Question about Sony Audio Players & Recorders
Sony TC-230 motor has very little torque - Sony Audio Players & Recorders
Check the motor's run capacitor.It should have be 2Mfd. Generally it goes bad with time.
Posted on Aug 23, 2010
Jet table saw 3hp, low torque! New saw, correct electrical hook up, but not much power at the blade, so yes it runs but no torque! mag switch in test position, does it need to be in auto???
I am not sure what model you have but they have this saw in two models one is 230 volt only the other is 230/460 volt.
But that is not a 220 volt circuit. 220 volt is single phase where the 230/460 is a 3 phase circuit.
Look on your motor and see what the power requirement is.
if you have a different machine then the one I am looking at I would switch over to the auto function.
May 10, 2017 | Jet Saws
How to get bolts out of a torque converter on a 99 Nissan quest
Where is the torque converter? Transmission installed in car?
If so there is often an access plate on the bottom of the bell housing to get the bolts off with an open end or box wrench. If the access plate is on the top you often have to pull the engine/transmission, release the TC bolts, then split the trans from the engine to replace the torque converter.
If you've broken the bolts and there are stubs in the TC you can try to drill them out and use an EZ-out bolt remover. OR just replace the TC.
Feb 04, 2017 | 1999 Nissan Quest
I want to change a 3.7 motor off of 2004 jeep Liberty 2wd in order to fit my 2002 jeep liberty 4wd?
engine swaps are complex as is mixing engines to wrong transmissions.
so both are 3.7L, is that it?
you never said what exacty didnt fit.
the flex plate to TC
or TC to A/T pump side mismatch.
if its the flex then get the correct flex plate.
or call jeep parts? ask them for the right parts
the side of the trans has the trans part number
my guess is all you need is the correct flex plate for engine to TC.
Aug 10, 2015 | 2004 Jeep Liberty
New leeson 3 hp motor for my tablesaw has very little torque, and is less powerful than my old 1hp craftsman motor. What could the problem be?
If the motor is a 115/230 volt motor and is running on 115 volts but the wiring is configured for 230 volt operation, the motor will be weak.
Apr 05, 2014 | Leeson Table Saw Motor - 113627
Flywheel for 1992 302 two big won't fit torque converter
Are you swapping engines? Only manual transmissions use a flywheel. Automatic equipped engines use a flex plate to mate the torque converter to the engine crankshaft. The flex plate is bolted to the crankshaft just like a flywheel, but is much smaller, thinner and with very little weight. If you do have a flex plate mounted, it must be the wrong one to match your torque converter and transmission.
Sep 23, 2013 | Bikemaster Motorcycle Magneto Flywheel...
Torque converter switch code
p0719 is torque convertor clutch brake switch curcuit low. p0724 is same curcuit is high, p0741 is tc clutch system stuck off, p0742 is the same but stuck on. p1860 is torque convertor clutch pulse width modulator solinoid curcuit, p1887 is tc convertor clutch release switch malfunction.
Oct 06, 2010 | 2001 Pontiac Aztek
Where to buy a crawl tool to reinstall belts of sony tc we 605s cassette tape deck
There is no crawl tool to reinstall belts in this tape deck, it just needs little expertise/ skills.
First put flat belt on motor pulley then slowly thread the flat belt on both capstan wheels with help of tweezers or some thing.
Let me know your email to send you related service manual free copy that has exploded views of mechanism and I hope that will help you to reinstall belts in correct direction/ way.
Thanks.
Aug 10, 2010 | Sony Audio Players & Recorders
Need head bolt torque for Brigges Stratton 18 Hp
210 to 230 inch pounds. Torque in a crisscross pattern upper left lower right upper right or left or right.
Jul 10, 2009 | Garden
I have a sony TC 530. Fast fwd and rewind work
You need to replace the motor run capacitor. It's a small aluminum can looking thing with three wires right next to the motor; they often leak paraffin wax into the bottom of the case when they overheat. Whether or not yours has leaked it's easy to replace if you can use a soldering iron. Search eBay for a Sony reel to reel 1.5uf 250VAC motor run capacitor - they're less than $15 and come with detailed instructions.
Please wait Image not available
Jun 14, 2009 | Quantegy 456 Reel-To-Reel Recording Tape
Slow tape speed on reel to reel tape deck
My TC-230 has the same problems and it is mechanical. Actually, its real hard to say what your problem is, but it is most likely the pinch roller is to tight on the piece that is connected to the motor. This extra tension is from a spring inside the machine and, when in storage for a long time with the machine set to stop, extra pressure builds up on this spring. Try leaving it unplugged on fast forward/play overnight. that might help.
May 08, 2009 | Audio Players & Recorders
156 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
