Question about Dishwashers
Bit of plastic stuck in the drain is making a horrible noise.
Little bit of plastic broke off of one of my daughter's toys that we tried to wash and now it's making a horrible noise during the wash cycle. Tried to feel around the bottom for it but without luck. Where is the drain and how to you get to it? Amana ADB1500AWB Dishwasher. Thanks for your help!
  • 619 Answers
On this particular model you have to go thru the top section of the pump. Remove spray are and using torx crew driver remove all the upper section to get to the piece of plastic. Don't worry you can do this and not cause any leaks.
Posted on Jan 31, 2010
The washing machine wont drain its water
It could be a clogged filter, a belt that broke, or a bad pump or motor. There could be a bad relay, switch or controller that sends a signal to the motor. The model number might narrow the cause, but unless you are a do-it-yourselfer, you may want to call a repairman.
Does the pump make noise, are there any error messages?
Sep 24, 2016 | Washing Machines
My maytag MAH550BWW has recently started making a horrible howling noise. It is otherwise working perfectly. It is draining good and not leaking at all.I have taken both hoses off the pump and found...
Had the nd error and smelled like burning wires. Read a review here and removed drain pump and a piece of plastic stuck in the impeller. Removed,inspected and reinstalled. Worked perfect! Thanks
We were heading out next day to buy new washer and dryer at $2000! Yikes!
Apr 28, 2011 | Maytag Neptune MAH5500B Front Load Washer
Makes a horrible noise when it is draining
Either something stuck in the pump or the pump bearings need lubricating. It is easy to remove buy tipping the machine back at 45 degrees, the pump is under right front and is removed by turning anticlockwise.
Apr 19, 2010 | Fisher and Paykel IWL12 Top Load Washer
My washing machine is making a metallic grating noise on the wash cycle although not all the time. It has also stated to make a louder version of the noise when spinning
Alot of times the underwire of womens bras comes out in the wash cycle and gets stuck in on of the holes of the tub and starts to make the horrible racket. Look in the machine with a flashlight to see if you can spot the culprit. Usually not to hard to spot. I would find it before it gets into the water pump and starts breaking things that are costly to repair.
Jan 21, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Water will not drain out of dishwasher
trace it back along the outlet pipe and you will find on the pump a unscrewable plug be carefull as you are going to get a few litres of water over the floor
Apr 08, 2017 | Hotpoint 24 in. HDA1000Z Built-in...
Printer makes a loud clicking noise
Same problem after a paper trapped. I don´t know if the paper trap was because something broke, but after I took the paper the noise started. Please someone give us a solution.
Apr 13, 2008 | Samsung ML 2010 Laser Printer
Kenmore Washing Machine won't agitate, spin, or drain
The problem sounds like the motor to transmission coupler. If it is not draining or spinning you may find that the lid switch is inop.
Dec 07, 2007 | Washing Machines
Dishwashers Logo
127 people viewed this question
Top Dishwashers Experts
