Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
My light bulbs keep burning out prematurely on my garage door opener.
I have tried replacing the bulbs with heavy duty ones but this did not solve the problem. Someone suggested that i might have a problem with the logic board. Can this be repaired? My model number is 139.18470.
I have a 1/2 horse craftsman opener that utilizes dual light bulbs. I put 2 new bulbs (heavy duty) in and both burned out as soon as I pressed the light switch on the control pad.
  • 3 Answers
I had a similar problem on my Liftmaster units made by Chamberlin. I would leave the garage door open for hours during the day so our dog and children can enter the house through our garage and laundry room. Everytime they come into the garage the Light's would go on because of the safety sensors are "tripped" at the bottom of the garage door tracks.
I turned off this feature and my lights are lasting much longer now. Over 1year in fact. To turn off and on this feature, make sure the opener light is off, then Press and Hold the Light Switch on the Wall Control Until for about 10 seconds till the light goes off. This deactivates this sensor from turning the lights on, but does NOT deactivate the sensor for Stopping the door if something is under it. Safety is still preserved.
Additionally, my door opener would vibrate while operating, and need to be aligned - I did this and also prevented the bulbs from "shaking". As we know the light bulb filaments are brittle especially after some use - this I think also helped lengthen the life of my lights on the opener.
Posted on Jul 01, 2012
    Scholar:
  • 143 Answers
This is a logic board issue. You can purchase a replacement one at searspartsdirect.com. Enter in your model number and a parts list will come up. This is a fairly easy install, make sure and unplug the unit first. You will have to reprogram the remotes. Thanks BB
Posted on Sep 17, 2010
Garage doors work but the light on one of the inside opener keeps flickering, What do I do?
disconnect the power and try to pry the prong in the socket of the light outwords,check the connection in the unit itself
Jun 11, 2011 | liftmaster Chamberlain Garage Door Opener...
The lightbulb in the unit burns out quickly, every 4-6 weeks. I have Lift Master 1/3 H.P. FCC ID #HBW1127, Part #41A4252-7D
You can buy bulbs designed for garage door openers. They are heavier duty. Also you should unplug the unit and remove the light bulb. Pull out on the center contact of the socket. Replace the bulb and plug the unit in.
Oct 17, 2010 | Sears Craftsman LiftMaster Chamberlain...
Replacement bulb only lights for a day and then burns out again
There are heavy duty/rough service bulbs you can buy at the hardware store that are made to withstand the vibrations. You might also try unplugging the opener and removing the light bulb. Use a screwdriver to reach down to the center contact in the light socket and pull out. That will increase the tension on the bulb somewhat.
Jul 09, 2010 | Sears Craftsman LiftMaster Chamberlain...
My Crafstman garage opener is melting my light bulbs!
Rather than new bulbs I suggest you unplug the unit and use a small screwdriver to pull out on the center contact of the light socket.
Nov 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
Light bulbs burn out constantly on Chamberlain garage door opener
Get an electrician to measure voltage where the light is plugged in. It sounds like you have too high a voltage.
Aug 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain door opener--Door opens but light will not come on
We had he same issue and changed our bulb from a CFC back to a traditional bulb and the problem was solved!
Sep 22, 2008 | Chamberlain Powerdrive PD422D 1/2 HP...
Light problems
Try to install a heavy duty vibration proof bulb. Most hardware stores sock these. Your door might vibrate too much and cause premature bulb failure.
Mar 27, 2008 | Chamberlain Powerdrive PD422D 1/2 HP...
Garage door opener light bulbs burning out
You can replace the socket itself. Unless there is extreme vibration this will be your best bet. If there is vibration then use some rubber washers to lessen this. You can get replacement parts at chamberlain.com. Thanks BB
Mar 07, 2008 | Sears Craftsman LiftMaster Chamberlain...
I tried a REVEAL(brand) 40 WATT DOUBLE LIFE CEILING FAN LIGHT BULB , and almost two months later it still works. It is sold at Home Depot in Illinois. The filament is much thicker than any of the other heavy-duty bulbs I have tried, and that seems to be the difference. The REVEAL bulb is the only one I have tried that has lasted this long.
Feb 01, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
621 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
