Question about InFocus ScreenPlay 4805 Multimedia Projector
How do i know if it is the bulb that is the problem? can i check it in any way before purchasing a replacement?
  • 2,237 Answers
Look at the inside of the lamp. does it have bulges, black spots, fogging, or flaking? if so, replace it. if not, it may be the fan or colorwheel no spinning.
Posted on Feb 03, 2010
Quantum cxl. Why doesn't replacement lamp work?
Or it could be the incorrect bulb for the machine or if purchased from a secondary market, ie China, etc. I've purchased a replacement bulb from eBay and even though it was guaranteed to work in the machine, there is a lip on the bulb that prevents it from being inserted completely into the machine. Might be best to purchase an authentic replacement bulb from a dealer.
Feb 22, 2016 | Singer Sewing Machines
Im replacing a tail light circuit board on both rear lights, is their any special way to do this
just check accurately bulbs if you mixed it could happen like that, some cars for the brake lights use two contact bulbs some of them single contact, two contact bulbs can give two signals which one is used for brake ligths and another for taillight, so check the bulbs carefully
Apr 13, 2014 | Dodge Stratus Cars & Trucks
Makes beeping sound
Did you just recently purchase this vehicle? When you first turn the key on (don't start the engine) it does a bulb check. Look to see if the 'Air Bag' light comes on. If not, then you need to replace that bulb. It beeps to let you know the bulb isn't working.
Jan 28, 2014 | 2012 Chrysler 200 LX Sedan 2.4L 4-cyl....
Replace check engine light bulb
Take out instrument panel completely. Remove all bulbs and hold the panel up to the sun while looking at the back of it. You will see where each warning/info bulb goes.
Sep 26, 2013 | Chevrolet Aveo Cars & Trucks
Replace heater control panel bulbs
1. use old bulbs as samples by gently removing them with a soft cloth.2. Go to autopart shop or walmart,target or Canadian tire and you will find replacement bulbs. 3. Make sure you mark or place each old bulb into an envelope so you know where to put the new bulbs.
Jul 17, 2013 | Nissan Cars & Trucks
How do you know if it's the bulb that needs replaced before purchasing a new one? Please help.
If bulb is bad, the brightness to picture will be less, it will blink occasionally, wont' start within the predetermined time and so on.
Visit the site named 'Electro-help' for more details. Check this link and select the site named above. View it in 'Flip card' option, which can be selected from the drop down box menu by the [Sidebar] tag, at the left top left corner of the display window. It will make search easy. Some times, the ads attached with each posts both at the right and bottom, might help you to find the availability of spare parts. There are more than 640 posts to different brand TVs now. Will be updated daily.
Aug 19, 2012 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Bulb is dead on passenger headlight i purchased bulb but not sure how to replace
If you didnt know how to replace it, you should not have bought one. Most auto shops will not install parts not purchased from them. Its not a big deal to replace the bulb, just look at the rear of the housing and there wil be a cover and a ring or clip holding the bulb in. Be sure to NOT TOUCH the bulb with your fingers.
Dec 01, 2010 | 2006 Toyota Sienna
Hi, my sisters tail lights aren't working on her dodge durango but her stop and turn lights are fine
sonds like the blbs need replaced as there are 2 elements in the bulbs trn and brakes se the same elements but driving lights /parking lights are a seperate element
Aug 21, 2009 | 1998 Dodge Durango
No Blinkers or flashers. If you hold down the flasher button and try blinker lever, you can get each blinker to flash except driver side front. When you try driver side front, inside indicator blinks fast....
Hi with the blinker blinking fast this tells you a bulb has gone now if you check witch one is working then you will know if its the front or back that needs replacing.
When you know this go and purchase the bulb from any car spares place also the car spares place can tell you the best way to replace the bulb as this varies from model to model.
If you get stuck or need futher assistance then let me know and ill be glad to help
Aug 11, 2009 | 1997 Ford Taurus
FUSE OR LIGHT ISSUES
If you purchased your vehicle in the States, it is not equipped with Daytime Running Lamps, you will have to purchase an aftermarket module and have them installed to the parking lamp circuit in order to save the wear on your Xenon bulbs.  Only Canadian models have running lamps standard.  As far as your clock I know that the bulbs in Infiniti clocks are notorious for going bad. You can remove the clock and replace bulbs, but I would check your fuses, there is a fuse panel down in the drivers floor kick panel. I would suggest doing a google search for G35 manual and you can probably find some site that has a PDF version you can download for free.
May 09, 2009 | Infiniti G35 Cars & Trucks
InFocus ScreenPlay 4805 Multimedia Projector Logo
79 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
