Question about Bernina Virtuosa 150
My bobbin straight stitch is wavy and loose and looks ununiform and messy. Was having trouble with upper straight stitch but seem to have gotten that to look better but the bobbin stitch is bad. Tried adjustment with tension, different thread, cleaning etc. but still not happy with how it looks. Any suggestions to try before I take it for service?
  • 234 Answers
If you have any spare bobbin holders, I suggest you exchange it with the troublesome one and see if you get better results, Some times the bobbin /holder gets worn and no adjustment will correct it, therefore, you need to replace it. Or, could be that the timing (syncronization) of the upper and lower movements have changed and need to be realigned (not all models allow you to do this realignment syncronizing). Goodluck, Macgivor
Posted on Jan 31, 2010
My thread keeps bird nesting on the bottom of my fabric what am I doing wrong? What are the correct settings for a straight stitch?
Is your bobbin threaded correctly? You should be able to pull out the thread slowly while feeling it very slightly holding back. It should not pull out easily or quickly.
Could be something wrong with your tensions, try adjusting the upper tension first by starting at the middle setting and working gradually higher and then lower till you get a neat even stitch.
Nov 29, 2015 | Sewing Machines
How to adjust the bobbin tension.
According to the manual, you should not need to adjust the bobbin tension (and I located other sites which stated the bobbin tension cannot be adjusted on this machine). Apparently, all the tension adjustment is accomplished through the upper thread::
"EN Thread Tension Upper thread tension Basic thread tension setting: "4". (1) To increase the tension, turn the dial to the next number up. To reduce the tension, turn the dial to the next number down. A. Normal thread tension for straight stitch sewing. B. Thread tension too loose for straight stitch sewing. Turn dial to higher number. C. Thread tension too tight for straight stitch sewing. Turn dial to lower number. D. Normal thread tension for zig zag and decorative sewing. Correct thread tension is when a small amount of the upper thread appears on the bottom side of fabric. Lower thread tension The bobbin tension has been set correctly at the factory, so you do not need to adjust it. Please note: - Proper tension setting is important for strong seams. - There is no single tension setting appropriate for all stitch functions, thread or fabric. - A balanced tension (identical stitches both top and bottom) is usually only desirable for straight stitch construction sewing. - 90% of all sewing will be between "3" and "5". - For zig zag and decorative sewing stitch functions, thread tension should generally be less than for straight stitch sewing. - For all decorative sewing you will always obtain a nicer stitch and less fabric puckering when the upper thread appears on the bottom side of your fabric. 1 A B C 22 D"
Doing further research, I found this statement on a machine review site:
"After reading reviews online from where I've bought my drop-in bobbin machines, I think many of the negative reviews are due to the bobbin thread coming up without laying across the bobbin. It can cause the stitches to look very sloppy and no amount of tension adjusting can fix the stitches."
There are several machine review sites wherein 4423 owners stated their disappointment in the 4423's performance. Some said the machine failed almost immediately and others said the machines developed problems when sewing heavy fabric.
Apr 26, 2015 | Singer 4423 Sewing Machine
When I embroider with my Pfaff Creative 2 the top tension pulls bobbin thread up too much. I changed toe tension on top but it still does the same thing. How can this be fixed?
Suggest you do rethreading ,then test the stitches on straight stitch. If top stitches is loose you have to reduce the upper thread tension, if the bottom stitches is loose you have to increase the upper thread tension. Adjust accordingly till you can get a perfect straight stitch. If okay then you can continue your embroidery work.
Oct 31, 2013 | Sewing Machines
Bernina activa 210 won't zigzag and has bobbin issues on straight stitch
it's very possible that the machine is slightly out of time & needs to be service at a sewing machine shop
is the fabric & thread & needle compatable with each other?
did you use every thread guide when threading the machine?
is the bobbin in correctly?
is the bobbin warped?
Mar 20, 2012 | Bernina Sewing Machines
I have a singer futura xl-400 and I am having a problem with the machine
It sounds to me like your bobbin tension is off. Take the embroidery unit off and set the upper tension to "S". Run a line of straight stitches, then a line of zigzag stitches. It is helpful if the bobbin thread and the top thread are different colors for this. If the top thread is almost a straight line, your bobbin tension is too loose. If your bobbin tension is almost a straight line, your bobbin tension is too tight.
To adjust the bobbin tension, take the bobbin case out and locate two screws on the side. The one you want is the straight-slot screw on the left; leave the Phillips on the right alone. The rule is "lefty-loosy", "righty-tighty" turn in the correct direction only 1/4 turn and sew another line; you should see SOME improvement, but it may take repeated attempts to get it in balance. When it is, put the unit back on, and don't forget to change the upper tension to "E".
Feb 15, 2012 | Sewing Machines
Sewing machine tension
Hi. The upper tension is too loose (even tho it looks ok). If the upper thread is too loose, it can't pull the bobbin thread up to properly form the stitch and you get those messy 'birds nest' on the bottom side of the fabric. I posted a Tip on Adjusting Tension--read that and adjust your upper tension.
Thanks!
Robbie
Aug 02, 2010 | Singer Featherweight 132Q Mechanical...
CONSEW 206RB5 TOP THREAD NOT FORMING STITCHES AND BREAKING
you have your thread tension too tight that's why it is pulling the bottom stitch all the way through it looks good from the bottom but not good on top. Its pulled the stitch all the way through the material.
I had my own upholstery shop 18 yrs and tension gets you every time.Just loosen the top tension.
Jan 18, 2009 | Euro-Pro 8260 Mechanical Sewing Machine
Loose stitching underneath. HOW CAN I FIX!!!!
Sounds as though you may have a burr or rough spot on the hook where the bobbin inserts. Run your finger along the edge of the hook to see if there are any rough spots.I'm sure you're going to find at least one from the time you broke the needle.Once you locate it, remove it with an emery stick or small sharpening stone. Polish it so that it is smooth. Should work okay.
sewman7
Jun 27, 2008 | Juki TL-98Q
Suddenly zig zag stitch not working?
Because it is almost a straight stitch but the needle continues to move in a zig zag fashion is reason to believe it is in a long stitch. By changing the number of stitches per inch there will be a very noticeable looking zig zag stitch.
Mar 25, 2017 | Brother XL-2610
Sewing Machine, Upper Thread Jamming in Bobbin
I am having this problem also, and it is jerking up the whole bobbin case. I went to Joann's - the lady there said I have worn out the bobbin case and need to replace it.
Jan 04, 2008 | Sewing Machines
Sewing Machines Logo
894 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Derek Massey
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
