Question about Toys
Radar does not rotate on the 197 tower. I do hear humming when power is applied.
All set - please take me off mailing list.
Posted on Feb 01, 2010
My ghost radar classic does not talk.
Same happend with me . kindly remove n re install the happens
Jul 08, 2011 | Spud Pickles Ghost Radar Classic ™
Tip
Furuno VX2 Radar heading alignment
Please take the time to rate this tip!
This tip applies to all VX2 radars from Furuno. Models Include 1724c, 1734c, 1824c, 1834c, 1934c, 1944c, 1954c, 1964c, 1724cnt, 17234cnt, 1824cnt, 1834cnt, 1934cnt, 1944cnt, 1954cnt, 1964cnt, and 19XXBB series black box radar processors.When the picture is "crooked", "rotated" or "needs re aiming" you need to do the radar heading alignment. In order to do the radar heading aligment, you must access the installation menus, available only in installation setup mode.
Press and hold "MENU" during power on.Continue holding menu during start up, at least until the boat appears.
Choose , "Installation Mode", Choose "Menu", "System Configuration", "Installation Set Up" "Radar Set Up".
Here is where people get lost! Choose "Next Page", Choose "Heading Alignment". You will be prompted to place the dotted line on a target "dead ahead". Follow instructions and then, do not forget to press "SET". Press Return Return Return or Menu to exit and resume normal operation.
Note that the installation menus disappear if they are not accessed for five minutes!.
Please take the time to rate this tip.
That is all there is to it.
Please "Optimize Radar Video" in same menu (Radar Set Up).
847-746-0100
www.technicalmarine.com
on Jan 17, 2010 | Furuno Navnet 1834C/NT vx2 Radar C Map Nt
Dryer motor hums but does not turn when start button is pushed
If you hear the motor humming and not starting at all it most likely has a severe friction problem with the drum or motor. It could possibly have some type of garment jamming the blower wheel preventing the motor from starting too.
Open the dryer door and manually rotate the dryer drum counter clockwise (CCW). It should take very little effort to rotate the drum. If it's hard to rotate that could explain why the motor hums instead of starting up. If it turns freely, shut the door and see if will start. If it still hums and not start it may have bad motor or a low voltage supply to the motor.
Jan 24, 2011 | Maytag MDG6000 Dryer
Model # 72852 Burning smell Drum does not turn but a humming noise When door is closed it hums without the start button being pushed.
Jan 18, 2011 | Kenmore Dryers
When I press the start button, it hums but won't turn on, I hear clicking behind the cycle setting dial?
Jan 17, 2011 | Maytag Dryers
When you turn on the dryer you can hear the motor hum but the drum wont turn ...i checked the belt and it is not broken
When you checked the belt, did you check to see if the motor would turn by hand, if not the motor is locked down and that's why you hear the hum noise, it still has power and still trying to rotate, but from being locked down it has no option but to strain and hum. If that's not it, check around the drum for a sock or small piece of clothing, it can wedge between drum and dryer frame and cause the tub not to rotate just like if the motor were locked down.
Jan 06, 2010 | Washing Machines
Error SB SIG MISS on FURUNO CRT radar?
Either your reed switch is bad or your antenna is not rotating. You may hear the motor spinning but that does not mean the array is. If the array is not spinning make sure the belt did not come off the motor. Start there.
Jul 05, 2009 | Furuno 1715 LCD Radar System GPS Receiver
Pioneer Receiver SX-750: Getting a loud hum through the speakers
The hum you hear from the speakers and from the unit itself originate with 60hz AC power. They may not actually be related. Sometimes a transformer will hum slightly and unnoticeably. That you're getting a loud speaker hum says there is an electrical leak or a grounding issue somewhere.
Do all sources produce the hum or, say, just the phono? How about on headphones? Try rotating the AC plug. In those days they weren't keyed with one large blade as they are now.
May 17, 2009 | Pioneer Audio Players & Recorders
Help!
If you live near a cell-phone tower, your radar detector can pick up on the waves coming from it. If you like in an area where radar detectors are legal and Ku band is not used, I recommend turning off the vg2, spectre and Ku bands on your detector. This will not only cut down on some of the "noise" but also make your radar detector more reliable for when you are actually "zapped" by law enforcement.
Mar 31, 2008 | XRS-757 Radar Detector
The dryer just makes a humming noise when I turn it on, but won't turn all the way on
When you say it won't turn all the way on, does that mean the drum isn't rotating?
If yes, the belt from the motor that goes around the drum might have broken and you can hear the hum of the motor spinning but no longer rotating the drum.
The other thing I can think of is that the motor itself has failed, possibly seized, and you can hear the motor trying to spin but it cannot. With the dryer unplugged and empty of clothes, try to rotate the drum. If it rotates extreamly easily, then the belt has broken. If you cannot rotate it at all by hand, then chances are the motor is seized. It should rotate with moderate effort.
Mar 08, 2008 | Dryers
Toys Logo
129 people viewed this question
Top Toys Experts
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
