I have a Frigidaire Crown Series top loading washer that is over-filling. First, we had troubles that it wouldn't spin water out. We checked the hoses and put everything back together and now it over flows when filling up. Model # FWSB34RGSO; Serial # XC93445141. Also, same kind of dryer and it's pinching the clothes and burning them. What do you think? Front glides? Thank you!!
  • 1,531 Answers
Try and clear the pressure switch there may also be a reset on it sometimes just moving the pressure switch to different setting will fix it.there could be a small amount of foreign material in the rubber hose that comes off the switch to the tub you can also look for any break or hole in the rubber hose.as for you dryer as yet sound like you need to rplace the glisdes and the felt around the drum
Posted on Jan 31, 2010
Washer won't fill with water
Hi Allen, this is JK. I see that you are having trouble with your washer (FEX831CS) not spinning or filling with water. For the washer not spinning, check the drain hose length and make sure there are no restrictions. The concern could be with the timer or the drain pump. For the washer not filling, I would check the water pressure, pressure switch and the water inlet valve. If all of these suggestions pan out and the problem still persists, think about what may have happened prior to this occurrence. For instance, did you notice any error codes, odors, or other strange functions prior to this issue? If you are still having these issues and can think of anything in particular, please feel free to reconnect.
Mar 23, 2014 | Frigidaire FEX831CS Top Load Stacked...
My frigidare crown series washer won't drain the
Remove the back cover and later the drum drain pipe. If a filter is present, dismantle and clean out. Most often the cause is a object that that is hindering the operation of the spinning pump. Dismantle and clean the pump.
Feb 29, 2012 | Frigidaire Washing Machines
Crown series washer shakes violently on spin cycle
When you put on the clothes inside the spinner make it equilibrium to prevent shaking violently.
Jan 29, 2012 | Frigidaire FWSB5700DS Top Load Washer
The washer will drain but not completely ..leaves a litlle bit of water in machine
Make sure the spin is working. If its not working you wouldn't know it since it spins during the middle and end of cycle.
If not check lid switch
Thank you for using fixya
Leo Ponder
Please rate me if this helped.
Jul 17, 2011 | Frigidaire FEX831CS Top Load Stacked...
My Frigidaire Crown Series top load washer was agitating but would not spin. It did drain the water. The lid lock did lock when it was in the spin position. It was smelling like burning belt so I...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Mar 20, 2011 | Frigidaire Washing Machines
Water will not drain and washer will not spin
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Sep 01, 2010 | Frigidaire Gallery Supreme Series...
Kenmore Series 70 Washing Machine - won't drain water
WHAT IS WRONG WITH YOUR WASHING MACHINE?
small_11_21.jpg For a detailed Washing Machine illustration, click below.
redarrow.gif Top Load Maytag Style
redarrow.gif Top Load Whirlpool Style
redarrow.gif Top Load GE Style
redarrow.gif Front Load Maytag Style
redarrow.gif Front Load Frigidaire/GE/Kenmore Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Some problems that can occur with your top-loading washing machine are:
There's an error code on the digital display
It doesn't work at all
It won't drain
It doesn't spin
It doesn't agitate
It's noisy
It leaks
It's off balance
There's no hot water
There's no cold water
It's slow to fill
There's no water at all
The clothes are wet after spinning
The cycle doesn't advance
There's no delicate or regular spin or agitate
It's overfilling
It's underfilling
The water temperature is incorrect
Hope this may help;
DON'T FORGET TO RATE:
Aug 10, 2008 | Washing Machines
Frigidaire stackable will not stop filling with water or agitate.
yes unless pressure switch(water level switch)detects proper fill level wash will never start agitating some washer will not spin if switch does not detect empty tub
Jun 02, 2008 | Whirlpool LTE6234D Top Load Stacked...
Washing Machines Logo
160 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
