Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Garage door opener: motor runs but chain doesnt move.
My garage door opener motor runs, but the chain sprocket doesn't rotate. Is this easily repaired, or should I just buy a new unit?
    President:
  • 3,197 Answers
Depends on your mechanical ability. The drive gear is stripped. The part number is 41A2817 and is available at any door opener service company. It comes with instructions.
Posted on Feb 01, 2010
My garage door chain came off, i put it back on
Loosen the chain enough so that you can remove it from the sprocket above the motor unit. With the door closed run the motor until the sprocket turns clockwise and stops. With everything attached replace and tighten the chain. Some adjusting of the up and down limits will probably be required.
The chain normally comes off when there is a problem with the sprocket and gear assembly. The bearing goes bad and lets the shaft lean towards the door and the chain comes off. If this happens again you will need to replace that assembly which is part #41C4220A and is available at any good door service company.
Jul 24, 2010 | Sears Craftsman LiftMaster Chamberlain...
The door only moves 15 inches in each direction. I just installed a new gear kit.
Loosen the chain enough so that you can remove the chain from the sprocket above the motor. Run the motor until the sprocket turns in the clockwise direction and stops. With the door in the closed position replace and tighten the spring. This will get everything in sync and you will most likely need to tweak the 'up and down limit' controls to get it just right.
Oct 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman garage door opener 1/2 hp will not open door
It sounds like your chain is out of sync with the limit switches. Loosen the chain enough so that you can remove it from the sprocket on top of the motor unit. Now run the opener until the sprocket runs counterclockwise and stops. Now with everything attached and the door in the open position replace and tighten the chain. You are now in sync. You may need to tweak the up and down limit controls which are on the side of the motor unit.
Aug 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftman door opener brand new wont work?
Sounds like the drive gear is stripped. Remove the cover and take a look. It is white nylon and is just in front of the motor.
Jul 04, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener (chain) motor runs in reverse. Trolley slides forward trying to close door, even though it is closed, instead of sliding toward motor to open door. Happened out of the blue - was
Loosen the chain enough that you can remove it from the sprocket. Run the opener until the sprocket turns counterclockwise and stops. With the door in the open position replace the chain. You will probably need to adjust your open and close limits per your owners manual.
May 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman opener motor works, but chain does not move.
If the motor is working but the chain does not move you must remove the cover on the motor and check to see that the chain is on the sprocket. If the chain is on the sprocket and the sprocket is not moving but the motor shaft is moving then the sprocket must be retightened onto the motor shaft.
Apr 20, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener motor runs, but the chain drive doesnt turn
If the chain is not moving and the motor is – you need a gear kit.
Unplug the unit - take of the cover – you will find white shavings inside – these confirm the diagnosis. .
Get the gear AND sprocket kit.
It’s a good DIY project but you MUST VERY CAREFULLY Follow the instructions step by step.
HOPE THIS HELPS
Mar 13, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener motor doesn't work.
2 flashes is a safety eye issue, but you problen is most likely that the chain is not sync with the limit setting. Take the bottom off the gear and sprocket assemble and rotate center limit srew until it is in the same position as the trolley.
Jan 26, 2009 | Sears Craftsman LiftMaster Chamberlain...
Motor sounds like it is running but sprocket doesnt move
how old is unit. sounds like gears are shot, takes $25 of parts and 2-3 hours to fix if you are handy. Take cover off, If it has white powder (Not ****), gears are shot.
Jan 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
876 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
