Question about Refrigerators
I've had this unot for a few years and just this past week the refrigerator side is acting more like a freezer as everything is frozen... ( The temperature setting is only at 46 degrees) What could be the problem? (Bad thermostat??) Thanks
  • martinentr Jan 31, 2010
    Samsung Model RS263BBWP
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 162 Answers
What is the make and model #
Posted on Jan 31, 2010
  • harold nesmith
    harold nesmith Jan 31, 2010
    this unit has a sensor located in the refrig section that is no longer avaiable. checked a few diff places. nla ok this may or maynot be the problem, but this what i have come up with. this number changes and i have found an alt part # and a source. p# ca32-00006w and it can be ordered from marcone 1-800-282-6636 $5.72 this unit has a main control board that is prob expensive. try the sensor.
Hello. I've had the above f/freezer for about 6 years and its been fine. Over the past two weeks i've been getting small amounts of water going on to the floor, from the freezer side - it's as...
Sounds like a plugged drain. Your FF defrosts 2-3 times a day and if the drain plugged the next defrost water just runs out the door.
Aug 30, 2011 | Refrigerators
I have a Jenn Air JCD2289AEW side by side refrigerator. The freezer has not been cooling properly for a few days. Now the refrigerator seems to be maybe less cool than it should be. I still get cold air...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 16, 2011 | Jenn-Air JCD2389G Side by Side...
For past two days, my refrigerator and freezer are not on. Light works when doors are open. I cleaned coils underneath, and it did turn on after cleaning. But it also turns on when I leave doors open...
Is it staying cold? Are things staying frozen in the freezer? If everything is okay, then you simply made it a lot more efficient by cleaning the coils! If that is the case, your electric bill will probably go down.
Apr 22, 2017 | Kenmore 56239 / 56232 / 56234 / 56236 Side...
I have a Maytag Side by side MSD2356AEW unit. Everything was OK for years till the maid cleaned it. Afterwards we noticed water under the bottom drawer on the refrigerator side. Slowly in the course of 2...
Do a manual defrost overnight by unplugging and leaving the doors open the opening should not be frozen. Alot of humidity or constantly opening the door sometimes causes the frostup.
Mar 13, 2010 | Maytag MSD2651 HE Side by Side...
Maytg Top Mount Freezer drip tube leaks into bottom of Refrigerat
Just had this problem a few weeks ago. tube from freezer was frozen solid 1-2 feet down from the freezer. Empty EVERYTHING out of the the Fridge and the freezer into coolers or other suitable 2-4hr container(s). Unplug the unit and use a hair blow dryer on the coolest warm setting. If it's too hot it may melt plastic or styrofoam parts. As long as long as you have everything out and it's going to be at room temperature for a while, why not clean it totally out with fantastic or your favorite cleaner. Once your sure the clog is gone from the tube, put it all back together, plug it in and stop being a slob and keep it clean!!!! hehehehehehe
Sep 08, 2009 | Maytag MSD2756G Side by Side Refrigerator
Cold but not frozen
23 years old ? That thing was costing you more than a new unit would cost for the past 5 years!
Assuming your airflows are good, Its time for a new refrigerator.
Aug 29, 2009 | Refrigerators
Back of freezer ices up and the freezer
You most likely have a burnt out defrost heater. The most common part number is WR51X10053, but if you comment back with your exact model number I can confirm that for you. To fix it, you will need to remove the shelves in the freezer so you can take the back wall out. Defrost all the coils by unplugging as you have, or use a hair blower. The defrost heater is along the very bottom of the coils and has a wire connected to each side of it.
Jan 07, 2009 | GE GSL22JFPBS Side by Side Refrigerator
GE Side by Side refrigerator/freezer Evaporator keeps freezing up
Sounds like the auto-defrost timer has gone bad. In many cases, that is the cause. Check with GE service.
Sep 04, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ge after replace fan still fan not working
Something to check for. Is the top of the refrigerator door lower than the freezer door? If so the ref. light may not be turning off all the time. Pull bottom panel off to expose hinges. The ref hinge should have an adjuster. Adjust door up to be level with freezer.
Aug 03, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
