Question about Refrigerators
Frost on back of freezer, not cooling right in both boxes
Maytag Side By Side Model RSW24EOD. Both Freezer side and refrigerator not cooling. Freezer side is frosted on the back wall but temperatue is about 35. Refrigerator at 45. Cooler at the bottom than the top.
What might be the cause?
Condensor coils are clean checked that yesterday.
    Sergeant:
  • 306 Answers
You probably have a defrost heater, timer, or temperature switch failure. The heater is the most common problem. What happens is frost has clogged the cooling coils and very little cold air is being circulated through it to do the cooling. Clean out the freezer and remove the back panel to thaw out with a hair drier or wet vac blower etc. Now find the cause. http://www.appliance411.com/faq/howdefrostworks.shtml
Posted on Jan 31, 2010
My maytag MSD 2651 model fridge is leaking .i can see some frost in the freezer too -help
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 06, 2011 | Maytag MSD2651 HE Side by Side...
Refrigerator side is not cooling however freezer is fine model mzd2766bew
Check the that the fan in the freezer is running . If so check if there is frost on the back wall of the freezer.
Nov 01, 2010 | Maytag 25.6 Cu. Ft. Side-by-Side...
Maytag Model RSW24EOD. Not cooling. Frost on freezer back wall
Low on freon or there may be accumulation of dust and dirt on the coils of the condensor. To check to see if the coils are dirty you need to remove the bottom panel of the fridge just below the frige door. Once you pop off this panel take a flashlight and look under the unit. You will see what looks like a radiator with a fan and fan motor in front of it. If these coils are blocked the unit will not cool since this is where the heat goes from the fridge to be dispersed. Clean the coils with a coil brush (purchased at any hardware store) and use a wet/dry vacuum to remove the debris. Once these coils are cleaned it will take about 12 hours for the unit to operate properly.
If the coils are clean already then you possibly have a compressor that is low on freon. I would check the coils first since most of the time this is the cause of the problem.
Good luck on your repair hope this helped you some
Dave
Jan 29, 2010 | Refrigerators
Maytag Plus side by side (Model MSD2356AEA)not cooling in
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
hhkgjd
Jun 09, 2009 | Maytag MZD2766GES Side by Side...
Refrig not cooling Freezer has frost build up on coils
Frost on the coils won't allow air to pass to the fresh food section, thus resulting in insufficient cooling. To eliminate this problem, you will have to get a new adaptive defrost timer ( small board ), and a defrost heater assembly.
Apr 26, 2009 | Maytag MSD2732GR Side by Side Refrigerator
Maytag Fridge (Model # MZD2766GEW) not cooling
Check to see if you have frost on the back panel of your freezer in your fridge. If you do your coil is frozen over and you'll have to defrost your freezer. I just did mine cause mine wasn't cooling properly on my fridge side.
Apr 06, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Maytag side by side freezer ice build up
I HAVE A MSD2454GRW, 23.5 CU, MAYTAG AND ICE BUILDS UP ON THE FLOOR OF THE FREEZER TO A POINT WHERE IT RUNS ON THE FLOOR. CAN CLEAN IT OUT AND 12-15 HOURS LATER, ITS BACK.
Jul 20, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
MAYTAG MSD2354ARW
How great is the freezer temperature? Look for frost on the freezer back wall. If there is frost there you have a defrost system problem.
the refrigerator is cooled by air it receives from the freezer. When the freezer coil freezes up the air circulation stops.
May 30, 2008 | Hotpoint HSS25GDMWW Side by Side...
Refrigerators Logo
157 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
