Question about Brother FAX-1020 PLUS Plain Paper
Brother 1020 Fax Technical Problem
Pages are now coming out completely black. I thought that there might be a problem with the cartridge and have replaced it, but the problems continue. I have had the machine for over five years but it has not had heavy use at any time, just the odd fax and photcopy, probably 500 sheets maximum over that time. Is anyone able to offer advice?
    Scholar:
  • 78 Answers
If all page are coming out blank there is only one possibility. The Thermal Head (basically heats the ink on to the paper) has failed. It should be a relatively cheap fix but like you said the machine is know over five years old.
Posted on Feb 18, 2008
Can i default to print black only
I am a Brother employee working for the software technical support department.
We have a solution for your issue posted on our solution site.
http://www.brother-usa.com/FAQs/Solution.aspx?FAQID=200000017380
Description of Problem 100000013536
How do I print in monochrome mode (black and white) using only black toner from Windows or Macintosh OS X?
Brother Software Technical Support
Frequently Asked Questions
Jun 26, 2014 | Brother TN-210 Black Toner Cartridge
Hi there, I have brother 1020 fax and clients are
No, the scanner block is defective. I think it's time for a new fax machine.
Apr 18, 2010 | Brother FAX-1020 PLUS Plain Paper
Black pages to all work
Nothing you can do. The SCANNER BLOCK is defective.
Jan 31, 2010 | Brother IntelliFAX 1270E Plain Paper Fax
Brother Intellifax 2600 - Solid black pages
Black pages are indicative of a bad drum. A failing drum basically can't be charged anymore. Since the toner cartridge can't discern what part of the drum is calling for toner, it simply fills the whole page with toner, creating the black pages you describe. You should check the drum, and corona wire and clean both. If the problem returns, you have a bad drum and should replace it.
Jul 09, 2009 | Brother IntelliFAX 2600 Fax
We just changed the toner in our fax, and now it's printing solid black pages out. Help!
Unplug the cable that connects the computer and printer together.
Plug the printer power cord into a wall outlet.
Print a self-test to determine if the problem is related to the printer, rather than the software.
If the problem occurs on the self-test page, replace the toner cartridge. A faulty or damaged cartridge may cause black pages.
Remove all accessories (cartridges, memory, I/O boards, etc.) and try to print a self-test again. Faulty accessories may cause black pages to be produced.
If the problem persists, the printer may need to be serviced.
Thanks
Fame !
Jun 10, 2009 | Brother IntelliFax-2820 Laser Fax
Thick black streaks on pages coming through the fax
remove the toner cartridge and you should be able to see the matching black streaks on it, if it is the problem .....don't bother trying to clean it , it is supposed to be self cleaning and you can't improve this look...replace
Mar 03, 2009 | Brother IntelliFAX 4100 Laser Fax
Fax Brother 1020
SOUNDS LIKE YOU ARE USING REFILLS? IT IS BEST TO USE THE CART WITH E FILM ALREADY IN IT  GOOD LUCK
Jan 26, 2009 | Brother FAX-1020 PLUS Plain Paper
Prints completely black page when copying.
hello! are you usinga brother oen toner and drum cartrdige? that is the first thing to try, you are welcome to post back to me for additional help good luck brother tech
Jan 22, 2009 | Brother IntelliFax-2820 Laser Fax
Brother fax
The drum cleaning blade is worn out. You must replace the Drum Unit.
Apr 18, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
Brother Fax 1020
The 1020 only had a hard copy manual (ie not on PDF). The 1020e was rework of the previous model of the 1020 so it should be pretty much the same. Try this link - http://www.remington.com.pg/PDF_files/Brother%20-%20Plain%20Paper%20Faxes/Fax%201020e/Fax%201020e%20User%20Guide.pdf
Jan 11, 2008 | Brother FAX-1020 PLUS Plain Paper
Brother FAX-1020 PLUS Plain Paper Logo
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
