Question about Epson Stylus CX3200 All-In-One InkJet Printer
Epson printer ok thanks for the info inky. When you say a bit of paper might be left in by the flag, can i check for this and where is it you mean? It does seem to be behaving now but maybe that is because we have only been useing paper, but we most problems when printing cards. Thanks for you help.
  • Epson Master
  • 691 Answers
As you look at the front of the machine, toward the righ hand end of the feed path, close to where the head parks.
As the paper is fed in it hits a sensor flag to "hello I'm here" and if paper is pulled out backwards instead of forward the flag itself can tear off a small chunk and that will sit in the sensor area and cause jam errors.
You can take a sheet of card and by hand with the power off, feed it backwards through the feed path. Take great care towards the park area as the flag could get broken off if you hit it with the card. you try stuffing the hose of your vacuum cleaner down the ASF and sucking out any remnants also.
Posted on Feb 18, 2008
Want to clean my epson px660 after accidentally spilling some ink inside the printer
First - look for a YouTube video- a picturs worth a thousand words.The only real way to clean it is disassemble and clean and dry all parts, but since inkjet printers spray ink a lot of places in the printer normally, much of the ink may dry and cause no problems.
There are a couple of places that will need cleaning. You are going to be spraying water into the printer to do these steps, so I would remove the main circuit board, which is under where you will be spraying just to be safe. It is usually removable from back, but has a lot of cables atttached that need to be disconnected. Put the printer on a work table that can get inky, covered wth newspaper ( to catch any "drippings" that may sneak out-rather than onto the white carpet)
1.underneath where the printhead moves back and forth over the paper to make a print is a sponge pad to catch any o"overspray" and drain it to a big "diaper" in the printer bottom. If ink is all over this area- you can spray some water and let it drain into this sytem naturally. 2. the little rollers that hold and guide the paper will probably be covered with ink - spray them, soak up the inky puddles with paper towel, repeat and repeat. let everythng dry overnight, runnsome prints on cheap paper to soak the liitle inky places where you couldn't reach, but inky water is hidng,waitng for paper to come thru the printer- that's why we feed the cheap paper as a "sacrfice"
Sep 04, 2012 | Epson Stylus Photo Px660
I have canon 2900 and it having every time paper jam problem please help me
Analyse where paper jamming is happening? remove right left back & top covers..press door switch, shoot print command. Remove cartridge after paper jam, check upto where paper travel?
1. If paper jams with curl foldings in cartridge bank area..before entering the fuser assmbly..
# Teflon sleeve not rotation properly due to this paper not passing through it result curl foldings..Replace teflon sleeve..
2. If paper passed fuser assmebly little bit(near about 2-3 inches.
#Problem with paper out sensor/flag. clean sensor, check sensor flag movement & spring.
3. Check registration paper sensor located back side.
# while passing the paper, sensor flag has to act & once paper out it has to reach home,other wise paper jam error will appear.. check flag spring.
Aug 27, 2012 | Office Equipment & Supplies
I have an epson CX3200 about 4 years old. If I do
get a bright flashlight and look for tiny bit of paper, hair or other object.
If you see nothing to remove, try blasting the paper path with compressed air.
Feb 04, 2010 | Epson Stylus CX3200 All-In-One InkJet...
I have an lexmark 630 and keep getting the error "load MP feeder plain paper" thanks for the help chip loye chapelthrill@gmail.com charlesloye@gmail.com
Please follow my tips ,When you print your computer before you go to print properties.Setting paper layout choice paper source and enable MP tray then print ok.
keep your mind before print you must be insert paper in MP tray.
Sep 28, 2009 | Lexmark T630 Laser Printer
Error 13.20.00 on HP laserjet 5200 jam inside top
This is a common issue and most times a bear to repair. There is a sensor flag mounted on the paper feed assembly behind tray 1 which has a habit of either coming off or the spring which moves it back a forth comes out of its holder. In any case it is one of the worst repairs you have to do. Many items have to come off to get to it and getting that flag and spring on correctly even with the instructions is difficult. Usually what will happen is you get the 13.20.00 error on power up with no motor movement and when you open and close the top cover, the motor will move but the same error reappears. If you are lucky it is just a case of a shred of paper blocking the sensor flag from moving and worst case of the flag having come off. You will need the service manual and check the removal and replacment section on the paper feed assembly and play close attention to the 3rd page.
sometimes this error also appears if a wrong fuser is installed in ur printer that is not ur model number.... have it checked
thank you have a nice day
Aug 10, 2009 | HP LaserJet 5200tn Printer
Paper Jam in R300 Epson Stylus which I can't clear
Look for any debris, bits of paper, etc in the printer. You can try using a can of compressed air to blow out any debris inside. Should that fail, try a hard reset: Unplug printer from PC and power source, wait about 5 minutes and reconnect everything and see.
The paper jam error could be due to one of the following:
  • Check for paper in the paper tray
  • Check the size of the paper in the paper tray to see if it is the same as what the printer is set for.
  • Defective D-roller
  • Debris in the paper path
  • Gears not turning or broken gear
  • Defective paper tray
  • Broken input sensor flag
  • Defective input sensor board
  • Defective system cable 2
  • Defective system board
  • Exit Sensor flag (Fuser)
  • Exit Sensor board (Fuser)
  • System cable 1
If there is no bit of paper or debris stuck in the rollers, it would indicate something more serious, and in need of servicing. If your machine is under warranty, I suggest you take it back to the shop and get it replaced.
If your warranty has run out, then you'll either have to get it serviced or buy a new printer (whichever works out cheaper for you)
Hope that helps!
Jul 04, 2008 | Office Equipment & Supplies
C43sx both lights on
ok...start by removing the drivers from control panel, go to website and get new drivers, install them, try it again.
http://tinyurl.com/6qcpgy
Jun 11, 2008 | Epson Stylus C43SX InkJet Printer
Xerox PE 220
first with any jam message, identify if you have actually had any paper jam in it in the first place, especially if you are turning up to site and you're getting 2nd hand info. IE "oh no it just said that ...one day"
so assuming it actually had jammed paper in it that was removed at some point, find out where it was jammed...front or back. how it was removed...via front or back. note! many printers dont like having paper pulled out in the reverse direction to which the paper normally travels, this sometimes catches little flags and breaks them or pulls them out of position and the little photo sensor that is normally closed is then left 'electrically/optically' open so the printer sees this as a jam as soon as its finished booting up.
okay assuming you have gathered reliable info re the above.
check that area of the path for what looks like a small swinging flag, or maybe a little black 'U' shaped sensor that looks like it should have a flag in it.
remember the print will/can only say there is a jam if a sensor is stuck..open/closed or how it 'shouldnt be normally.
if you're out of luck you may find the pieces of a flag loose in the unit.
ideally they have a bit of flexability and just pop out.
BIG rule...dont force 'remove' jams. if it wont come out, contact someone with a bit of mechanical ability, even if they arent a printer tech, (like myself) then at least they have an 'intact' unit to work with so they can see how its supposed to work and just pull it apart to clear the prob area.
ok...so assuming you've found the area, if the flag is broken i wouldnt try making bits up to do the job, timing is critical, unless you can glue it back together exactly right then dont bother, you'll likely get timing related jam messages. just contact the manufacturer, see i you can get a part number. it may cost you a few bucks for a bit of plastic but its the best way trust me.
HP, lexmark, and fuji xerox i have found pretty good with parts down to a small level. some other brands i wouldnt touch with a barge pole.
after all this. most jams are in the fuser and most people are rough as guts and usually break something in the fuser by yanking it cos they're angry.
most fuser can be sort of pulled apart into sub components (although its not expected in my industry) so if you have an intact fuser but its got a heavily 'fanfold' paper in it so tight you dont even know its there, dont dig it out with a screwdriver, if you score or scratch the surface of the rollers then you done your money there. better to look at it for a bit, try to work out how to loosen it apart and remove the jam, inspect the rollers for scratchs or damage, andreassemble it.
(15 years repairing this gear, the methods are pretty much similar thinking for most printers when physical issues are the prob.) best of luck. - keith
May 14, 2008 | Xerox WorkCentre 220 All-In-One Laser...
Epson Cx3200 paper jam
Then there is something stuck in the paper feed path which is holding up the sensor flag making it think there is paper in it.
Or maybe the sensor flag has been broken off by yanking paper out the wrong way when it gets stuck.
Get your vacuum cleaner and stick the hose down the paper feed path and see if it suck out a push pin, piece of paper paper, fur ball, eraser, coin, toe nail, false eye lash etc (all of which I have removed from machines with "paper jams")
Dec 12, 2007 | Epson Stylus CX3200 All-In-One InkJet...
Alignment
Check the paper size in printers properties, it may have altered. If not disconnect printer, remove printer driver from add/remove programmes. Re install driver and reconnect printer when prompted. It should now be ok
Jan 30, 2007 | Epson C64 InkJet Printer
Epson Stylus CX3200 All-In-One InkJet Printer Logo
51 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
