Question about eMachines ET1641-02w (PT.NA60X.001) PC Desktop
I moved my computer. Hooked it back up and now the side speakers do not work. They power on but no sound . tried several connections. USB is plugged in and the green to green connection is in. checked all other volume controls.
  • 561 Answers
Hi
Please can you advise if you have 2 sound cards installed
You will know this by looking at the back of the computer, the sound card wil have 3 ports coloured Purple/Dark Green and Light green
Your speaker connection needs to go into the light green and will have a symbol above it like this ))(left arrow)
If there are 2 sets of ports then try one and if that fails try the other if there is only one plug your speaker conneciton into the light green port
Regards
Posted on Feb 10, 2010
Craig wireless portable speaker cma3561 won't charge battery
Batteries are holding back the 21st century. I have the older model of this and my battery went bad very fast. Now I have to keep it plugged in and not just any usb port will work it has to be a usb power supply of at least 2 amps. I keep mine in a 2100mA usb source.
Dec 25, 2013 | Craig Audio Players & Recorders
There is no sound from my speakers green light on
you have to install sound driver software to that supports your pc motherboard... then restart it will work...
Oct 10, 2010 | Harman Kardon HK206 Computer Speakers
My speakers are not working
Step 1
If no sound is coming from the computer, start troubleshooting your problem. Make sure both your computer and speakers are plugged in, have power, and are turned on. If the speakers are plugged in but do not appear to have any power, plug them into a different outlet. If you are using a power strip and this is case, replace the power strip. Some speakers are self powered and use a USB cable to supply power. Make sure that the USB cable of your speakers is connected securely to the USB port of your computer.
Step 2
Once you have verified that you have power to your speakers, test the sound again. If you still do not have any sound, make sure the cable connecting the speakers to the computer (known as a 1/8" TRS cable) is plugged into the green audio output jack on the PC.
Step 3
Before we move to software, let's try two more hardware fixes. If you are using self-powered USB speakers, remove the USB cable and plug it into a different USB port. If you are using outlet powered speakers and have a working set handy, replace the non-working speakers with the working pair to test. If you still have nothing, let's move on to software. But one tip first: (for geeks and beginners)
Step 4
As it is with any troubleshooting process, the issue can sometimes come down to the hardware itself. If you have an add-on sound card and none of the hardware or software fixes helps, you may have to replace the sound card. If you use on-board sound, it will probably pay to purchase an inexpensive sound card rather than a new motherboard. If you've been messing around in the BIOS, you may have disabled your on-board sound if that's what you're using. If you don't know what BIOS means, you probably haven't been there and can move on.
Step 5
Go to your desktop. Click Start > Control Panel > Sounds and Audio Devices > Volume tab. If everything is grayed out, go to step 8. If the "Mute" box is checked, un-check it. In "Device Volume" make sure that your volume level is set to a comfortable volume level for your speakers.
Step 6
Click the "Sounds" tab. Under "Sound Scheme" check to see if "No Sounds" is selected. If it is, click "Sound Schemes" and a drop down list will appear. Select "Windows Default" as the scheme. To test your sound now, click on a sound listed below the "Program Events" window. These will be indicated by a small speaker icon located next to them. Simply left click the sound once, then click the play button. If you hear sound, congratulations. If not, move on.
Step 7
Click the "Audio" tab. Under the "Sound Playback" option, make sure your sound card is selected as the default playback device. Usually, only one device appears here, unless you have multiple playback devices installed.
Step 8
If everything is grayed out, you either do not have a playback device installed or your drivers are corrupted and need to be replaced. Drivers help hardware and software function together. Try this fix for reinstalling drivers. Click Start > Right-click "My Computer" > select "Properties" from the drop-down menu > Click the "Hardware" tab and then click the "Device Manager" button. Device Manager will open.
Step 9
Look for either a red X or a yellow question mark listed under "Sound, Video, and Game Controllers" If you have a red X, right click the device with the x and select "Enable" from the pop-up menu. Test your sound at this point. If you have a yellow question mark, right click the device, click "Properties" from the pop-up menu, and then click the "Driver" tab on the window that appears. Now, click the button "Roll Back Driver" to go back to the previous drivers that were functioning correctly. Restart your computer at the prompt.
Step 10
As a last resort, you can uninstall and reinstall the device. Right click the device and select "Uninstall" from the pop-up menu. Restart your computer. Windows will automatically detect and install your audio device upon boot-up. If after doing all of the steps, listed here and you still cannot hear any sound from your computer speakers, contact a qualified computer technician.
Please rate me if this solution works for you
Thanks......Have a great time.
Aug 08, 2010 | Computers & Internet
I have this set of speakers hooked to a Dell 3000 running under Windows XP Pro. I recently had to change offices and when I hooked up the speakers, the subwoofer wouldn't work. I've tried reinstalling the...
Please check the cable using a multimeter. Check if the cable is broken.
Just by shifting the system, I fear if you could have an issue like this. Also check the Subwoofer box if its working or not. Good Luck.
Jun 04, 2010 | MidiLand MLi SW190 Computer Speakers
I need to hook speakers up to my Dell B110 computer.
2 things are needed to get sound from your speakers:
1-wiring connecting your speakers to a socket to the back of the computer. (The spot they need to plug in to ON YOUR COMPUTER is a small light green circular socket. The other end of the plug you plug in here should run to one of your speakers *usually the right side speaker-the right speaker should then have separate wiring to connect the left speaker.)
2- A source of power.
Some speakers use their own power source and plug in to a power outlet - your wall. Other types have a USB type plug and plug into a USB port in your computer and that is how THOSE get their power.
Those are the basics of sound setup. Some computers are equipped with more complicated setups such as surround sound, subwoofers, digital and more. Reply if you need more help, I will try to assist you further.
Hope this helps.
Feb 02, 2010 | Dell Dimension™ B110 PC Desktop
Help! Only my right speaker works on my new speakers! Do I need a new sound card?
USB headphones and speakers tend to operate independently of the PC's sound card, but you can determine if your sound card is the problem by plugging the speakers into a different computer. If both speakers work on a different computer, then the problem does lie in the original computer. If so, try a different USB port, especially one that is directly on the computer, not in a usb hub.
If only one speaker works on a different computer, I would troubleshoot the cord that connects the left speaker to the right speaker. Perhaps it is damaged or not connected fully.
Hope that helps.
Oct 15, 2009 | HP USB Powered Speakers . Computer...
NO SOUND
They should be plugged in and turned on when you power up your system.They should be plugged into the green jack (line out). You then may have to check settings in control panel for your sound card's properties to see if digital only is checked. Try it both ways. Hope this helps.
May 22, 2009 | Boston Acoustics BA735 Computer Speakers
No sound coming through Toshiba Dynadock station
Try to plug in the speaker jack to Headphone jack on you laptop not to your docking station. So the desktop speaker is treated as an external average speaker. GoodLuck!
May 12, 2009 | Toshiba Dynadock Port Replicator, Docking...
DURABRAND 2.0 CH USB COMPUTER SPEAKERS
try going to control panel, the system icon, hardware tab, divice manager, check to see if your sound card does not have a yellow ! icon next to it, if it does try right click, go to properties, and reinstalling it, it does help if the computer is hooked to the internet so it can find it automaticly over the internet.
Aug 29, 2008 | Durabrand 5.1 Surround Sound Computer...
Durabrand uc-280 don't work!
go to device manager locate the speakers, right click and update drivers, if that fails search google for that sound card driver.
Nov 12, 2007 | Audio Players & Recorders
eMachines ET1641-02w (PT.NA60X.001) PC Desktop Logo
90 people viewed this question
Top eMachines Computers & Internet Experts
brian soufane
Avishek Samaddar
Avishek Samaddar
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
