Question about Polycom SoundStation
Noise on the recieving line
I have a Polyspan Soundstation.
When I make a call to a friend I can speak clearly to them but they are recieving the call with some noise on the line.
Can you help
Sarag
First unplugged the polycom in the teephone outlet and try to connect a digital or analog phone to the telephone line. If there is still some noise, the telephone line is the problem. but when the line is clear and you can hear the other party clearly, check some loose connections in the Polycom provided telephone cable. Or try cleaning with alchohol first the telephone connectors. Dont forget to unplug the power adapter first before you start fixing the cable.
Posted on Sep 29, 2008
  • 682 Answers
1-change telephone cable from your machine to wall outlet if the problem fixed it is ok,if not you must contact your phone company because noise may be in telephone line itself.
Posted on Mar 25, 2008
My kenmore coldspot refrigerator sounds like it is backfiring. Air in the line?
If it is the water line you speak of the I would just let the water flow until the lines are clear. Otherwise I would be looking at the fan motors mocking the noise. There is no possible way for air to get into the refrigeration lines. Good luck
Sep 08, 2012 | Kenmore Refrigerators
I can not get a dial tone on our new soundstation 2W I have unhooked one of our phone lines in our office so the line is good but does not work on the soundstation but works on our phone. When you try...
You need to update the software on the device. I called their support line and the tech explained everything. This has been a common problem with this conference phone.
Feb 07, 2011 | Polycom SoundStation 2W (2200-07800-001)...
Polycom soundstation 2w has no signal. tel line is good, power to transmitter is good. Soundstation seems ok, can get to menu & settings ok.
Hello Edward,
This is a known issue with this product that requires a software upgrade to resolve. Please download "SoundStation2W Software Upgrade" from the Product Support page of our website and follow the included instructions. If you need any assistance please don't hesitate to call for assistance at 1-888-248-4143 Options 2, 4.
Regards,
James
Sep 14, 2010 | Polycom SoundStation 2W (2200-07800-001)...
Error #252
This is a poor fax line error. The line quality has noise or some issue causing the fax receive /or send to fail , often people use the same line for faxing and ADSL (telephone provided internet) and this will cause noise on the line. To fix this I have used a noise filter that came withe the DSL router from the Telco. sometimes ive even had to use two, one on each end of the phone cable before the line was clear enough to send and recieve faxes without a problem. If this is not your case, have the person sending the fax do one at a time or vice versa. Hope that helps you Gurvy
Sep 01, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Polyspan soundstation power supply schematic diagram
My Polycom sound station power unit malfunction. I found that AC transformer broke. If I try to get substitute transformer, what is the required ac output (Vac) and Amp that I need to find?
Nov 23, 2008 | Polycom SoundStation
I have an 18 month old acer AT3220B TV - it has always had a rather loud humming noise in the background and also the volume adjusts itself?! Now I have a vertical black line down the RHS of the...
The TV reciever is capable of recieving an interference especially if your mobile cellphone is near the TV otherwise the black line which is shown on your screen is not normal,you have to sent your unit the service center.....
Jun 14, 2008 | Televison & Video
Static from SoundStation Premier
Check the phone cable you are using for your POTS line. Attach a phone directly to the phone jack and see if it is clear or static without the device.
May 20, 2008 | Polycom >>> SOUNDSTATION PREMIER EX /AVAYA...
Persons on the other end can't hear me speak
hi,
go to menu, then admin setup, then diagnostics, you can adjust the mic levels in there, they are 50% by default.
Feb 27, 2008 | Polycom SoundStation 2W (2200-07800-001)...
Polycom SoundStation Logo
487 people viewed this question
Top Polycom Lands Phones Experts
Gerald Ridge
Gerald Ridge
Level 1 Expert
David Burbee
David Burbee
TEKUSER
TEKUSER
Are you a Polycom Lands Phone Expert? Answer questions, earn points and help others
