Question about Belkin (F5D7230-4) Router (587009)
F5D7230-4 Router won't support >1 wired ethernet connections
Router works fine most of the time with one wired and one wireless connection. When I plug in an extra PC I lose connection on both wired connections. Both are running XP. Any ideas?
My first suggestion would be to shutdown the modem, router, and XP PCs. Then power up the modem, router, then PCs (in that order) pausing about 20 seconds between powering each unit.
Good luck.
Posted on Feb 18, 2008
I have wireless Internet! I have a laptop, I tried to connect to it~ It will connect to the router, but won't connect to the Internet! Help!
How many wired and wireless computers do you have ion the network.
Do you have any wired computer ?
Connect your laptop to the router with the Ethernet cable and try to access Internet. See if the wired connection is working or not.
If the wired connection is working then I think you will need to check the wireless settings of the router and the laptop.
Try following websites
Router setup
How to connect to the wireless network
May 15, 2012 | Computers & Internet
Want to connect aDI-604UP wired router to a DIR-615 wireless router to use as a printer port wirelessly
Hello Richard.
For this, you have two types of connection
1. LAN_LAN (ethernet to ethernet) -->wireless router is acting as a switch
2. LAN_WAN (ethernet to internet)-->wireless router is acting as a wireless router
in this case, you need the LAN_LAN connection
Physical connection:
plug an ethernet cable from the ethernet port on the wired router and connect the other end of that cabl to the ethernet port on the wireless router
Configuration:
log-on to the setup page of the wireless router, do this while the wired router is turned off.
-open your internet browser, type 192.168.0.1 on the address bar. Then type the username & password for the router ( default admin as the username, password : ).
Under the setup tab, click manual configuration. Then click network settings, change the router ip address to 192.168.0.5 & disable the DHCP server. save the settings. Just personalize the wireless network.
Hope this helps.
Sep 15, 2010 | D-Link DI-604 4-Port Cable/DSL Router...
Wired connection randomly drops
Since the wireless works fine on your router, then it is possible that there is a problem either on your ethernet cable or on the port of the belkin router.
Try a different ethernet cable. (Ethernet cable is the one that is connected from your computer to the router.) If you don't have a spare cable, you can directly connect the computer to the modem, just to isolate the issue and determine if it is the cable or the computer itself.
If you have determined that the cable is working fine, then try a different port on the router.
I hope this helps!
Jul 24, 2010 | Belkin F5D7234-4 Router
D-link G524-T router; this works fine with a
If you get the same speed on all three computers, I'd recommend replacing the router. I can't imagine any possible configuration setting that would cause a router to communicate at only 10KB over a wired Ethernet channel.
Nov 25, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
Wireless router - establish wired connection with desktop PC
You are right, cable connection is more secure. The steps are:
1.) Connect the PC to the router with a crossover cable.
2.) Once connected, try to see if you are in the network. If you are, then you are ready to connect to the net.
May 04, 2009 | Computers & Internet
Can connect via Ethernet but not wireless
well its unfortunate,,intel 2200 WLAN cards{oldest cards launched till now by intel} face this problem,the problem is with the differnce of wireless standards between the router and the wireless card.go for a wireless usb adapter,,install it and it wud work absolutely fine
Apr 12, 2009 | Intel PRO/Wireless 2200BG 802.11g/b
Connecting Laptop wireless and Desktop wired to the router
Do you need to see the desktop or just share folders from each other? If the latter then you need to do the following:
Use Windows Explorer and select a folder you want to share. Right click and select sharing and security.
On the sharing tab click on Share this folder. Enter a share name ( I like to enter the PC name _folder name; Rick1_Downloads)
Click on Permissions. If your ok with everyone using the PC's and Laptops having access then highlight Everyone and click on Full Control.
Do this on each PC and Laptop.
That should be it or darned near close.
Apr 10, 2009 | D-Link AirPlus DI-524 Wireless Router
My Netgear WPN824 v2 router won't work with my ps3?
hi, try setting a predefined setting
Ip adress : 192.168.1.200 ( or any number not used by pc )
Dns : 192.168.1.1
Gateway : same as DNS
Feb 28, 2009 | NetGear RangeMax WPN824 Wireless Router...
1 of the 2 computers cant get online
Pleaase check if the PC connects when plugged directly to the DSL or cable connection whatever you have without the router in between. That would ensure the functionality of the ethernet card on the other pc.
Feb 10, 2009 | NetGear MR814 Wireless Router
Connection to iMac not working
the easiest way is hard wire a windows laptop and use the CD that came with the router.
Oct 13, 2008 | Microsoft Broadband Networking MN-500...
Belkin (F5D7230-4) Router (587009) Logo
94 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
