Question about Trendware TEW-652BRP Router
'admin' password stopped working - Trendware TEW-652BRP Router
  • 2,260 Answers
If the default password is not working then you will need to reset the router for 30 seconds. unplug the power to the router. wait for 10 seconds and plug it back in. wait for 1 minute and now try to access the router.
Once you reset the router , you will need to reconfigure the router.
Click Here for more information about how to reconfigure the router.
Posted on Feb 01, 2010
I forgot my Bizhub 223 administrator password
The admin password is 12345678 yes you can change the password you will need to log into the tech rep mode once in tech rep mode you need to press the following buttons stop 0, then the C button
once this is done you then select admin password and change it
Aug 04, 2014 | Konica Minolta Bizhub 223 Copier
Password reset tool
No reset tool for password. Just to service mode utility then meter count then stop 00 stop 01 to admin reset admin password default is 00000000
Oct 08, 2013 | Minolta Di550 B&W Laser Printer
I have a asus wl-600g. i sometimes do a power off, and power on again. two days ago, i did a power off, and i kept it disconnected, since the morning until the afternoon. When i connected it again a few...
Reset your router back to it's factory settings by holding the reset button for about 5 seconds. I have provided a list of the most popular router brands. If it does not work you may need to google what your specific model's default IP address/default username/default passwords are, for example search for "Encore ENHWI-2AN3 default IP address" The default login info can change, it can depend on where you obtained your router. If you purchased it yourself from a store then the standard defaults should work. If you obtained your router from your Internet Provider you may need to contact your service provider. It also may depend whether it's an old or new model router as well. And you may need to press and hold the reset button on your router several times before it actually clears. Make sure you have a wired connection then once you have accessed your router simply run the Setup Wizard. Set your SSID as something you'll remember like "Mavericks Network" and your Password can be something like your phone number for example 3109876543
Belkin - Username: Leave the field blank Password: Leave the field blank Default IP address is: 192.168.2.1
Buffalo - Username: root Password: Leave the field blank Default IP address is: 192.168.11.1
D-Link - Username: admin Password: Leave the field blank Default IP address is: 192.168.0.1
Encore - Username: admin Password: admin Default IP address 192.168.1.1
Linksys - Username: admin Password: admin Default IP address 192.168.1.1
NetGear - Username: admin Password: password Default IP address will be: 192.168.0.1 or 192.168.1.1
TP-Link - Username: admin Password: admin Default IP address 192.168.1.1
TrendNet - Username: admin Password: admin Default IP address 192.168.10.1
Zhone - Username: admin Password: admin Default IP address 192.168.1.1
Zyxel - Username: admin Password: 1234 Default IP address 192.168.10.1
Sep 07, 2011 | ASUS WL-600g Wireless Router
I just installed my new netgear router and i have the hardtime to get a username and password..what is the best way to fix this problem
Default settings will be as mentioned below....
IP address:
//192.168.1.1
Username: admin
Passsword: password
Thanks,
Satheesh
Jan 27, 2011 | Computers & Internet
Hi guys, i just got a thomson twg870 and i'm trying to connect to 192.168.0.1 but i can't find the username and password. I tryed with admin and "password" but it's not working. Any ideas? Thanks
pankystu,
The default username and password for most routers is:
username- admin
password- admin
OR
username- administrator
password-
Hope this helps.
-S
Oct 19, 2010 | Computers & Internet
How can I rest the admin password on Bizhub c250
still having trouble..if default password didnt work for you then try reseting it to default password by:
1) Utility/Counter
2) Details
3) press STOP zero zero + STOP zero one
and now your in Tech Mode
4) same page press STOP + Zero + C
5) modify admin password and retype and then exit
6) do not DO NOT touch any other options unless you know what your doing..you can lock the machine and would be able to work..rate if this helped you out
Feb 24, 2010 | Konica Minolta bizhub C250 All-In-One...
Username password
Start a HyperTerminal session: Click Start and then select Programs -> Accessories -> Communications -> HyperTerminal. c. Set baud rate as "38400", data bits "8", parity "none", stop bits "1", and flow control as "None". Then press "OK" to bring up the HyperTerminal window.
Apr 18, 2009 | EnGenius EOC-3220 (EOC3220)
Konica Minolta Admin Password
Try 12345678.  That worked for me for my Bizhub C250.
Mar 18, 2009 | Konica Minolta bizhub C250 All-In-One...
Konica minolta c 200 password
It was 12345678 for our C250 - hope this helps. And sys_admin (solution 1) - You are a complete idiot. Your answer was useless. If you were working for me, I'ld fire you...
Feb 01, 2009 | Konica Minolta bizhub C250 All-In-One...
Connecting to the internet via wireless router
access your router with following link
http://192.168.0.1
then type user name:admin
password is:admin or blank
then enable DHCP.then u can get ip automatically.
set in your wireless lan adapter proprties tcp ip properties theh enable ip get auot amtically. thats it.
Nov 15, 2008 | NetGear RangeMax WPN824 Wireless Router...
Trendware TEW-652BRP Router Logo
565 people viewed this question
Top Trendware Computers & Internet Experts
Prashant M
Prashant M
Tejodhar Atreya...
Tejodhar Atreya...
Are you a Trendware Computer and Internet Expert? Answer questions, earn points and help others
