Question about JVC AV-48WP30 48" Rear Projection Television
The colours seemed to have separated on the screen
  • sands194 Jan 31, 2010
    I tried to reset the convergence but I can only line up the four corners. The green crosses are out. Is there a way I can realign them to the green?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. From what you have described it seems that you have to replace the convergence IC and check power resistor for leakage, if values are not exact you have to replace them. The typical cost to get this fixed by a pro is about $300 - and it doesn't mean that he/they will do a job better than you do. The parts are less than $100 (about $20-$30 for the IC's) if you want to do it yourself. Replacing only the IC's MAY solve the problem; however, many people have also had blown resistors requiring replacement. Why would you ask should you replace both of the IC's if only one is shot?! If one is shot the other one is not far away and for that little price of the chips it worth changing them both at the same time. Also the convergence board should be checked for cracked solder. If you replace the ICs and the resistors are shot, the ICs may blow again almost immediately, meaning you may have to do the repair twice.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Jan 31, 2010
  • Rylee Smith
    Rylee Smith Jan 31, 2010
    I think you have to replace the ICs as you have already tried adjusting everything. Please do accept the solution if the issue is resolved or else revert for further assistance.
    Thanks
    Rylee
Sansui rear projection tv
Convergence misaligned. You have to check the converging control circuit first, for any fault' before attempting a convergence adjustment procedure. Contact any service technician.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 15, 2014 | Televison & Video
RED COLOUR ALL OVER SCREEN
this sounds like a problem with either the screen or, more likely, the graphics chip. If you can't replace the graphics chip (if it's not on a separate removable card), I'm afraid you'll need to bin it and buy a new machine.
The acer logo is displayed before the graphics drivers or windows has started.
Apr 13, 2013 | Acer AL2016W 20" LCD Monitor
Colour separating on screen
Sounds like a Convergence problem----see attached photos---if so provide model and brand and I will offer suggestions/solution for you--also indicate your skill level?
Dec 03, 2012 | Televison & Video
Hi B/w printing is ok but color printig seems blurred and fainted and blue is missing
hi.....
This is because the colour catridge might have finished.
for black and whicte printing you have separate catridge.colour catrige is a tri colour catridge which contains three colous in it.The blue colour might have finished. So please change your colour catrige and it wil ok.
thanx
Jul 03, 2010 | Canon BubbleJet i550 InkJet Printer
There looks to be colour separation on Panasonic plasm viera.
This problems can't be fix,u describing the inner screen of the Plasma pixels burn in.U use this as computer too?U freeze frames in movie,leave video game on pause long period of time,these thing most likely causes plama screen burn in.
Jun 18, 2010 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Printed colours doesn't match with monitor colours
Here is a list of reasons why colours on electronic designs might differ from printed designs:
  • Monitors work in the RGB (Red,Green,Blue) colour space while printers use the CMYK (Cyan, Magenta, Yellow and Black) colour space.
    Designs look fine on a monitor if they are designed in RGB to begin with. Converting them to CMYK might make them look odd on screen, but they will print correctly, to a certain measure. It is difficult to sign of an image file that is currently in CMYK mode while viewing with an RGB monitor.
  • Monitor settings differ.
    The designer was sitting in a darkish room when choosing the blue and his blue looks vibrant. The client was viewing the same design in a well-lit room, making the blue seem lighter. The designer uses an LCD display and the client uses a CRT monitor and the vibrancy differs. The contrast and saturation settings on each monitor might differ as well, rendering the blue with different values.
  • Each printer in the world prints colour slightly different.
    Sometimes it is really obvious and sometimes it is almost impossible to see the difference. Normal desktop printers are definitely not something to do colour proofing with. If you print the design out on your desktop printer then a slight shortage on any of the colours will make the colour come out wrong. There are a lot of factors that can influence even the most expensive printing equipment. These include altitude, humidity, the current heat of the printer, age of the printer, quality of ink, the paper that is being used, special coatings on the paper etc. Even viewing the same printed material in different lighting conditions may make the colour seem different.
Tips on getting the most accurate colour
Go to your nearest printer company and ask to see their Pantone colour matching system. Each colour in the Pantone chart has a matching number. Most design applications have the same Pantone charts built in so that colour matching is easy. Read up on Pantone at Wikipedia. Make sure that the file is converted to CMYK (If not designed in it originally) before sending it to print. Some printer companies might ask for colour separation prints which the leading design packages can produce. It is also important for the designer to choose the correct colour management profile in the design package.
Dec 05, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Double image and colour
There are two common problems with these sets.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 07, 2009 | Sony KP-53HS30 53" Rear Projection...
My acer X193w screen went blue and wont show red
I once had that problem, I think you need to make sure that the power supply cable is fitted well and your monitor receives enough power. if its shares the power cable with your CPU try and separate it then restart your computer.
Jun 24, 2009 | Acer X193W LCD Monitor
Colour interestingly different!
Change posistor in the degausing circuit.
Dec 22, 2007 | Toshiba 28N33 28" TV
Laptop screen problem
I think that possibly over-heating may be the cause. try running a fan on the back side to keep it cooler
May 31, 2007 | Compaq Armada M700 Notebook
JVC AV-48WP30 48" Rear Projection Television Logo
21 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
