Question about Vizio VX20L 20 in. LCD TV
I have a Vizio 37 inch lcd tv. It works fine from
I have a Vizio 37 inch lcd tv. It works fine from the cable box, but when I try a DVD the picture will fade out to black after about five minutes. The picture comes back if I hit the volume or any button on the cable remote, but will fade out again after a couple of minutes. If I switch back to the cable box, it will then also fade out. I have only been able to stop it if I go through a complete tv set up, but it will do it again if I try a DVD again. Does this have a screen saver or power saver in the set up?
  • msyaros Feb 01, 2010
    I have a Vizio 37 inch lcd tv. It works fine from the cable box, but when I try a DVD the picture will fade out to black after about five minutes. The picture comes back if I hit the volume or any button on the cable remote, but will fade out again after a couple of minutes. If I switch back to the cable box, it will then also fade out. I have only been able to stop it if I go through a complete tv set up, but it will do it again if I try a DVD again. Does this have a screen saver or power saver in the set up? This is a new set. It only does it when I first try to view a dvd. I can correct it by going through a full set up, but will do it again at a later date when I try a dvd again.
  • 4 Answers
Well It depends on what you mean by fade out, Fades out completely or just darkens enough to be annoying? I just bought this exact tv and mine also fades, I changed the preset picture function to "game" mode and the fading stoped.
Posted on Feb 17, 2010
  • 566 Answers
Hi msyaros
In order to have data`s specific to model , i would need the model# written on the back of the tv set.
Be waiting for your reply
Posted on Feb 01, 2010
  • 3,037 Answers
I'm not sure how electrically inclined that you are, but you need to open up the set and measure the DC voltage on the backlight inverter board to see if you have the 24vdc after the picture goes out, if you do have the 24vdc, then the problem is in the inverter board, if 24vdc is gone then it will be in the power supply which then needs to be replaced. You should be able to find the parts needed at shopjimmy.com
Let me know how this works out for you and remember to be careful as there are many dangerous components in the set when there is power running to it.
Benjamin
Posted on Jan 31, 2010
  • Benjamin Patri
    Benjamin Patri Feb 01, 2010
    There is no easy fix on this tv, the problem is internal and someone with electrical expertise will need to look at it unless you can return the tv and exchange it. I have said exactly what needs to be checked on the tv. The tv screen is lit by a backlight and this backlight is not staying lit and there are two possible parts that can cause this light to not stay lit up.
    If you have questions on anything else with this tv, please let me know.
Vizio E470VLE HDMI inputs not working
its the antanna don't go on your roof you probs bumped it
Aug 31, 2016 | Vizio E470VL 47 in. HD-Ready LCD TV
42 inch vizio has picture (direct tv) but no sound. Tv is not on mute.
Did you check the RCA AV Cables? The ones with the red, white yellow?
What is the connection you have from Direct TV box to your TV. You might want to start on that.
It might probably as well related to any of the remote controls settings. Either of the Direct TV control or TV Control.
1. Check the cables
2. Check if there is any function on the Direct TV remote that will turn off the sound
3. CHeck the Vizio TV Menu Settings.
4. Try with other component such as DVD to discard the possibility of malfunctioning VIZIO Speakers.
Vizio offer a good customer service if still under warranty.
God Bless You!!
Feb 14, 2011 | Vizio VW37L 37 in. LCD HDTV
My Vizio LCD TV screen fades to dark. Sound stays on.
I w having this same issue when watching a Blu-Ray disc. I found it to be dependent upon what picture mode the TV was set to. By this I mean certain picture modes would cause the TV to dim during dark scenes of a movie. Changing the picture mode helped a lot.
Feb 28, 2010 | Vizio VW42LF 42 in. LCD HDTV
Vizio 37" tv. sound loud enough on satellite and antenna. when hooked to dvd or blue ray, can hardly hear it even at maximum sound
I have a similar problem with my new 37 inch vizio. Watching on cable and the sounds gets lower and lower until i can hardly hear it. Must switch channels back and forth to restore the sound level of a particular channel. Does anybody have a solution ?
Feb 13, 2010 | Vizio VW37L 37 in. LCD HDTV
My lcd tv makes a humming noise
My 37 inch vizio did the same thing. go to your menu screen on the tv and go sound. My tv has an option to turn speakers on/off. Once I turned my speakers off and the back on again everything worked great. hope I helped! if I did please let me know! youtube.com/xniax1
Mar 21, 2009 | Vizio VW37L 37 in. LCD HDTV
Connecting COX DVR and Phillips DVD to Vizio HD TV
we connected the cable box to the coax connector while our philips dvd went into the HDMI1 connector, and we got both working fine and dandy
Jan 10, 2009 | Vizio L32 32 in. LCD HDTV
No audio output hooked up to my Vizio 37" LCD
You need to select digital out in the menu of the dvd player..
Jan 01, 2008 | Nakamichi DVD-10S
Vizio GV42L LCD TV screen black when turn TV on first time
If you are using a set top box this might be caused by turnig the box on at the same tie as you turn the tv on or slightly after you turn the tv on.  If you are using compnent or HDMI inputs the set needs to see the signal as it is turned on to know what formt the signal is in.
Oct 15, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
LASONIC DVD PLAYER NOT WORKING WITH COMCAST BOX OR SOYO TV
you have to plug everything to the tv. only thing them are good for is recording to some other unit. like dvd recorders
Mar 05, 2017 | Lasonic DVDP | DVD-7050 5.1CH
Vizio VX20L 20 in. LCD TV Logo
1,106 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
