Question about Whirlpool Washing Machines
My top loading Whirlpool YLSR7233BQ0 causes staining and discolouration on occasion. Anything available to clear the washer of this problem?
catriver
  • 878 Answers
SOURCE: Black stains on Laundry from a front load washer.
bob, if your model starts with 417. this is a mother of all jobs. The black marks are coming from the rear bearing assy. in the tub. I just changed one out and it is misery. I don't believe the boot is causing the black marks. When I tore this one apart I found the tub, tub to drain pump hose, pump itself, contaminated with this black crap. Replaced them all. The tub and bearing comes as one piece and it is no fun to put in. The whole washer has to come apart to do this job and it requires two men to do it. The boot (bellow)itself is a pain to install. You might want to check with Sears and see if this is covered under the 5 year warrany on the bearing and tub, parts only, if not, it's not worth the time or money..Catriver..post back.
Posted on Apr 23, 2007
SearsTechToo
  • 261 Answers
SOURCE: WHIRLPOOL ULTIMATE CARE II MAKES YELLOW BROWN STAINS ON LIGHT COLOR CLOTHES
Grease will not come from the interior of the washer, as the machine ages build up deposits under the basket and it is oily, greasy and full of mildew. If can get a spanner wrench from a appliance parts house and remove the basket you will see on machines older than three years a build up starting. I pulled 15 lbs from a 25 year old machine and I had to go get sick outside, it was bad.
Posted on Oct 06, 2008
duby1990
  • 370 Answers
SOURCE: no cold water Whirlpool top load washer AP595033
Your cold water celenoid has gone out. There is no way to just replace the cold itself, So you have to buy the whole water valve. That will fix ya up!
Posted on Nov 19, 2008
prasanth83
  • 68 Answers
SOURCE: Oil spots on clothes
HI Friend,
First of all relax alright, you are in safe hands.
See every washing machine has a turbine at the bottom f the washing bowl and below that there is a motor. And there wud be a safety valve or (washer ) which basically looks like a ring made out rubber or plastic and when this ring gets outdated or torn it stops controlling the oil flow and thats the reason y ur clothes have the oil stains ,so once it is replaced you will not have this issue.
This would surely help you in getting the clothes clean and tidy.!!!!!!!!!!!!
Have a great day!!!!!!!!!!!!!!!!!!
And please rate me so that I can improve myself(vote).
Prasanth83:):):)
Posted on May 13, 2009
  • 180 Answers
SOURCE: Whirlpool Cabrio top loading washer F1 Error
F1 means the control board is shot. Call whirlpool and they should take care of the parts and labor even though your machine is out of warranty.
Posted on Nov 27, 2009
Gunk gets on clothes-stains them,i pulled agitator out and cleaned it off ran bleach thru-its better but still getting on clothes
The problem may be the seal on the transmission failing. If this happens, grease from the transmission (necessary for it to function) will leak and float (recall from science class that oil is less dense that water) up into the washer. As the grease enters the tub, it stains your clothes.
Washer Transmission Replacement Whirlpool Kenmore Top Load Washing Machine...
Washer Leaks Water GE Top Load Washer Tub Seal Replacement Part WH02X10383
Jan 21, 2016 | Amana 3.2 cu. ft. Top-Load Washer
Washer leaves stains on clothing
Many times when we cook in the kitchen, we get splattered with oils that aren't easily visible. Very often these oil spots pick up dirt from the wash water. These stains don't usually get noticed until after the clothes have been dried. The best thing to do is to rub detergent or stain remover right on these spots and let them sit about half an hour. Then rewash the clothes in as hot water as the material can take afterwards.
Aug 11, 2008 | Whirlpool Washing Machines
CLOTHES COMING OUT OF WASHER WITH DARK STAINS
Hi Lynn, this is AP.
I understand you are seeing stains and lint on your clothes once removed from your top load washer, model FWS833A. There could be several culprits causing this to happen. To confirm, are the stains not being removed during cycle or do you believe the washer is the cause of the stains? If you believe the stains are being caused from the washer it could possibly be undiluted liquid fabric softener poured directly on fabric. Something more serious could be a broken transmission causing oil to leak in the tub.
There are some basic troubleshooting tips for lint to check such as undissolved detergent can leave residue on clothing. Separate clothing items which shed lint from items which attract lint. Permanent press, synthetic, knit and corduroy items will pick up lint from towels, rugs and chenille bedspreads. Make sure to Use correct amount of detergent, water temperature and water level.
There are some simple troubleshooting tips listed above and in your owner's manual, if you find they do not resolve your concern I would recommend contacting a local authorized technician to inspect the washer.
Thanks,
Mar 30, 2014 | Frigidaire FWS833A Top Load Washer
We have a whirlpool top loader (Gold ultimate care II quiet wash plus). After washing, clothes are stained with grease like spots. Do you have any idea what is causing this?
I am not an expert but I would guess it is your soap. perhaps try a different brand or maybe less.... I have not had this issue with mine but i did have the issue with my old washer and it was actually soap and not grease that caused the issues. I could be completely wrong, maybe you just need to run a cleaning cycle.
Jan 13, 2013 | Whirlpool Cabrio WTW6600SBT Top Load...
On several occasions, white sheets come out of the washer with dark stains on them. Seems like some kind of oil. We have to spray with stain remover and rewash. This seems to take care of it, but would...
This is caused by an oil leak at the transmission tub seal.
Kinda expensive to fix. Depends on the age of your washer whether its worth it.
If this was helpful please rate me.
IMUFO2
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Sep 06, 2010 | Fisher and Paykel GWL11 Top Load Washer
Stains from washer
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Starting to leave brown oily like stain on clothes
The first place that I'd check would be the small metal screens inside the openings on the water inlet valve. They can get really rusted, epecially in areas with hard water, so I would recommend removing the water supply hoses and take a gander at the screens. They can sometimes release the iron oxide into the wash water and cause brown stains or blotches on clothing. Hope this helped and best wishes.
Sep 07, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Washer whining when washing and spinning leaving brown stains on clothes
Turn water off. Remove hoses and clean the rust out of the strainers at hose end. If they are clogged they will sound funny when water goes through them.
May 04, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
I have been getting brown stains in the shape of a line on items of clothing washed in my Whirlpool duet washer. I can not get these stains out with anything and they are ruining numerous items of...
I have been getting brown stains in the shape of a line on items of clothing washed in my Whirlpool duet washer. I can not get these stains out with anything and they are ruining numerous items of clothing. I have no idea what is causing them - I have manually cleaned the inside of the washer. same thing here. I have been having this problem for a few weeks, cant wash anything white without ruining it.
Apr 23, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Washing Machines Logo
47 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
