Question about Linksys WPC54G Wireless-G Notebook Adapter V2.0 (WPC54C)
Tries to connect sees wireless network and continues to try and connect but never will
  • 2,260 Answers
When you try to connect to the wireless network does it ask for the wireless password ?
If your wireless network is secured then it should ask you for the password of the network.
You can try to remove the network from the preferred network list.
Also check the wireless settings of the router.
Make sure that you have all the correct wireless settings.
To check the wireless settings of the router , you will need to open the router set up page.
Click here for more information about the routers and wireless networks
Posted on Feb 01, 2010
Router connects to computer fine but can't find network, network is running
Can you do me a favor first? if this is possible, please connect your computer with cable to the router and from the router to your modem or wall port for internet. See if this gives you internet.
Second, see if other network devices can access the internet with this wireless internet connection. Try this one first then the Cable.
I want to know where the problem is. If you say like for example Cable works, but other devices with same network wireless access doesn't work. Then i can say that wireless is either bad configured or something else happening with wireless. Then i can continue to help you.
I'm an IT student who works specially with Teamviewer to access peoples computer to help them fix such issues when it's possible and needed.
Checkout here for more netwoking accessories online , http://www.gizga.com/consumer-electronics/computer-and-networking
Jan 27, 2014 | PREMIERTEK PowerLink Hermes IEEE 802.11n...
Trying to connect to my Fast Access Wireless DSL Home Network. Continuously get the following message: REMOTE NETWORKING PPPoE Access Concentrator is not responding. Try again later. I have no clue...
Hi Sherole,
Sorry for the late reply. I need some more info before i can assist you properly. Is the Netbook connected to the Wireless network via cable or you trying to connect wireless? As i see it you are trying to do a dialup via your router which you dont really need.. If you can do the following for me. Press the start button then go Control Panel and Internet Options and then go to the Tab called Connections.. In the field where it says Dailup and Virtual networks what connections are listed?
Regards Gunter
Dec 27, 2011 | Sylvania G-Netbook
Net continuously not connecting, disconnecting immediately
It is possible that the network key is incorrect or you may need to try and reset you wireless router settings to see if the issue will still be the same.
Also try and recreate the wireless profile in windows just to see if there will be any changes with the way the wireless connection goes.
Are there any error messages when you get disconnected if I may ask?
Oct 11, 2011 | Computers & Internet
I was able to scan to my computer four pictures without any problems. When I tried the fifth, I get a "scan request failed" repeatedly. Nothing changed between the computer and the printer. ...
What is the status of the WiFi light on your printer? Try to check if your printer is still connected to your wireless network by printing the wireless network settings. How to Print the Network Settings Page on the X3500 and X4500 Series Inkjets; a Brief Explanation of its Values. Check the SSID and the IP address of the printer and see if it's the same as your network.
You can also try to relaunch the Lexmark Wireless Setup utility to connect to the printer again.
May 28, 2011 | Lexmark X4530 InkJet Printer
Just purchased a NETGEAR wireless N WNA1100 and once it installs the software, it just quits...the wizard puts an icon on my desktop that when i click, shows busy icon, then stops, and the wizard (after 3...
Try to update the driver manually
go to your device manager and go to "network adapters". if you see the adapter and it says that it is working fine, just try to connect manualy to the network.
If you see "network controller" under other devices. right click on network controller and click update driver. select manualy update the driver. browser for the drivers inside the disk and install it into your computer. after that, you'll be able to connect to the wireless network.
Sep 18, 2010 | NetGear WNA1100 WirelessN 150 USB Adapter...
Hello.My name is Nick and I have a Wlan adapter Asus 169ce.My problem is that the adapter cannot "see" my router but can "see" other routers from other houses around.What can I do?
Login to your router, click wireless and make sure the box turn on wireless in checked. If it is then open control panel-> Network connections-> Choose the correct encryption type while creating a connection(WPA, WPA2-PSK, WEP etc.,). Try it and let me know so that we can continue troubleshooting if necessary.
Aug 07, 2010 | ASUS Computers & Internet
The adapter continues to try connect even after
i have the same wireless card the thing that it does is it has to keep the connection going so it rechecks every few minutes to stay fully connected if u dont like this try switching the usb hub that u use when plugging it up.
Mar 23, 2010 | Belkin (F5D7050) 802.11a/g/b Wireless...
One laptop connects but not another
If you use Windows XP:
First do some checks!
Confirm that your WL adapter on your Laptop is not DISABLED !
If it is, Enable it! How?
Open Control panell and then, open Network connections. Right-click on your Wireless Network Adapter and click 'ENABLE' !
Next check!
Right-click My Computer, and then click on 'MANAGE' !
On the left side click 'Services and Applications', and then 'Services'.
Find 'Wireless Zero Configuration' and double-click.
Check the Startup type is Automatic, and if the service is started.
if not, change it to automatic, and then click on START.
Click APPLY and OK, and than closle Computer management console.
Do you use some Software for your WireLess ?
If so, then close and exit it!
Do you see a network icon near the clock on the right bottom of your toolbar?
Right-click on the icon and click on 'View available networks' !
If not, then open Control panell and then, open Network connections. Right-click on your Wireless lan and click 'View available networks' !
You should see a list and your Network now?
If so, then restart your Laptop, use your WL software (if any) and try to find and connect your network.
If you don;t see any network, again close and exit the software and try to connect as I said before.
If it works, than something is wrong with that software.
Do you have a CD with installation of that software?
If so, than first UNINSTALL the software, restart your Laptop and try to install it again.
If it doesn't work, then, (again) uninstall it, restart your laptop and continue to use your Windows Wireless Zero Connection instead.
regards
Mar 24, 2009 | Computers & Internet
Cannot connect wirelessly, but can through my network cable
After a few tries and re starts it may connect itself, but if not go to Start>Run, then type 'ipconfig /flushdns'. Try connecting again, but ensure your wireless card is set to obtain IP address automatically and you have enabled wireless connection and DHCP in your routers menu. Hope this helps
Dec 05, 2006 | D-Link AirPlus DI-524 Wireless Router
Open Questions:
Linksys WPC54G Wireless-G Notebook Adapter V2.0 (WPC54C) Logo
359 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
