Question about Husqvarna 28cc Gas Line Trimmer
Bogs out when you hit the gas need fuel and throttle adjustments replaced pump and fuel lines! ITS AN E TECH 2 326R X series
  • 105 Answers
Your best to clean the carb,....use compressed air to clean the very small orifices,..a can of carb cleaner with the little plastic hose is needed too. sounds as though the main jet is clogged,..common symptom.
Posted on Jan 31, 2010
On Honda 2009 Shadow Aero, Engine "bogs down" at top of throttle. I've cleaned gas tank, carb, fuel line.
Have you cleaned the carb power jets and blown them and there passages out with compressed air?.
Sep 13, 2016 | 2008 Honda ST 1300
Losing power while driveing like
check the fuel regulator and fuel pump. also check the filter for the fuel.
Jan 14, 2014 | Ford Explorer Sport Trac Cars & Trucks
Cuts off when give it gas
There could be other problems than this but if an engine dies or bogs when excelerated then it is a lack of fuel. This is either from an accelerator pump in need of adjustment or clogged fuel injectors ( which with your truck is the problem). with fuel injection as seen on nwer cars and trucks the Throttle positing sender (TPS) could be bad or in need of adjustment.
Mar 06, 2013 | 1989 Chevrolet S-10 Blazer
2006 ttr 50 dies when giving gas
Hi, Jason and the usual suspects are:
1. Idle circuit and transfer ports clogged.
2. Air fuel mixture adjustment too lean.
3. Pilot jet clogged.
4. Faulty accelerator pump.
5. Float level too low.
6. Float bowl contaminated old fuel, water, dirt, rust, etc.
7. Float bowl vent or overflow tube clogged.
8. Fuel flow to carburetor restricted.
9. Intake manifold leak.
10. The gas cap is not venting properly or fuel tank venting system blocked.
11. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
12. Needle and seat stuck closed in the float bowl.
13. Multi carburetors not in sync.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
TTR50 bogs and dies when twisting throttle
http://www.r6messagenet.com/forums/general-motorcycle-talk/93609-bike-idles-but-dies-when-i-give-gas.html
YAMAHA TT R50E Owner Service Manual
OEM parts for Yamaha
Yamaha TT R50E Owner Manual
Nov 15, 2012 | 2003 Yamaha TT-R 125
Bogs out when i hit throttle
This is fuel starvation, clean/replace the fuel filter in the tank, check the fuel hoses for signs of cracks or fuel leakage, if this fails it may well be dirt in the carb itself, remove the carb, and clean /replace the fuel screen located under the carb pump cover
Aug 18, 2012 | Homelite Garden
Not getting fuel? runs for 5 min then stalls & it will start again in a couple of mins & do the same thing
Hi, Johndraonett the following applies to carbureted also fuel injected models and the usual suspects are:
1. Severely discharged or damaged battery, 9 volts or lower.
2. Failed alternator/generator and or voltage regulator.
3. Loose or corroded battery terminals and or cables especially the "NEGATIVE" cable, look for loose, corroded, or broken connectors inside the cable harness at "BOTH" ends.
4. Failed main circuit breaker or ignition switch, check for loose connections and continuity.
5. Failed system and or ignition relay, check for continuity.
6. Failed ignition coil, ignition/electronic module.
7. Failed CKP, CPS, CMP, MAP, TPS, or BAS sensor, corroded, loose or broken wire connector pins/sockets.
8. Throttle cables and or idle speed improperly adjusted hot idle speed should be 950 RPM to 1000 RPM.
9. Air/fuel mixture screw improperly adjusted.
10. Water or dirt in the fuel system, carburetor or filter.
11. Restricted, blocked or kinked fuel line.
12. Fuel tank empty.
13. Gas cap is not venting properly or fuel tank venting system blocked.
14. A failed fuel pump, pressure regulator and or fuel injectors.
15. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
16. Needle and seat stuck closed in the float bowl.
For more information about your issue and valuable free downloads that you need please visit the websites below. Good luck and have a nice day.
Engine stalls bogs with throttle 99 M900 Carbed Resolved
http://www.ducatimonster.org/forums/tech/187633-01-monster-900-stalls-undriveable-will-not-idle.html
Free Ducati Motorcycle Service Manuals for download
Ducati OEM Parts Fiche Lookup and Online Ordering
Ducati Maintenance
Jul 17, 2011 | Ducati Monster 900 Motorcycles
1989 Yamaha Razz stalls when throttle applied
Hi, Dstelte and the usual suspects are:
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Razz wont staY RUNNING Scooter Invasion
Razz 88 Bogs up hills and full throttle
Yamaha SH50 Razz 50 Scooter Workshop Service Manual 1987 2001 Download... $10
Yamaha RAZZ SH50L Owner Manual
Jun 27, 2011 | Yamaha Motorcycles
650 yamaha vstar 2006 stalls out when giving it gas
Hi, Donjkiii and the usual suspects are:
1. Idle port, transfer ports, slow air jet clogged.
2. Idle adjusting screw set too low.
3. Air fuel mixture adjustment too lean.
4. Pilot/slow fuel jet clogged.
5. Faulty accelerator pump.
6. Float level too low.
7. Float bowl contaminated old fuel, water, dirt, rust, etc.
8. Carburetor bowl vent line clogged/blocked/pinched.
9. Fuel line to carburetor kinked or pinched.
10. Fuel filter clogged.
11. Intake manifold leak.
12. The gas cap is not venting properly or fuel tank venting system blocked.
13. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
14. Needle and seat stuck closed in the float bowl.
15. Multi carburetors not in sync.
16. Faulty fuel pump.
650 idles on choke and dies on throttle in 650 Star Tech Forum
http://www.starbikeforums.com/forums/49-v-star/68346-650-starts-but-dies-throttle.html
Yamaha XVS650 Service Manual
YAMAHA XVS650 Owner Manual
Sep 07, 2010 | 2006 Yamaha XVS 650 Dragstar Classic
Have 1988 ramcharger 5.2 throttle body it starts hard just cranks till i press on gas then when i drive up the road when i hit he gas it bogs down any ideas
Start by checking to make sure that fuel delivery to the carburetor is good. The fuel pump might not be working well, or there could even be a problem with the fuel pickup tube in the gas tank.
Feb 26, 2010 | 1988 Dodge Ramcharger
Husqvarna 28cc Gas Line Trimmer Logo
473 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
