Question about Lexmark X5470 All-In-One InkJet Printer
Lexmark x6570 paper continues to have feed problems after clearing jam.
  • Official Brand Answer
  • 3,344 Answers
Hi, In the following link are some tips and a good document on how to clear and how to check if there is something blocking the way of the paper and how to properly load the paper to avoid paper jams.
http://bit.ly/bdk0WJ
Posted on Feb 01, 2010
It wont feed the paper it keeps say paper jam but the paper is not even going in
Lexmark Impact S301 Printer won't take the paper -
printersquestions.com/lexmark-impact-s301-printer-wont-take-the-paper....
Dec 19, 2013 - Feeding paper is the first step of printing materials. However, what will you do when the Lexmark Impact S301 Printer won't take the paper ...
Paper Jam Troubleshooting on 2009 Printers - Lexmark
support.lexmark.com/index?pmv=print&page...en...
LexmarkLexmark Impact S301, Lexmark Impact S302, Lexmark Impact S305 ... When troubleshooting paper jams on Lemark's 2009 printer models, make sure you also ...
[PDF]Solving paper feed problems - Lexmark
www.lexmark.com/publications/pdfs/w820/eng/prfedprb.pdf
LexmarkUse the following table to find solutions to paper feed problems you are ... For detailed instructions on clearing paper jams, see Clearing print media jams.Missing: impact ‎s301
How To: Clear a Paper Jam on a Top Feeding Lexmark ...
? 2:30
https://www.youtube.com/watch?v=H1-J1xDbDsY
Jan 14, 2016 | Lexmark Impact S301 Wireless All-in-one...
Lexmark 705 adf jam
If your adf is jamming while it is feeding it might be due to a broken hinge. Check out this video.https://www.youtube.com/watch?v=GaS0oKcreBo
Jan 29, 2012 | Lexmark Prevail Pro705 Wireless All-In-One...
201.08 paper jam The paper continually jams - I clear it and hit the continue but it jams over and over. there is nothing stuck in there!!
201.08
Description
Exit sensor is never made.
Possible causes:
• Improper loading of manual feed slot
• Paper wrapped in fuser
• Damaged paper exit sensor or paper exit sensor flag
• Damaged fuser autoconnect
• Faulty fuser DC cable connection
• Faulty fuser
• Faulty system card
Action
• Check for anything in the paper path that might cause the paper to jam.
• Load paper in the manual feed slot.
• The fuser exit sensor may not be functioning properly.
Jul 14, 2011 | Lexmark C530dn Laser Printer
4TH LIGHT FROM THE TOP KEEPS COMING ON LEXMARK E232
What this light sequence means that the printer has a paper jam.
When a paper jam occurs, the printer stops and the operator panel's Paper Jam light and Continue button lights come on. Press and release Continue twice quickly to display the specific secondary error paper jam light sequence.
How to clear Paper Jam
Press Continue button twice quickly to see the secondary error code.
To get the secondary error codes
When the Error light (!) and Continue button lights are both on, a secondary error has occurred.
When the Paper Jam light (4th light) and Continue button lights are both on, a paper jam secondary error has occurred.
Press and release Continue button twice quickly to display the secondary error code light sequence.
Press Continue button to resume printing once all the jammed pages are cleared from the paper path.
We recommend that you clear the entire paper path when a paper jam occurs.
To clear a paper jam:
1 If you are feeding paper from a tray, remove the tray, and then remove any jams.
2 Open the front cover and remove the print cartridge assembly.
NOTE: Do not leave the print cartridge assembly exposed to direct light for an Extended period of time. Extended light exposure can cause print quality problems.
3 Remove any jams in the area behind the print cartridge assembly.
4 Lift the flap at the front of the printer and remove any jams beneath the flap.
5 Open the rear exit and remove any jams.
6 After you have cleared the jams, reinstall the print cartridge assembly, make sure all printer covers and trays are closed, and then press Continue button to resume printing.
NOTE: The printer reprints the pages that caused the paper jam.
Jun 30, 2011 | Lexmark E232 Laser Printer
Continues to report paper jam even though no paper; reset does nothing.
Try to look for the sensor as some tiny paper shreds might be blocking it which causes the system to detect a paper jam.
Also look for tiny pieces of shredded papers that might got stuck between the rollers.
Aug 01, 2009 | Lexmark X6570 InkJet Printer
X6570 paper jam message won't clear even after paper removed
I had the same problem. What i figured out wich said nothing about it in the book was to.
- turn off printer
- Dbl make sure there is no jammed paper
- put at least one sheet in the feeder like normal
-then turn printer back on ,when printer is going through its start up steps it will pull the paper through that you loaded in the printer and should clear the paper jam message.
It took me a day and a half to figure that one out, so some how post a reply if it works for you so i can pat myself on the back.
Thank you -PURNRG
Jul 03, 2009 | Lexmark X6570 InkJet Printer
My Lexmark X6570 shows paper jam I have performed all the normal orfices for paper and it is clear and the check mark will not clear
I called the Manufacturer and they had me make 5 or 6 different tests and concluded it was a hardware problem. They are replacing the unit.
Thank you for the attempt, but I do not believe you should charge if you can't fix it or have the answer.
Nov 15, 2008 | Lexmark Office Equipment & Supplies
Lexmark X6570 printer - Cleared paper jam. No paper scraps visible anywhere in printer. Continue to get error message to clear paper jam and then press the "check" button. Does not reset. ...
Ok, the paper jam could be due to one of the following:
  • Check for paper in the paper tray
  • Check the size of the paper in the paper tray to see if it is the same as what the printer is set for.
  • Defective D-roller
  • Debris in the paper path
  • Gears not turning or broken gear
  • Defective paper tray
  • Broken input sensor flag
  • Defective input sensor board
  • Defective system cable 2
  • Defective system board
  • Exit Sensor flag (Fuser)
  • Exit Sensor board (Fuser)
  • System cable 1
First try a hard reset - unplug printer from power source, wait a minute and replug. If it still does not work, uninstall the driver, reboot PC and reinstall (or download latest version from lexmark.com.
If there is no bit of paper or debris stuck in the rollers, it would indicate something more serious, and in need of servicing. If your machine is under warranty, I suggest you take it back to the shop and get it replaced.
If your warranty has run out, then you'll either have to get it serviced or buy a new printer (whichever works out cheaper for you)
Hope that helps!
Nov 11, 2008 | Office Equipment & Supplies
Paper jam
There is an end of form sensor in the paper path that is likely stuck or the rollers cannot turn due to some other Jam. The machine will throw that message if those two mechanisms cannot function. Look for debris in the printer - give it a good shake.
Sep 22, 2008 | Lexmark X6570 InkJet Printer
Lexmark X5470 All-In-One InkJet Printer Logo
158 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
