Question about D-Link DIR-615 Wireless Router
We had a power outage, and now I can't find my original info to reset our DLink. We don't have a secure connection and I can no longer print wirelessly. Can you help?
  • 2,260 Answers
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Once you open the set up page, you will find the option to make it secured
Click Here for step by step instructions
Posted on Feb 01, 2010
I have a dlink n150 router dir-600L. i tried to configured it and changed the SSID and network key. the problem is, i cannot connect it to the wireless connection even though the network appears on my
Did you enter the security key (password)? It may be your laptop? Try resetting the D-Link to default settings and connecting to the laptop. They reconfigure the SSID and Security Key. Write down the info for future use. Here's a user Manual: http://www.dlink.com/uk/en/home-solutions/connect/routers/dir-600-wireless-n-150-home-router
Jan 24, 2013 | D-Link DIR601 WirelessN 150 Home Router...
I'm trying to reload my dlink wb1310 but I don't have the security key.
Most router have a reset in the back. Hold it in till it cycles. This will clear ALL custom settings. Then use the defaults.
Jan 08, 2013 | D-Link Computers & Internet
Dlink DIR 615, network name changed, won't accept password
It appears your brother has changed your wireless router settings.
You can reset the Dlink back to the default settings by -
Power off the Dlink and press and hold the RESET button on the back of the Dlink and the power on the Dlink. Hold the RESET button for 5 secs. until the LEDs flash at the same time.
Connect a LAN cable from the computer to the Dlink. Open a browser and enter the Dlink's configuration URL
http://192.168.0.1
Default login = admin
PW = blank (just press Enter)
You can now change the admin password and set up a new passphrase (ie encryption)
For details on how to secure your wireless from unauthorized access, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
May 19, 2010 | D-Link DIR-615 Wireless Router
Lost connectivity after power outage
If this is a printer WITHOUT WiFi or bluetooth - and you have it connected to another computer (Print Server) via a USB cable - you need to make sure you can see that computer from the other computer you are printing from. Use the network explorer - if you can see the computer and the printer you should be able to print to it.
Sometimes, it may be secured with a password. I found if I can map a shared drive from my laptop to my print server then I can print again. So see if you can see the printer and printer server computer from the other computer. If so you may need to add that printer again to you printer list.
May 01, 2017 | Zonet ZPS3611 Print Server
Dlink router is not connecting to the internet
Check the lights on the router to make sure both out going and incoming are on.
Manual link below in case that helps
ftp://ftp.dlink.co.uk/di_broadband_gateways/di-524/di-524_manual.pdf
If not both on contact broadband supplier as IP for router may have been "altered" and will need resetting their end.
Not unknown for an outage to be proceeded by a "spike" which can blow unprotected items.
Jan 24, 2010 | D-Link DI-524 High Speed 2.4GHz (802.11g)...
Lost ip/connection on Dell 1720dn
try resetting the "print spooler"
  1. start
  2. control panel
  3. admin. tools
  4. computer management
  5. services and applications
  6. services
  7. scroll down till you see "print spooler"
  8. left click once
  9. "restart"
Jan 06, 2010 | Dell 1720dn Laser Printer
After power outage, router will not connect. Cable modem connected directly to PC works, but why not the router? Is it a setting?
Yes.
It is possible that the router actually got reset in the process.
Dlink setup is 192.168.1.100 I believe. It should say in the manual. If you do go through the setup wizard and it still won't connect, then the power outage may have affected either the firmware or the hardware.
Aug 08, 2009 | D-Link AirPlus DI-524 Wireless Router
Hi, I connected the printer server GPSU01U to a dlink 524
When you connect the print server to the router, does the lights lit? have you tried to reset the print server (reset button is on the side of the print server). press the reset button for 10 seconds, after 10seconds, while still holding the reset button power cycle the print server (unplug then replug the power cable) then release the reset button. Try to find the print server using the PS admin.
May 17, 2009 | IOGear (GPSR01U) Print Server
A couple of days ago I was trying to log onto our laptop and found that we lost our connection to dlink. After I went into the dlink icon on my computer I did something?? don't know what!!! but now able to...
Hi Mike,
First off, I'd reset the router in order to gain access. On the back of the router, you'll find a little hole, that if you take a paper clip and un roll one end, you can use that to push into the hole. Hold the reset button in for 10 seconds. This resets the router back to the manufacturer's defaults. Once that is done, Open up a browser and type in the following IP address in the address line. 192.168.0.1 and the user name is admin, and leave the password blank. This will get you into the router, so you can setup your connection again.
Good Luck and dorn't forget to leave a rating.
Thanks
Mark
Apr 20, 2009 | D-Link DIR-625 (790069292637) Wireless...
How do I secure my dlink wireless connection?
Type 192.168.0.1 (you can type the router address if you have changed) and enter on browser's addressbar. Router's interface will appear.
Click on SETUP and Click on the WIRELESS SETTINGS at left side. on the page you will see the option of WIRELESS SECURITY by drop down menu you can choose the Security mode that you wish. here is the link for the emulator
http://support.dlink.com/emulators/wbr1310_revB/wireless.htm
Please post your question if you need further assistance
Good Luck
Jan 19, 2008 | D-Link 802.11g Wireless Router WBR-1310...
D-Link DIR-615 Wireless Router Logo
65 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
