Question about Libec LZ-60 Tripod
Libec T57 tripod
Handle / knob has broken on stick height adjustment. Need section 4 as shown on illustration.
3 Suggested Answers
Buffalo12980
  • 625 Answers
SOURCE: Libec T58 Tripod
I had a Porter-Cable that I was able to repair using three small pieces of lexan and a bandsaw. I took off one of the latches that were good and traced the pattern on the lexan and sawed out the handles. Cleaned them up with sandpaper andthen stacked them and drilled out the holes. Then I drilled two more holes for clearance for two 6-32 machine screws and nuts. Put the whole thing together and installed it - still working after four years.
Posted on Aug 22, 2007
SOURCE: Quick release plate for a Heiwa HS-744 tripod
Have you had any luck? I need one for the HS-644B model.
Posted on Mar 03, 2010
How can I replace the quick release head for the libec th659dv tripod. A student has lost the plate but UK retailers do not seem to stock libec replacements.
Try a plate from another tripod. I have three different tripods, and the quick-release plates are all interchangeable.
Jul 08, 2015 | Libec Photography
My Bausch & Lomb Professional Tripod 3 way Oil Fluid Pan Head Tilt Tension Knob is broken and the quick release plate is missing. Do you have parts for this unit?
Take off Ring Sitting Nob .... issue with tentionner Ring holder crack or base crake.. need to be change... Cause exessive force on the handle
Sep 29, 2010 | Bausch and Lomb Bausch&Lomb Master Tripod
Broken elevator column crank handle
Please state the make and model. But if it is any Vivitar model then like all budget tripods spares simply aren't available.
You either make a claim under the manufacturer's one year warranty or you chuck away your tripod and buy either another budget model or invest in a quality brand which does have spares support.
The only other option is to see if a friend or relative has an engineering workshop and can fabricate spare parts for you from scratch. It's likely to be a straightforward job, but not one which is worth paying for.
Mar 07, 2010 | Vivitar Photography
Feb 20, 2010 | Photography
Height adjustment not adjusting
The height adjustment wont engage unless the handle is in the down position. Not knowing this led me to overturn the hight adjustment knob.
Step on the handle release, pull the handle back and lay the vac on its side. Then you can get the knob and the plate back together again.
BTW, the reason I had this problem is because the front brush slows dramatically when using on carpet, I thought it was set too low, and turned the knob (in a manly fashion, putting it past its limit). Still working on that one. After inspecting the belt, looks like one worn and cracked spot gumming up the works.
Jun 21, 2009 | Bissell 3920 Bagless Upright Vacuum
Leg lock broken
Assuming you still have the female part with the treads in tact, you can do what I did. I used a hose clamp, the kind used on radiators, but larger. First, take off the lock down knob, then put the hose clamp over the broken plastic housing and mark where the knob would screw through. Then remove the hose clamp, placing it on a sturdy surface and use a 5/16 drill bit to make a hole where the lock down know will pass through. Place the hose clamp over the plastic housing, insert the knob, tighten the hose clamp (but not so much that it restricts the tripod leg from moving) and you are done! I can send you pictures of the process and the final result. It saved me from buying a new tripod! I can be e-mailed at boingsplatplop@yahoo.com if you have questions.
-Spencer
Nov 07, 2008 | Photography
High hat for Libec T98C
Try the site www.transfilm.com they are a repair facility and reseller of used equipment and might have what you are looking for.
Aug 03, 2008 | Libec Photography
Libec THM20
The leg is slightly off the track, which is a curved piece which fits along the tripod support rail. If you're not careful when collapsing the legs you'll force the leg to go off-track like this.
Sep 07, 2007 | Libec ST30 Tripod
Libec T58 Tripod
Aug 21, 2007 | Libec LS-55 Aluminum Tripod System -...
Libec LZ-60 Tripod Logo
374 people viewed this question
Top Libec Photography Experts
pontelemon
pontelemon
TC CAMERA REPAIR.Com...
Are you a Libec Photography Expert? Answer questions, earn points and help others
