Estate Washer: Mod# ETW4400VQ2 Water to washer just trinkles in. Ihave replaced the water valve, which has a Thermister on it. Water still just trinkles in during the Rince cycle. I diconnected the hoses to the water valve, and checked for water preasure. That was all good. This washer doesn't have a control board. So I'm thinking it must be the Washer Timer or the Water Temp. Swich. The washer agitates at the proper water level, but takes a half hour to 45 Min. to get there. Any Ideas?
  • 1,531 Answers
Check the voltage to the water valve.you could havesediment build up in the lines that come from the water valve.check the hose that comes off the water valve to the top of your tub.
what side of the water is slow. you can switch the hoses and or connection to the water valve as well as the temp switch.temp switch can be faulty check the current from there to your water valve.
also check the continuity on your wire there could be a break that is not visible
Posted on Jan 31, 2010
Hi i have a kenmore mod.110.44932 200 ser.csn0605989...no code but at time while the washer not in use i hear water then when i check the washer the inside is full of water and running out the door what...
The problem is that the water valve is not fully closing and the water valve would need to be replaced to stop it from filling when off.
The part number for that water inlet valve is 8181694 it could be purchased at your local appliance parts store or online at;
partselect.com
apdepot.com
repairclinic.com
searspartsdirect.com
apwagner.com
To replace that water valve,turn off water supply to washer,disconnect rubber fill hoses,remove top and the valve will be on the rear top under the top
GENE
Sep 06, 2011 | Kenmore 44932 Front Load Washer
Very little hot water runs in tub
you either have a problem with the house water supply going to the washer and you can remove the hot water hose from the washer,first shut down the water,stick the end of the hose inside the washer and turn the water supply back on,if the water comes out normal then you have a bad water valve on the back of the washer.call your parts store and give them the full model number off of the washer,open the lid,follow it down to the bottom and right under the bottom of the lid you'll see the model number
Jan 23, 2011 | Kenmore 24032\24036 Top Load Washer
How do you replace the water inlet valve on the estate by whirlpool
You unplug the machine, turn off water and bleed off pressure, open the wahsing machine case, disconnect water hoses and electrical connections to the valve, and then unscrew the valve's mounting screws.
Oct 03, 2010 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Water is trinkling down the bello and filling drum after wash is complete
Theres an electric water valve. You have to find out if its the hot or cold thats leaking and replace it.
Jan 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My washer will not stop filling with water and overflows
Turn the washer on and let the water run, while the water is running unplug the power cord if the water stops the inlet valve is ok but if still running the valve is bad and need to be replace if the pump is good you need to test the water level switch, if faulty need to replace.
good luck
Mar 17, 2009 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Estate washer, new, water will not stop, overflowing
you need to replace the inlet valve something is stuck in the valve not allowing it to shut.
Dec 23, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Washing machine leaking at the connection to water pipe.
Hi vks1,
Your water is coming out into the washer even when you water supply is switched off at the pipe?
Disconnect the washer hose from the water pipe and see if the water still comes out of the water pipe even when the water valve is shut off!
If the answer is YES!
This is a plumbing malfunction.
The valve on your water pipe is not closing completely!
There is a washer in the water valve attached to the end of the valve stem that more than likely needs replacement.
And not a washer malfunction.
If I understand your explanation correctly this is the cause.
If this is not the problem then the washer has a water inlet that is stuck open.
But this dose not make sense if the external water valve is shut off there should not be water reaching the washer inlet faulty or not!
I believe I figured out the problem for you and you will be fine when the valve is fixed or the valve stem replaced!
Bless You,
ngafm
Let me know that you have succeeded!
Happy to of helped you.
Please give me a good rating before you sign off our site!
Thank You
Sep 10, 2008 | Estate TAWX700JQ Top Load Washer
Cold water won't come out on Estate washer by Whirlpool? Why?
HI THANKS FOR THE QUESTION . tHE PROBLEM WITH YOUR WASHER IS THAT YOU NEED A NEW WATER VALVE .tHANKS FORTHE QUESTION tHE APPLIANCE DOC
Jun 09, 2008 | GE WHRE5260E Top Load Washer
Maytag performa washer hot water runs continuously
Littleone.. please check your instructions.. some washers now dont need Hot water connection to them...they heat their own as part of the efficiency settings on the wash programmes themselves!
Regards Faggly
Mar 19, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Washing Machines Logo
44 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
