Question about Pioneer ECS KT600A SKT A W/SATA/400FSB/6CH AUD (KT600A10) Motherboard
My computer will not boot up, i.e I get no video although my hard drive spins but there is no disk activity. I have a KT600A motherboard with a AMD Athlon processor. Could my motherboard have gone bad? Thanks in advance Keith
  • 728 Answers
I don't know how computer technical you are, but it sounds like you know a thing or two about them. So here's the best way to find the problem:
There could be many things that could stop the board from fully booting, Determining what is wrong is like detective work. What I do, is open up the case and take everything off the board to start. Then add the minimum to start a board to see if it will start. That's one drive (cd, hard drive or otherwise) the CPU, a graphics card (only if required) and one bank of memory. (which is not required, but it helps avoid beep codes) Also, make sure you have your pin's set on the board absolutely correct, or that could be your problem to begin with. If your going to load a IDE drive, make sure you set your pin setting correctly on it, meaning the drive (IDE or EIDE) your putting on the board is set to Master, or Cable Select if your using the cable placement method.
Now, turn it on, and you should get the power supply on, and the cpu fan going. If they start, then make the next step to have the single drive be your hard drive, and see if it boots. If it boots, then great, open Bios and make sure Bios is reading the board and all things are fine with it. If so, what ever you put on next make sure it one at a time so you can identify what it doesn't like.
In the case where the CPU or power supply don't power up, it's then either one of the six elements. The CPU, Power supply, Ram, Drive, graphics card (if required) or the motherboard.
The next step is to replace each one of the first five, starting with the Ram Chip, put another like chip in and see the results. Then do the same thing to each of the remaining 4 components, the graphics card (if required), then the drive(cd, hard drive or otherwise), on to the CPU, and last the power supply. Hopefully something will show it's ugly way to make a change. Also, on the drive (IDE, EIDE or SATA) , try a different cable to make sure it's not that.
Now If no changes happen after all that, then I take it one step further and usually get a like (doesn't have to be exactly the same, but a board that the components can be tested on) motherboard that I can test the first four, and make sure that they really work. If after that and you have tested all of the components and they all work, then it's save to say you have a bad Board my friend. It's a lot of work I know, but it's the sure fire way of finding out what isn't working.
Good Luck,
Mark
Posted on Feb 01, 2010
I'm installing a biostar a78ldm2s and everything turns on but I keep getting a read disk error on the hard drives that I try to use. I've tried 5 different hard drives and get the same result.
Hello here you can download a manual:
http://www.biostar-usa.com/app/en-us/support/download.php
By entering the right mainboard number.
Try to set the bios to factory settings.Load default settings.
And set the boot order: first boot device:dvd, second, the harddrive.
If you are using a IDE drive make sure its set as master.
A sata drive does not have that function.
Make sure the windows disk is clean and without scratces.
Here is a youtube video that shows you how:
http://www.youtube.com/watch?v=sMc5ukMguEo
Good luck
Nov 04, 2012 | Biostar A780L Motherboard w/ AMD Athlon X2...
I have a problem with my m/b k7som+ 7.5c. When I press the pwr button everything seems ok, all fans are working properly and I also hear the HDD spinning sound. However there is no POST beep or anything...
There are a few procedures you can possibly try before replacing components.
I HIGHLY recommend you unplug power while trying these steps
1) Unplug power and remove CMOS battery (usually a small silver circular battery) on motherboard for 1 minuted then reinstall battery and see if it boots up.
2) Re-seat all RAM memory chips. If it doesn't help, then try booting the system 1 memory chip at a time, to rule out a bad stick of RAM
3) If you have a separate video card (not onboard video) then try re-seating it
4) unplug both data and power cables to all internal components (hard drives, CD-Roms, Floppies, etc) and also internal cards and see if it boots. If it does then reconnect one device at a time til you find the culprit
That's pretty much all you can do without swapping out parts.
I hope this help and I wish you luck!!
Regards
Mar 07, 2011 | EliteGroup V7.5A (K7SOM+ V7.5A)...
About disk boot failure
Hi!
Disk boot failure means that your BIOS can't find the master boot record of your computer which resides in the hard disk or a floppy disk.
This indication means that your hard disk drive is not detected by your BIOS or their is no operating system installed with it.
Have a nice day!
Jun 02, 2010 | Foxconn WinFast K7S741MG Motherboard for...
Can i plug a IDE dvd-r & SATA drive together? my new pc wont recognize the hard drive
The IDE DVD and the SATA hard drive can be installed together in the desktop computer, BUT not on the same data cable, they have different types of data cables and disk controllers.
You need an IDE disk controller and a SATA disk controller, the late model motherboards have both types of controllers on the motherboard.
Dec 25, 2009 | EliteGroup ECS A780GM-M3 AM2+ AMD 780G...
Disk boot failure insert system disk
Is it recognises Hard disk or not?
reply
i will try to solve u r problem
Jun 25, 2009 | ASUS K8V-MX Motherboard
Adding harddrive
hi my name is wesley. you need to make sure the hard disk you put in is set to slave otherwise it clashes with your other hard disk and will not boot. you will see a jumper on the hard disk you can set to slave instructions is on the hard disk you just have to change witch two pins the jumper is on.
Jul 08, 2008 | Foxconn WinFast K7S741MG Motherboard for...
Disk boot failure when I installed a new SATA DVD writer
Start the system & enter you're bios & use you're manual to help guide you on this. Go to the Boot section of the bios. You can set the boot order. Normal boot order is like this:
1st boot device, floppy disk (if one is connected).
2nd boot device, cdrom drive
3rd boot device, hard drive
(Drive the has windows installed on it).
Save & exit the bios. The system will restart & windows should load. If it does not, than you picked the wrong hard drive.
Mike
Jun 17, 2008 | Foxconn (755A01-6ELRS) (K8S755A6ELRS)...
NTLDR is missing in my computer
firstly check your bios settings
the pc may be trying to boot from another source rather than the hard disk. (cd rom maybee)
if thats not the case
you can set the pc to boot from the windows cd and go thro the recovery consol
  1. When prompted to press any key to boot from the CD, press any key.
  2. Once in the Windows XP setup menu press the "R" key to repair Windows.
  3. Log into your Windows installation by pressing the "1" key and pressing enter.
  4. You will then be prompted for your administrator password, enter that password.
  5. Copy the below two files to the root directory of the primary hard disk. In the below example we are copying these files from the CD-ROM drive letter "E". This letter may be different on your computer.
    copy e:\i386\ntldr c:\
    copy e:\i386\ntdetect.com c:\
  6. Once both of these files have been successfully copied, remove the CD from the computer and reboot.
the easyest fix for you is to re-install windows
this file is the nt leader file
hope this helps
Shugster
Nov 04, 2007 | MSI AMD ATHLON-64 939 PIN MOTHER BOARD...
Foxconn 6100K8MA-RS Motherboard
Hi You need to make sure that your boot sequence sets to boot from hard drive first. Also, make sure that the hard drive sequence has the hard drive enabled. If this does not work, then let me know so I can give another suggestion.
May 30, 2007 | Foxconn 6100K8MA-RS Motherboard
Pioneer ECS KT600A SKT A W/SATA/400FSB/6CH AUD (KT600A10) Motherboard Logo
160 people viewed this question
Top Pioneer Computers & Internet Experts
Computer Links
David
David
Are you a Pioneer Computer and Internet Expert? Answer questions, earn points and help others
