Question about Kenmore Washing Machines
Kenmore 80 series - won't spin out. I can start it spinning and then it sometimes will - but I also can't figure out how to get at the inside, I think it's a stretched out belt. My 20 yr old Maytag was easy- lift off the front panel - Don't know how to get at this one.
  • 1 more comment
  • mbickham Feb 01, 2010
    It is a top load Sears Kenmore
    Model - 110 - 24872300
    Serial #CP3928806
    I am not sure of anything - just that it won't spin the clothes after the final rinse - not sure after the wash...as have not actually caught it then. It seems to be worse with a heavy load - like big towels or jeans. How do you even get to the "works" of it?
  • mbickham Feb 04, 2010
    I sent the model number but didn't see it on here....
    another clue: It spins out OK on the wash cycle - so I let it go all the way through - most of the water does drain out after the final rinse but not all. So, I shut off water and turn washer on again at the wash spin cycle to get the clothes spun out.
    Kenmore - top load
    Model:24872300
    CP 3928806
  • oldguy5 May 11, 2010
    Can you provide the exact Make, Model and Kenmore model number? .......... Kenmore model numbers use the format ###.######## with the first three digits of 110 for Whirlpool manufactured machines......... The model number on top load washers is usually found by lifting the lid and looking above the tub. The Fixya numbers are Stock Numbers. Actual Model Numbers are necessary to correctly diagnose the problem. Are you sure that it's a belt drive??? Top load, direct drive washers use a Motor Coupler between the motor and transmission. It serves basically the same purpose as a belt.
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:;
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.24872300
and you'll see a list of major sub-components with diagrams and parts.
The Kenmore / Whirlpool top load uses a reversing motor to initiate the pump for draining and the transmission to spin.
If you cannot hear the motor trying to turn the pump, (but the washer will agitate) the problem points to the Timer, or the Lid Switch.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
Following is a description of how to release the console for access to the pins.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part.
While you have the cabinet off, pull the pump and motor and check the Motor Coupler to see if it's worn or damaged.
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission.
It's used as a fail safe device and consists of three parts.
Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the transmission input shaft. Between them is a rubber piece with six holes.
The power from the motor is transmitted through the rubber piece to the transmission.
The other shaft on the motor directly drives the pump.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or spinning.
See the following for how to remove the cabinet, pump, motor and motor mounting plate to inspect and replace the motor coupler.
If the coupler looks damaged, it's a relatively easy fix.
Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6 inch) pry bar works well.
Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to put pressure equally around the pieces.
Put the rubber piece on the transmission plastic piece.
Replace the motor mounting plate.
Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be damaged.
Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
If the problem isn't in the switch or the Motor Coupler, and the Timer continues to move, the problem is likely in the transmission.
If you lift the lid, put it down again and the washer begins to spin, the problem is likely in the transmission "Neutral Drain Assembly".
Those cams/gears etc. in that assembly keep the washer from spinning until all of the water is pumped out and then go into spin mode.
Apparently, by opening and closing the lid, torque from the motor starting throws the cams into the right gears so that the washer will spin.
Ours had the same problem, no spin unless the lid was raised and lowered or we shut off and re-started the cycle.
After looking at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) we noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Found the part number for a kit (Whirlpool part number 388253 Neutral Assembly) for $15.00 and replaced the cams and gears.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator uses a plastic 1/2" drive bolt (a 1/2" socket extension works well).
You don't have to remove the drum.
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside.
Remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission.
Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft), remove the 8 screws carefully the transmission holds 14 - 15Oz of oil, remove the clip holding the main spin gear on and check the plastic cams.
If the cam that should have a spring doesn't, or the others look damaged, or the main spin gear is damaged the washer won't go into spin mode.
If that's the problem, install a Neutral drain kit, put everything back together carefully and the problem may be solved.
As an aside, fixing ours cost less than $30 including 80-90 weight gear oil vs. $170 for a new transmission.
Posted on Feb 01, 2010
Kenmore 80 series model # 110.82382110 fills, agitates and drains but won't spin
Based on the information you provided, you need to replace the wig wag on the unit. No joke, that is what the part is called. Here is a link to the part to order.
Nov 05, 2012 | Washing Machines
My kenmore ad 80 series washing machine won't spin
The lid switch is probably out. Bypass it and see if she magically comes to life. Their are 3 wires to the lid switch 2 of which are live wires. Jumper them 2 live wires and see if she runs in spin.
My home video: Washer won't spin It's a doozy
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 20, 2012 | Kenmore Washing Machines
Kenmore 80 series washer won't spin or agitate
check to make sure the belt hasn't come off. if it's direct drive make sure the shaft is working and moving freely. if all of these check out the motor that turns everything my be stuck, frozen up or just bad all together.
Jul 14, 2012 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series washing machine model stopped spinning
Check this out acc8ce4.jpgmight be a partially defective coupling or lid switch. More HERE
Mar 21, 2010 | Kenmore Washing Machines
Kenmore 80 series not agitating or spinning,making racheting soun
You have a broken coupling that links the motor and transmission. Call around your area for estimates. It is a pretty straight forward job so most technicians should be able to give you an estimate over the phone. Most likely between $150.00 and $200.00.
Aug 01, 2009 | Washing Machines
Kenmore 80 series washer make high pitched whining noise
cold water screen in hose was half plugged causing it to either shut off the spin cylce due to lack of water or increase the spinning speed.
Hope this solves the problem.
Dec 10, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore washer 80 series 4 years old
my washing machine is not rinsing and spinning
Jan 20, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
207 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
