Question about Hitachi 51F510 51" Rear Projection HDTV-Ready Television
The color is gone.
The color is dull.
What color that is there is blueish.
People skin color is yellow like they have malaria.
Reds and greens are gone.
What should be orange. is yellow
Please help
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. From what you have described it seems that you have to replace the convergence IC and check power resistor for leakage, if values are not exact you have to replace them. The typical cost to get this fixed by a pro is about $300 - and it doesn't mean that he/they will do a job better than you do. The parts are less than $100 (about $20-$30 for the IC's) if you want to do it yourself. Replacing only the IC's MAY solve the problem; however, many people have also had blown resistors requiring replacement. Why would you ask should you replace both of the IC's if only one is shot?! If one is shot the other one is not far away and for that little price of the chips it worth changing them both at the same time. Also the convergence board should be checked for cracked solder. If you replace the ICs and the resistors are shot, the ICs may blow again almost immediately, meaning you may have to do the repair twice.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Jan 31, 2010
HOW DO I CONNECT A JENN AIR MODELE C 202 C COOKTOP HAS 5 WIRES
Hello Ken,
What color are the wires i suspect they are red,black white,green or bare copper??
connect all the reds to the reds from the house wiring same for the black and white and connect the either green or bare to the green or bare wires
Nov 05, 2011 | Jenn-Air Cooktops
The color is extremly messed up...peoples skin is redish and the green is like a neon color? How do I adjust the color frm the back of the tv?
If your TV looks 3D, warped, or distorted it likely has a convergenge problem.
If however it just looks dull, washed out, redish, greenish, or blueish or if it looks like objects on the screen have halos the fluid in the lens has soured.
You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
Mar 05, 2011 | Philips Magnavox 9P6034C 60" Rear...
The picture & contents are outlined in red green ,yellow colors
Mar 01, 2011 | Hitachi Televison & Video
The color is off, no reds. the tint is either
Bad news is the light engine failed. Good new is Sony extended all warentys for this model till June 2010 so get this to the shop, you do not want to pay for this $800.00 light engine
Dec 29, 2009 | Sony KDF42E2000 42" HDTV
I have a toshiba 56hm195, colors skin tones are washed out, reds
I'm having the same problem; have you found any solutions yet?
Dec 22, 2009 | Toshiba 56HM195 56" Projection HDTV
Screen gone yellow and green
I have a 21'' NEC TV Screen and it about 3 year old. the colour has gone to yellow and green color and the red etc
May 10, 2009 | Samsung PPM42S3 42 in. Plasma Television
Color problem with Sony Grand WEGA 42WE655
Well, there probably isn't any relation between the two problems occuring exept for the timing. Magnetism won't affect a rear projection LCD.
I would say that your description is a bit odd, though. Usually on this model, there is a blue blob that shows up, eventually turning into a blue haze, and a star pattern of stuck pixels. It almost sounds like you have a bad set of component cables. On the SXRD's, they usually turn green.
Does it do it on all inputs (including the channels)? If it does, then it is the optical block. If it does not, then I would suspect that it is cable-related. If it is the optical block, then there is no way that any input can be different from the others (except for digital/analog differences, but those are usually obvious with patterns vertically on the screen).
If it does not look the same on all inputs or channels, change out whatever cables you are using. A loss of the red or blue cable in a component can give the symptoms you describe.
I hope this helps you...
Jan 08, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Yellow is a greenish color
Try printing this test pattern. I got this from this other website. But as ridiculous as I may sound, did you put the yellow cartridge into the Cyan compartment? Because to produce green you need to combine yellow and cyan. This test pattern will tell you which colors are not working properly. Then we can trace which cartridge is the problem or not. Let me know the colors that come out.27dfd86.jpg
Jul 22, 2008 | Brother MFC-410CN All-In-One InkJet...
Hitachi 51F510 51" Rear Projection HDTV-Ready Television Logo
79 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
