Question about KLH HT-9900 System
KLH Model 35 AM/FM turntable combo
Have a KLH Model 35 AM/FM turntable combo, and I am repairing some damaged components on the power supply inside. Looking for a wiring diagram. Does anyone have the Service Manual and are you willing to scan and share the schematic ? Thanks.
H
3 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: KLH subwoofer Model BASSBite V. Has a bad 60Hz buzz
Before you go throwing money at this problem, try to eliminate any external influences like track lighting. I myself am trying to figure out why mine makes a buzz throughout my system when the lights are on. I already replaced the variable light control with no improvement.
Bad cable ground can let airborne electronic noise into the Sub's amp.
Posted on Jan 31, 2010
  • 547 Answers
SOURCE: My KLH subwoofer (model ASW8-120B) has stopped
It's unlikely that you can find a shop to repair it for less than the replacement cost ($75ish for a comparable KLH or Sony sub)
If you're up for doing your own soldering, here's a solution for the same problem with the same amp.
If this helps, please hit the "thumbs up" for me!
Posted on Jun 26, 2010
My hoover optima washing machine is tripping my electricity supply. Have tried disconnecting heating element and looking for damaged wires.
Ian if the circuit breaker is a rcd it will trip off the supply if it
normally detects a very small leakage or unbalance of around 35 m /amps this could be a small water leak onto live parts in the machine or a minute short to earth on one component ,make sure all parts are dry / is it tripping when you switch power on to machine or does it trip when machine is in cycle mode.
1. its as first suggestion 2. it's a component like pump or drive motor that;s causing problem. hope this is of some help,g.luck
Nov 11, 2016 | Hoover Washing Machines
Tip
Schematic Diagrams for KLH ASW10-120
After acquiring a fried KLH ASW10-120, I write to the tech folks at KLH and they sent me the upper and lower board schematics. I asked if I could publish them online, and explicitly asked if I could share them on FixYa.com, and they gave me permission to do just that.
Here's the lower board, which has the power supply:
KLH ASW 10-120 subwoofer schematic - lower board
Here's the upper board:
KLH ASW 10-120 subwoofer schematic - upper board
on Sep 25, 2009 | KLH ASW10-120 Subwoofer
Free schematic diagram
You may not be able to get a schematic. You need to be able to troubleshoot electronics without a schematic. Check where the AC cord connects to the circuit board. In general there should be a fuse and a transient suppressor. Next will be the transformer if there is one or rectifier diodes. These usually fail in a lightning strike. There is also the probability of other component failures, but you won'y know that until you repair these components.
Sep 01, 2014 | Sound Around Pyle Home PTCDS2UI AM/FM...
The turntable will not work. Help!!!! It is model number mmv4205bas
Fisrt check that there are no crumbs or other obstructions on the floor of the oven that would prevent the turntable assembly from rotating properly. Also try removing the plate and lifting up / checking the drive assembly inside the oven cavity to make sure that the turntable drive mechanism has not become disengaged from the motor shaft underneath.
If your problem is not something inside the oven cavity itself, then it may be the result of a simple loose wire to the turntable motor, or it may be a completely burned out motor altogether. Unfortunately the only way to determine the exact source of the problem for sure is to disassemble the unit and troubleshoot the components and connections inside.
A microwave contains a number of very hazardous components such as the main capacitor which can deliver lethal shocks even after the unit has been unplugged. Extreme care should be taken in the disassembly and maintenance of any microwave oven and should be left to a trained technician whenever possible.
Here is a link to the parts diagrams and price lists for your model:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5174676
The turntable drive motor is listed as part number 27 on the diagrams. Here is a link to the part details including price for that item if required:
http://www.appliancepartspros.com/part_details.aspx?part_id=4215435
Hope that was helpful. Good luck and take care.
May 22, 2011 | Maytag MMV4205 Microwave Oven
Hi i'm attempting to repair (with no prior experience or knowledge) a zenith solid state turntable. The only names on it are "allegro sound system" model 169570 and it is an antique style...
I would recommend that you check the wires that are going to the spindle that you described, and see if it is getting power. If not then I would recomend that you replace the switch.
Mar 19, 2011 | Audio Players & Recorders
Turn table doesn't turn. The middle peg doesn't move.
The microwave oven does not have a drive belt for the turntable. The component you describe that the carousel plate sits on its called the turntablel shaft or turntable coupler and it is attached to the turntable motor. This problem is commonly caused by a turntable motor that has worn out and needs replaced. The following link explains how to access and replace one:
http://www.fixya.com/support/r3555716-replacing_a_turntable_motor_on_a_microwa
This is a very simple repair, that usually is not expensive. The motor usually averages about $35 - $40, but the price also depends upon the model. This repair can also be performed on an over the range model microwave oven WITHOUT uninstalling it.
You can usually purchase replacement parts at the any of the following websites:
searspartsdirect.com
pcappliancerepair.com
repairclinic.com
The first three sites listed offer helpful exploded view diagrams to assist you in parts location/identification. If you have any questions, please post back with your complete model number and let me know. I hope this helps you.
Dec 20, 2009 | GE Advantium 120 Convection/Microwave Oven
Have the KLH ASW10-120 Powered Subwoofer and it is blowing fuses
If it stays on for 3 seconds then it probally is not the transformer. However it may very well be the power amp no way to tell untill we operate. Call Pro Line Music 215-736-8055
Dec 11, 2009 | KLH ASW10-120 Subwoofer
A friend stupidly plugged his deck into a 120 volt power supply
More than likely the power supply / power transformer has blown. Although these units have fuses, they will not protect from such a power surge.
Have you lost power, or is the platter rotating abnormally? If there is no power, it's the power supply that needs to be replaced. If it's acting funning, then some components on the main drive PCB are damaged. In either case, professional help is highly recommended.
- OPTiC
Turntable Repair Expert
Digital Analog Therapy
A DJ PRO AUDIO Co.
Nov 24, 2008 | Technics SL-1210 Turntable
Went dead after power outage all other components ok
Hi there!
Power surges are common after the electricity is re-established. The reason some and not all are damaged is because the closest point or the weakest supply is normally taken out first. A job for a repair technician if your are not familiar with the inside of a TV. May just be a fuse if you are lucky. If the led comes on in standby only it is normally more serious. Good Luck,JUS004
Dec 17, 2007 | Sanyo DS35510 35" TV
Yamaha reciever will not power on
If the receiver is completely dead, the problem could be as simple as a blown fuse. If there is no visible fuse holder on the back panel, you'll need to remove the cover. There should be a circuit board near the rear of the chassis where the line cord attaches. You should see a small glass fuse held by clips on the circuit board. Visually inspect it for a break in the small wire inside. Alternately, check it with an ohm meter. If the fuse is blown, replace it with the same amperage fuse rated for 250 volts. (The amperage is engraved on one of the metal ends i.e 0.5A). Before replacing the fuse, do a visual inspection of the other components on the circuit board looking for any signs of burning or overheating The over voltage may have damaged other components, in which case you'll need to take it in for service or scrap it. Most Yamahas have a separate standby supply. If yours has this, chances are pretty good the damage is limited to this area. If the main supply is damaged, it may not be worth fixing.
Dec 12, 2007 | Yamaha HTR-5830 Receiver
KLH HT-9900 System Logo
256 people viewed this question
Top KLH Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a KLH Audio Player and Recorder Expert? Answer questions, earn points and help others
