I have a 13 year old Toshiba T55H60 Theatre View Rear Projectuon tv and i need to know how to fix the convergence.
  • bradysrental Jan 31, 2010
    is there any way to adjust the convergence before i go out and buy new chips? And where is the best and cheapest place to get the parts?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. You have to replace the convergence IC(stk ICs) and check power resistor for leakage, if values are not exact you have to replace them. The typical cost to get this fixed by a pro is about $300 - and it doesn't mean that he/they will do a job better than you do. The parts are less than $100 (about $20-$30 for the IC's) if you want to do it yourself. Replacing only the IC's MAY solve the problem; however, many people have also had blown resistors requiring replacement. Why would you ask should you replace both of the IC's if only one is shot?! If one is shot the other one is not far away and for that little price of the chips it worth changing them both at the same time. Also the convergence board should be checked for cracked solder. If you replace the ICs and the resistors are shot, the ICs may blow again almost immediately, meaning you may have to do the repair twice.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Jan 31, 2010
  • Rylee Smith
    Rylee Smith Jan 31, 2010
    Its been 13years for the set so I dont think adjusting convergence might help you. If you want to buy parts you can buy it out from this link: Toshiba T55H60 parts. Please do accept the solution if the issue is resolved or else revert for further assistance.
    Thanks
    Rylee
Red light keeps flashing on toshiba theatre. How can I fix it?
on the older sets it is a short and usually in the convergence circuit, the way to know is located the convergence chips and unsolder both from the board (18 pins each) and if set then comes on (WILL LOOK BAD) one of the two chips is bad and both need to be replaced----should be stk-392=110 chips.
May 22, 2012 | Toshiba TP55F80/81 55" Rear Projection...
The convergence looks like it failed finally. 8+ years old. Fix it or buy another tv?
Fix this tv can last u another 5 or 6 years easily.The shop will cost u like $300-350 to repair the convergence board
Jan 13, 2011 | Toshiba 42HDX82 42" Rear Projection...
Toshiba Rear Projection TV picture color is now a greenish hue
Hi, I used to work in Best Buy and one of the key things about rear projection TVs and the reason they push those service plans on you is that the tubes/colors need to be calibrated each year. You can do this yourself by checking out the following website:
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=3229
If you are not able to adjust the convergence using the remote you will need to replace the convergence chips.
Typical Symptoms
1) Convergence menu does not work for one or more colors.
Such as: Red moves up,down, but left or right fails.
2) Screen is bowed looking.
If you have one or more of the problems above you need to replace the convergence chips. You can get a kit and instructions from www.TvRepairKits.com
Hope this helps :)
Sep 12, 2009 | Toshiba 50H82 50" Rear Projection...
Panasonic PT-47WXC43G Red Color problem
This is a convergence problem; in the customer menu there is an option to adjust it----if red or blue will not move in some direction---one of the two convergence IC's is bad and both need to be replaced.
I have step by step instructions telling what you will need for this repair. They are in Microsoft word----let me know if you want them and I will email them to you. You can buy both chips for this set on Ebay for about 13 dollars plus shipping for a pair.
etower.766@netzero.net
I do this here for free so if this has helped you take a moment and give me a vote here.
SD TECH
Sep 03, 2009 | Toshiba 53H71 53 in. Rear Projection...
Convergence problem red lines are out of wac on
Most of these sets use two STK-392-110 convergence IC's; both along with any open resistors around them need to be replaced and the set adjusted.
You can buy the chips on Ebay for less than 13 dollars(look for suburban electronics--Sewsale--they have the best price on these parts and give a 6 month warranty) if you are able to replace them yourself if not, look for someone in your area to do the job for you; this is the slow time of year for TV repair shops---some shops get 300 or more for this repair. I fix a lotof these smaller sets(42 etc) for 200 parts and labor.
Find someone and make sure BOTH IC's are replaced. If you have questions let me know here. I do this for free so if this was helpful give me a vote here.
regards, SD TECH
Aug 25, 2009 | Toshiba 42H81 42" Rear Projection...
Power light blinks off and on, nothing else
try unplugging the three convergence yokes then try powering up the set to see if it powers up. If it does replace both convergence ICs
Feb 03, 2009 | Toshiba 55H70 55" Rear Projection...
Toshiba TP50H95 TV Won't turn on - Pete
You will need to trouble shoot the start up and shutdown circuits. Often this is a minor component failing causing the set to not power up or go into protective shutdown. Do you have the service manual for this TV?
Mar 01, 2008 | Toshiba TP50H95 50" Rear Projection...
TV picture shaking!!!
It sounds like the Hyper board is begining to fail....Does the menu shake too?
May 16, 2007 | Toshiba 50HX70 50" Rear Projection...
Samsung SP42W4HPX
The convergence wouldn't cause it to go all green. Green outlines yes but, not all green. Get a technician to look at it.
Mar 06, 2007 | Toshiba 53H71 53 in. Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
