I Have just Replaced the water Valve. The water valve has a Thermister on it. The water still just trinkles in. I have also checked the water to the water valve , which checks good, what else could it be?
  • buddy306 Jan 31, 2010
    Dont Know yet, but it seems to me that the washer wouldn't Agitate at the proper water level, which it does. It just takes about 30-45 minutes to fill at the proper water level
  • 3,037 Answers
It could be the water pressure switch is bad. It will be connected to a tube on the inside of the machine (usually on the right side looking from the front of the machine between the drum and the side panel). Try first blowing into the tube to clear it up, otherwise try replacing the pressure sensor switch.
Let me know how this works out for you.
Benjamin
Posted on Jan 31, 2010
I have kenmore he4. My cloathes dont dry completley. My flame ignites for 20 seconds then goes out. Then this behavior continues about every 5 minutes throughout the cycle. Ad the cycle continues the...
I still say ur safety gas valve and coils are bad SORRY NOT ABLE TO HELP MORE WHEN U CHECK the ceramic igniter it could test good meter wise but yet be bad mechanically which would also do what ur experiencing if it was going bad
Mar 29, 2015 | Kenmore Dryers
Replaced viable but no water filling just clicking noises
DISCONNECT THE ELECTRICITY , DISMANTLE THE INLET WATER HOSE CHECK THE WATER COME OUT, CHECK THE VALVE STRAINER ,CHECK THE VOLT ON THE VALVE IF THERE IS , REPLACE THE VALVE
Apr 02, 2014 | Frigidaire ATF6000ES Front Load Washer
Whirlpool commercial top load coin washing machine with only Luke warm water
i would take hoses off washer and check screens infill valves first.valve may have a thermister in it to control water temp this may be bad.may have to call a tech.
Dec 10, 2013 | Whirlpool CAM2752RQ Coin Operated...
We have an GE Profile @ 2005 side by side Model PSC 23 SGRCS5, SRRi L8411485. The freezer temperature has been fluctuating from -1 to 15 degrees. The icemaker is not working. We have replaced the...
The board could be bad, sounds like you have done the test by chilling then warming the thermister and see the rise/drop in ohms value depending whether the thermister is warmer or colder
Aug 17, 2011 | General Electric Refrigerators
THERE SEEMS TO BE A PROBLEM WITH LETTING IN WATER, THERE IS AMPLE WATER PRESSURE BUT JUST A TRINKLE IS COMMING THROUGH AND IT TAKES HOURS TO FULL UP TO WASH
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Aug 12, 2011 | Washing Machines
Samsung RF265ABBP french door bottom freezer. Not making ice. In 2009 the following work done under warranty: new thermister installed, new water valve installed and icemaker replaced. Then in 1-2010 the...
No, the valve is automatically controlled by the PCB panel. You must find out if the valve is commanded by measuring the voltage across it.
If the voltage is there then the valve has failed again and it will have to be replaced. Here it is
http://bit.ly/igBu6H
If the voltage is missing then the PCB panel has failed and it will have to be replaced. Here it is
http://bit.ly/kEWphS
Jun 01, 2011 | Refrigerators
I have a kenmore 90 series, while filling..it's all hot and very little cold. I've checked the outside lines and their clear. So now I'm going inside, any thoughts?
newer washers have a thermister on water valve meaning water temp usualy between 42 and 92 degrees in the tub is the flow of water normal
Jan 23, 2011 | Kenmore Washing Machines
No matter what the temp setting is at it only has very hot water
Your water temp is determined by 2 things. First the hook up to your water supply. If you are able to turn off the hot water valve that feeds the unit and then select a cold water only wash, do you get cold water?? If not then someone hooked up the hoses to 2 hot water feeds. If hot and cold feeds are installed right, the second thing is your computer which monitors the incoming temp through the boards atc control and a thermister. If you select cold, and only get a hum and the cold water valve is on, you may have to clean the screens in the valve of any sediment. If no hum, and no cold, dead solenoid on valve, but that would throw an error code usually. All fills are monitored by the board and usually begin with a hot/wrm mix and then changeover to a monitored cold temp , about 70 degrees.
May 05, 2010 | Kenmore Elite 45986 Front Load Washer
Water is trinkling down the bello and filling drum after wash is complete
Theres an electric water valve. You have to find out if its the hot or cold thats leaking and replace it.
Jan 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
FE code water overfills due to faulty water valve
Water valve is stuck open and needs to be replaced.  The best way to check if the water valve is the problem is to remove the top cover, run the machine to get the water running.  While the water is filling, remove the connector to the water valve that is filling.  If the water continues to run without the connector, the valve needs to be replaced.  If the water stops flowing when disconnected, you may have a control board problem and will need it to be replaced.
Jan 08, 2008 | LG WD-3243RHD Front Load Washer / Dryer
Washing Machines Logo
19 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
