Question about Procom (177653) Utility Heater
Vent Free Blue Flame heater: shuts off
Vent Free Blue Flame heater Model MD300TBA: pilot lights then when you turn the temp knob up pilot light gets smaller then all of a sudden there is a big burst of flame then it turn completely off
  • 1,420 Answers
Sounds like a gas pressure problem. Have your gas company check the pressure.
Posted on Feb 01, 2010
I can"t keep my pilot light going.
I am assuming this is a patio heater. I have extensive experience with gas appliances. The most common problem with pilot light issues is the thermocouple it is a probe that is directly over the flame , it senses the flame and allows gas to flow, if it senses no flame the gas valve closes. Patio heaters are also quite finicky, sometimes a simple adjustment of the thermocouple will do the trick. Also thorough cleaning of the orifice is necessary at least 1 x a year.
Dec 12, 2011 | Pool & Spa
When i unplug my rinnai heater does that turn off the pilot light?
If it's a Vent-free (Vent-less) heater, not it does not turn OFF the pilot light. If it is a Vented Heater, yes unplugging the heater will turn the pilot light OFF. If you want to turn the pilot off on either unit, the best way to do it is with the Gas Valve, Pilot Control Knob. Turn the knob from the ON position counterclockwise to the OFF position and the pilot flame will go out.
Hope this helped you.
Apr 09, 2011 | Heating & Cooling
How di i light the pilot light
Be sure that the gas line to the heater is ON.
Looking at the Control Knob on top of the heater, you note that he knob has 3- positions: OFF, Pilot, ON.
Turn the control knob to the Pilot position and push down on it. If it does not go all the way in and your do not feel strong pressure pushing back at you, it is not directly in the pilot position. (Reposition the knob slightly and try again). Once You're sure the knob is directly in the pilot position and the knob is depressed, continue to hold it in and press the Ignitor button next to it. You will hear a loud click. If possible, watch the pilot assembly inside the heater when you do this. That way you can see if the pilot lit the first time. If not repeat, pushing the ignitor.
If the gas line had been turned off to the heater, the pilot may not light the first couple of tries, due to air being in the gas line. If that is the case, hold the control knob in until you smell gas, let off, wait 5 minutes and repeat the lighting sequence.
Once the pilot does light, continue to hold the control knob in for 1 minute. This will allow the Thermocouple to heat up completely. Ease off the control knob and the pilot should remain lit. If it does, turn the control knob to ON and the burner will light.
Now you're ready to set the temperature or comfort level. You do this by raising or lowering the flame height. The higher the flames, the more heat it puts out. The lower the flames, the less heat it puts out. The stripe on the knob represents the flame heights - Narrow stripe, lowest setting, widest strip, highest setting. Or your specific model may simply say Low, Medium, High.
If you do not have the Owners Manual for this heater go to http://www.desatech.com/
click on Wall Heaters and enter the Model Number of your heater. You can then download and print the Owners Manual.
Hope this helped to get you up and runnig.
Feb 20, 2011 | Vanguard International Blue Flame - Large...
Charmglow CGL300TQ Keep shutting off after a minute???
Not too familiar with this product, but it looks like a vent free heater. ALL vent free heaters are required to have an ODS pilot light. These pilots monitor the oxygen level in the room and if it detects a low oxygen level, it shuts down the whole heater. This is what I think is really happening. And the solution is simple. Near the rear of the metal tube where the pilot light flame comes out, you will find two very small holes. If these holes get even a little plugged up with dust you will have this problem. Just get a can of air or use an air compressor and blow air through these holes. I bet that this will solve your problem. It is also a good idea to keep the area around your heater clean and free of dust. I have a free standing gas log heater and at the start of each season I take the logs out and vacuum everything, inside and out, and also underneath the unit. Then I use my air compressor to blow out any remaining dust, especially around the pilot light, and of course, I then blow air through the two tiny holes in the pilot light tube. Since I started doing this, I have not had any problems with my heater.
Dec 30, 2010 | Blue Flame Charmglow 30K BTU NG Vent Free ...
Pilot light will not lite; plenty of propane. What position does the knob need to be in to lite the pilot. I see pilot, on, and off positions. It is a Williams gas unit direct vent, does not blow hot air...
The knob needs to be turned so the arrow is pointing at "Pilot". It is the only position you will be able to depress the knob all the way down. Once you light the pilot, keep holding down the knob for 30-60 seconds. When you release the knob, the pilot should stay lit if it's working properly. If not, here's a few things to check. Is the pilot flame blue? Is the flame actually heating the thermocouple end? The thermocouple has to get hot enough to allow the gas to stay on to the pilot. Also look at the tip of the thermocouple. It should be smooth and rounded. If you're pilot flame is a lazy yellow, after time it will burn off the tip of the thermocouple, causing pilot outages. Replacing the thermocouple is usually the easiest fix it and is probably what you will need to do. But if your pilot flame is that lazy yellow, you will also need to clean it by either a tiny broach needle or using canned air (with straw attached). Be careful and because propane is heavier than air, smell low to the floor before lighting it to make sure there is not a gas leak. To be safe, close the gas shut off valve and air out the room before lighting and always follow the manufacturer's lighting instructions printed on the heater. If doing this seems too difficult or scary, then call your local propane co and they will send out a serviceman to fix it for parts and labor. Good luck! Douglas
May 25, 2010 | Heating & Cooling
Lighting a glo warm heater
Is this a new heater or have you had it awhile? If new, yuo may have air in the line that will need to be bled out. The heater has a gas valve with a pilot setting on it. Make sure the gas is turned on. Turn the knob to the pilot setting and depress the handle. Holding it down and at the same time, press down on the red button that sparks. You may have to repeat this a few times. Once the pilot lights, continue to hold down on the pilot knob for about 30 seconds. When uou release the knob, the flame should stay o. If it does not, replace the thermocouple. Once the pilot flame is steady, turn the gas valve knob to on.
Nov 29, 2007 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Glo-Warm Wall Gas Wall-heater parts...
We had a problem keeping the pilot light to stay on, and this site recommended that it could possibly be the thermocoupler that was causing our problems also. We ordered the thermocouple, put it on,hooked it back up and it worked great! Thank you so much.
ordered thermocouple from www.masterparts.net
Nov 19, 2007 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Wont run
check the flame detector it may be a millivolt generator or a flame rod feeding to an electronic circuit.
Nov 16, 2007 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Procom (177653) Utility Heater Logo
413 people viewed this question
Top Procom Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Procom Heating and Cooling Expert? Answer questions, earn points and help others
