Question about Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
Hi I HAVE A SUPER g 3 CANON PRINTER ALARM IS ON MESSAGE THERE IS A PAPER JAM I CANNOT FIND IT AND IF THERE IS A PIECE OF PAPER FRM WHAT I TOOK OUT THERE IS A SMALL PIECE HIDDEN..ANY IDEAS ON HOW TO GET TO A SMALL PIECE OF PAPER
  • 4,041 Answers
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Mar 04, 2010
Message appear 'paper jam'
Have another look, especially the front rollers, all it takes is a small piece of paper in the right place, to get the error message. How do I know, cause it happened to me today.
Nov 07, 2009 | Canon MultiPASS MP360 All-In-One InkJet...
Paper jam
try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 12, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
My canon mx310 keeps showing a paper jam alarm and there is no paper jam. how do I fix it?
give this a try
alternative :
Jun 02, 2009 | Canon PIXMA MX310 All-In-One Printer
Alarm - paper jam slide platen left - but no jam - won't copy
the paper jam is more than likely in the fuser assembly. unfortunately you will need a service tech to come out and fix that issue.
May 27, 2009 | Canon Office Equipment & Supplies
Paper jam problem in pixma mp145. E3 error.
hi
just recently had these problems
symptoms:
LED flashing E3 code and alarm light was solid. But dissapeared when opened the coved and came back on when closed the cover.
Also the when the cover was open the inks did not slide out to the left and stayed to the right side.
There was no paper jam, but error said paper jam.
Solution:
1. I took a thick piece of paper, from like a paper folder ones, thick enough to go in the printer and not curl up when pushed..
2. turned off the printer and turned it back on.
3, while printer was turning on,and makings sound as it does normally when turning on, I pushed through the piece of paper and the rotors stoped for a millisecond.
4.the rotors started again and pushed out the paper by it self with out my force.
5. I let the printer get started. and then turned it off and then on.
6. this solved all of my problems.
this was the first problem ever with this printer in 3 years.,preety good printer.
May 18, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Canon MF3240 Paper Jam - No Real Jam
try this
alternative :
Dec 18, 2008 | Canon imageCLASS MF3240 All-In-One Laser...
Paper Jam
hey, give this a try:
alternative :
Jul 25, 2008 | Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
Canon PIXMA MP160 showing paper jam, but none
hi
symptoms:
Solution:
good luck...
Feb 24, 2008 | Canon PIXMA MP160 All-In-One InkJet...
499 people viewed this question
old marine
old marine
