Question about Singer CE-100 Futura Computerized Sewing Machine
Original cd that came with machine will not download. it gets to 93% then and error message comes up.
    Novelist:
  • 233 Answers
First, there's a Windows 7 update available at www.Futura-support.com. Click on the lefthand side, then on CE100/150/250/350, etc, etc. Follow the directions CAREFULLY. First, be sure the uninstall ALL Futura software you've attempted to install and reboot your PC.
If for some reason this doesn't solve you're problem, I've posted a set of instructions at http://www.fixya.com/support/r8955271-use_machine_windows_7_or_vista that will allow you to run the software under XP on your Windows 7 machine. This is a bit more complicated a solution, but if you follow the instructions carefully, you should be fine. Try the Futura update first, though.
I hope this solves you're problem. Happy embroidery!
Posted on Apr 24, 2011
Error message #2
Perhaps this error list will help you resolve the problem:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&ved=0ahUKEwijuKaq-9fJAhUD6WMKHXLVCyYQFggjMAE&url=http%3A%2F%2Fwww.janomeservicevideos.com%2Fwordpress%2Fwp-content%2Fuploads%2F2015%2F02%2FError-Codes.pdf&usg=AFQjCNHyJmEhmZ9Avh-lSL4Y0vVHEYM1yg&cad=rja
Try lowering the pressure foot and the needle and then raise them
again and then restart the machine, and if that doesn't clear the
error message then it's time to service the machine.
Dec 12, 2015 | Janome Memory Craft Clothsetter 10000
Connection error, check usb cable....
This may sound silly and I am not trying to be a smarty but mine does that quit a bit and it always because I don't have the on switch on when I pull up my soft ware and if the cord you bought is to long it will not work I suggest only because i do this frequently go back to the original cord hook it up turn it on then pull it up on your computer
Sep 06, 2015 | Singer Futura Xl-400 All-In-One Sewing And...
Have a window7 laptop and cannot download software for futurases2000 so know i hve a embrodiary machine jhat i can't use please help disappionted
Do you have the original disk for the Futura software? Which version of the software do you have? Do you have the 32-bit or the 64-bit version of Windows 7? (To check your version, click Start > Control Panel > System and Security > System. If you see x64 at the end of the OS version, then you have the 64-bit version. Otherwise you have the 32-bit version of Windows 7.)
For the Futura SES-2000 version 3 software:
If you have the original CD, then do you have an optical drive in the laptop? If you do not have an optical drive, you should get an external one (USB connection); these can be gotten for ~$50 or less. (Make sure to have the laptop on AC power when installing software.)
You should be able to start the installation of the Futura software from the CD. For details on the 64-bit install: http://www.futura-support.com/files/Futura%2064bit%20Installation.pdf . In the 64-bit install, you will click OK on several error messages. Then download and install the patch from http://futura-support.com/downloads/updates/Ver3_0_0_9.exe .
For older versions of the software, there are a few options, you could upgrade to version 2.5 or you can maintain a computer with an older version of Windows. (See http://www.futura-support.com/downloads/ce150.html and the Service Updates links in the lower left hand corner.) For the older version of Windows, you can keep a second machine with that OS, a dual boot computer with the OS, or a virtual computer with the older version. If you have Win7 Pro or Ultimate or upgrade to one of them, then you can run a virtual copy of XP for free. Download and install in order: Microsoft's Virtual PC and the XP mode software. Then install your Futura software to the XP computer (as if it were regular OS) and connect the sewing machine and transfer the files for your embroidery. There are other virtual computer programs (Parallels and VMWare). However, XP mode is the only way to avoid needing a licensed version of the older Windows OS.
I hope this helps.
Jul 30, 2011 | Singer CE-200 Quantum Futura Computerized...
Need Software, Singer Futura CE-100 Embroidery Machine,lost cd evelyn.hardy@hotmail.com
Unfortunately, the only place I found after searching and searching months ago was to go back to Singer itself and pay for a new CD. The cost was $100 as of January, 2011. It doesn't do any good to copy someone's CD or for someone to get it to the internet for you to download, because when you go to install the software the program asks for you to put the CD in the drive, and the program knows to look for an original CD.
Jan 15, 2011 | Singer CE-100 Futura Computerized Sewing...
I need the singer futura driver to download
Oct 12, 2010 | Singer CE-100 Futura Computerized Sewing...
I need the drivers to install my Futura sewing machine. Where can I get them?
Jun 03, 2010 | Singer CE-100 Futura Computerized Sewing...
Need the software instalation CD. Can you help
Apr 10, 2010 | Singer CE-100 Futura Computerized Sewing...
Futura CE200
called singer and they sent instructions
May 05, 2009 | Singer CE-200 Quantum Futura Computerized...
Pfaff 2170 Query
my pfaff 2170 machines shows "Cannot make Directory" pls help me in this
Apr 26, 2008 | Sewing Machines
Hoop arm won't slide to start position
You can try re-loading the program, it is possible the static spark has corrupted one of the chips if this is the case and the re-loading does not fix the problem then I am afraid you need the services of a sewing machine tech.
Jan 28, 2008 | Singer CE-100 Futura Computerized Sewing...
Singer CE-100 Futura Computerized Sewing Machine Logo
101 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
