Question about Dell Vostro A860 Notebook
Can you help me with my dell vostro a860. everytime its shutting down by itself,i mean in fact its not shutting down but just power off
Do you have a charged battery? If not, it sounds like a bad power jack.
Posted on Feb 01, 2010
Vostro dont start
There is a coin cell style battery inside that keeps the cmos values while the notebook is off. In time that battery will run down and needs to be replaced.
Feb 12, 2014 | Dell Vostro A860 Notebook
In my dellvostro a860 , rite side of the screen colours are spreaded,it it looks like shade,,whats the problem in that i m not getting please help me..........
It is the screen Inverter, or the LCD screen itself.
Screen Inverter: A small circuit board located behind the Display Bezel, and mounted towards the bottom of the LCD screen,
http://support.dell.com/support/edocs/systems/vosA860/en/sm/display.htm#wp1183775
The yellowish long object, at the bottom, is the screen Inverter.
Here is another look at it,
http://www.batterycenturys.com/dell-vostro-a860-inverter-p-185294.html
Dell Support > Vostro a860 Notebook PC > Service Manual,
http://support.dell.com/support/edocs/systems/vosA860/en/sm/index.htm
In the list clicking on -> Display, will get you to the first link above.
Need guidance in replacing the screen Inverter, post in a Comment.
(Just a basic guide using a Vostro 1014/1015 Notebook PC. Not yours, but good for basic guidance. This is replacing the LCD screen,
http://www.insidemylaptop.com/replace-lcd-screen-dell-vostro-1015-1014-laptop/
[ Primer:
An LCD screen cannot produce light by itself,
http://solutions.3m.com/wps/portal/3M/en_US/NA_Optical/Systems/BehindTheScenes/Optics101/
( Click on the small window with the monitor in it )
It needs an additional light source. A Backlight is the additional light source.
A Backlight can be a CCFL, (or more than one), or a series of LED's used as lights.
The Dell Vostro a860 Notebook PC uses one CCFL, for a Backlight, OR there are Vostro a860's that use LED lights.
(If you replace the LCD screen, make sure FIRST of what type of Backlighting it uses)
A CCFL is a Cold Cathode Fluorescent Lamp. Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
[Average thickness of a CCFL is 2mm. That is a little larger than 1/16th of an Inch.
Average length is almost as long, as the LCD screen is in height ]
A screen Inverter is used to convert the power from the laptop, for the Backlight, and LCD screen.
Most of the time the fault is the screen Inverter.
The Vostro a860 Notebook PC's, that uses LED's as a Backlight, MAY also use a screen Inverter.
Primer over.
For your problem it could be the screen Inverter, but I lean more towards the LCD screen itself, is the problem.
How to test a screen Inverter? Requires a very sensitive multimeter.
Read; Expensive,
http://www.fonerbooks.com/test.htm
For a layman who does not have access to a sensitive multimeter, the method is to just replace the screen Inverter, and see if it is the problem.
'Parts changing', I know, but if you do not have the proper equipment to test with?
Screen Inverter replaced, and problem still persists, replace the LCD screen,
http://www.laptopscreen.com/English/model/Dell/VOSTRO~A860/
For additional questions please post in a Comment.
Regards,
joecoolvette
Jun 23, 2012 | Dell Vostro A860 Notebook
Why is my dell vostro a860 overheating all the time?
It should be normal, make sure you don't block air from bottom the laptop or any sides because that is where fan sucking the air to cool off the core. If that does overheating then it should be shut down by self because it already built in temp sensor for overheating protect.
Feb 11, 2011 | Dell Vostro A860 Notebook
My Dell vostro A860 Laptop shuts off after 5 seconds that I have turned it on, the blue light showing that is has turned. The screen is black, I don't even get the boot up screen. What will I do. thanks
Enter to bios after powering and watch if it still go off. If not, go to Healt or sensors section and watch the temperature of CPU and system. The computer might turn off because of overheating.
Nov 02, 2010 | Dell Vostro A860 Notebook
I recently purchased a Dell A860 from a garage sale. My problem is they didn't give me any passwords to the laptop. When I power up the computer it asks for a password authentication system. How could I...
try booting it in safe mode and make a new user name with administrator privileges, then shut it down and restart to find the new name, then you can delete the other user names. Did you try to go back where you bought it?
Oct 21, 2010 | Dell Vostro A860 Notebook
I have install window srvice pack 2 then I have a problem of all the driver ie vga, sound,usb,base systm and video controller.My lap top is Vastro A840 n series. kindly send me solution
you can download all the driver for your Dell vostro A860 notebook from here follow this link to download the drivers,
http://www.getpcmemory.com/drivers/dell-vostro-a860-download-dell-vostro-a860-notebook-windows-xp-drivers/
this will solve your laptop driver problem
Thank you for using Fixya.
Regards
Manish
Jun 13, 2010 | Dell Vostro A860 Notebook
Dell Vostro A860 Ntbk, Vista Home Basic, Slow, Fan Always Running
Try one of my Tips & Tricks which i had published
http://www.fixya.com/support/r4681055-speed_tune_up_windows_vista
I hope it might help your Notebook run faster.
May 12, 2010 | Dell Vostro A860 Notebook
Can you help me with my dell vostro a860. everytime its shutting down by itself,i mean in fact its not shutting down but just power off instantly. i thought it was due to some virus or because of the...
well if it is just tuns off that might be the problem with the power supply unit so its better to check the power cords, battery, power plugs are working properly. good luck
Jan 05, 2010 | Dell Vostro A860 Notebook
How to switch on the wireless switch on dell vostro a860
have you tried to switch to wireless by using the keys: Fn + F11 ?
Jul 10, 2009 | Dell Vostro A860 Notebook
Dell Vostro A860 Notebook Logo
248 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
