohm measurements are within a specific range for the amp and speakers work together properly. You may have it wired for a 2 ohm load, and maybe your amp can't do 2 ohms all day long.
Apr 09, 2010 | Kicker Comp DC12 2-ohm Enclosed Subwoofer...
My amp goes into protection mode when i turn on my car. It gets hot too. I had 2 kicker 12" l5's and blew the subs with that amp, could i just have a simple problem with the amp? What are all my options?
Protection LED on, no output? Amplifi er is very hot = thermal protection is engaged. Test for proper
impedance at the speaker terminals with a VOM meter (see the diagrams in this manual for minimum
recommended impedance and multiple speaker wiring suggestions). Also check for adequate airfl ow around
the amplifi er. Amplifi er shuts down only while vehicle is running = voltage protection circuitry is engaged.
Voltage to the amplifi er is not within the 10–16 volt operating range. Have the vehicle’s charging and electrical
system inspected. Amplifi er will only play at low volume levels = short circuit protection is engaged. Check
for speaker wires shorted to each other or to the vehicle chassis. Check for damaged speakers or speaker(s)
operating below the minimum recommended impedance.
No or low output? Check the balance control on source unit Check the RCA (or speaker input) and
speaker output connections.
Jan 29, 2010 | Kicker ZX10001 Car Audio Amplifier
Jbl am in protect mode
if it goes in protect mode means ur amp is turn up to high or it is over heating so it protectn it from fryn ur amp try to adjust it down
Jul 12, 2009 | JBL BP1200.1 Car Audio Amplifier
Kicker amo in my old vette
If the amp is in protect mode, it probably has shorted output transistors. To eliminate other possible problems, do the following.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage drops below ~11 volts, you need to check the wiring feeding whichever line is dropping too low when the amp goes into protect.
If the voltage is OK, you need to check the speaker wiring and the speaker(s). Try it with a known good speaker if possible to see if the amp works normally.
Nov 07, 2008 | Kicker KX600.1 Car Audio Amplifier
Kenwood amp kac-x401m
How long will the bass play before the amp kicks into protection mode and how loud are you listening to it? I've noticed with my amps that if they don't have enough air flow they will get hot and kick into protection mode. They will also kick into protection mode if you are running it at more than it can handle. Check your adjustments on both your amp and the head unit. Make sure you are not running more bass than the amp can handle.
Nov 04, 2008 | Kenwood KAC-9152D Car Audio Amplifier
Kicker zx1000 only plays at low volume
how high did you turn the gain up and or the freq. mode most soun good at 90to 120hz. any higher some amps trip, and your speakers may not be able to handel the amp.
Jul 20, 2008 | Kicker ZX10001 Car Audio Amplifier
Goes into protection mode for no reason
if the amp is powering on the sub and playing and then turns in to protect mode it could be the amp is getting hot and its kicking into protect so you wont fry the amp
May 06, 2008 | Kicker 06ZX750.1 Car Audio Amplifier
Kicker DX350 Car Audio Amplifier Logo
1,155 people viewed this question
Top Kicker Car Audio & Video Experts
Morne Olivier
hoyzee1
Marvin
Marvin
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
