Question about Cobra 29 LTD CB Radio
Will the 29 bt handle nextel direct connect - Cobra 29 LTD CB Radio
  • 141 Answers
If its a bluetooth phone... then it should
Posted on Mar 01, 2010
Cobra manuals 29 lx bt lcd
www.cbtricks.com click on vradio schematics,manuals , click on C then click on cobra ,then scan down to 29 lx bt . If you don't have any results do a serch engine for a service manual for it.
Jun 12, 2014 | Radio Communications
Cobar 29 LTD with BT I have found many sites that show modding but most of them had completely different directions and wires to alter... Can anyone give me a sure fire way to boost the output watts on...
Hi socom, my name is John. Welcome to FixYa. There are different ways to do this, its all in what one wants out of his radio, I personally would not want the watts with out the modulation to go with it.You can let me know, and I will post it here. Thanks for choosing FixYa....John
Dec 04, 2010 | Cobra 29 LTD CB Radio
I have had a Cobra 29 BT installed and my reception is nothing but loud static only when moving. It is a 2010 Freightliner and SWR is consistently high at about 3.0. Is this a coax or antenna problem?
Hi,my name is John. Welcome to FixYa. It could be both. Try running your unit direct from or to the battery, bi-passing all ignition noise. Make sure your antenna is getting a good ground, have your SWR checked at a near-by CB shack, or Radio Shack all for free. Thanks for choosing FixYa....John
Nov 16, 2010 | Cobra 29 LTD CB Radio
Can boost mobile sim work in a pro 700
PRO 700 DOES NOT USE SIM CARDS! instead like the other sprint phones it uses the ESN/MEID number on the back. Just call sprint and tell them you want to do an ESN SWAP or SWITCH TO A NEW PHONE and they will ask you for the number under the battery. They will also walk you through activating everything including Direct Connect. It is as fast as Nextel traditional Direct Connect but it has a MUCH LARGER COVERAGE AREA FOR VOICE AND DIRECT CONNECT. Soon these phones will take control and the whole IDEN network Nextel uses will be converted to CDMA (sprints High Speed Network).
Mar 14, 2010 | Sanyo PRO-700 Cellular Phone
Direct Connect feature is hard to engage(Motorola i570 Nextel)
Compare the pressure required on your phone with someone else's i570 phone. If yours is harder, you will need to replace it with another phone. (You can just swap the SIM card). If yours is the same, you will have to live with it. This button is not a user-servicable component. I have used about 8 or 9 different types of Nextel phones, and I have not noticed any difference in any of them.
Dec 29, 2009 | Cell Phones
How can I unlock my blackberry curve 8350i (nextel) to work with boost mobile?
You do not need to unlock the blackberry 8350i to work on boost, you need to replace the service books.  The phone and direct connect will work immediately if you put a boost sim in the phone.  To replace the service books, look here for instructions http://www.howardforums.com/showthread.php?t=1530734
Just follow the directions.  Good luck
Nov 28, 2009 | Cell Phones
Cobra 29 NW WX BT Channel indicator
Still have the receipt? Take it back to the store and exchange it for another one. Easiest and quickest solution.
Otherwise, you can unplug the power from the radio and take the top cover off and check at the channel selector module to see if there's a broken wire or a broken solder joint. If the radio received rough treatment during some point in shipping (the outside packaging box may show no signs if it) it could be just a bad connection.
With the top cover off, replug the power and turn on the radio. BE CAREFUL IN HERE, THOUGH!! With a pair of insulated needle nose pliers, gently move the wires that connect to the channel selector module and see if it will light up. If so, disconnect the power and re-solder the joint or replace the broken wire. Reinstall the cover and reconnect the power, you should be good to go.
WARNING...if you open the cover on the radio, you cannot return it. Do this only as a last resort, if you can't return it for an even exchange for the same model radio.
Oct 22, 2009 | Cobra 29 LTD CB Radio
SPRINT SANYO PRO 700
Hey! I just got the PRO 700. IT DOES NOT USE SIM CARDS! instead like the other sprint phones it uses the ESN/MEID number on the back. Just call sprint and tell them you want to do an ESN SWAP or SWITCH TO A NEW PHONE and they will ask you for the number under the battery. They will also walk you through activating everything including Direct Connect. It is as fast as Nextel traditional Direct Connect but it has a MUCH LARGER COVERAGE AREA FOR VOICE AND DIRECT CONNECT. Soon these phones will take control and the whole IDEN network Nextel uses will be converted to CDMA (sprints High Speed Network).
Apr 09, 2009 | Sanyo PRO-700 Cellular Phone
Cobra 29 LTD CB Radio Logo
73 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
