Question about Black & Decker CTO650 1500 Watts Toaster Oven with Convection Cooking
Top want heat!
Want to take apart BD Toaster Oven do you have a brake down of this? Toster-Overn CTO650
You need to have where you can see break down on line, don't wait a day or so I want to go ahead and address the problem now! Thanks Jay Wes
Posted on Feb 19, 2008
Black & Decker Toaster Oven CTO650 ... Numbers around dials has worn off. Where can I get a replacement panel?
Search Results
    Black & Decker CTO650 1500 Watts Toaster Oven - Read ...
    www.epinion.com/.../Black_Decker_CTO650_Toaster_Oven.../3529132...
    Black & Decker CTO650 1500 Watts Toaster Oven No complaints Is it really ... Cons:Numbers wear off around dials after years of wiping. ... It has a see-through glass door, 30 minute timer, variable temp up to 450 degrees F and signal bell.
    Black & Decker CTO650 1500 Watts Toaster Oven No complaints i should'a bought this one Is it ... Cons: Numbers wear off around dials after years of wiping. .... It hasa 4-slice or 9 pizza capacity and touch button controls with LCD display.
Jan 28, 2016 | Toaster Ovens
How do i get parts for my toster oven model # TO1612
Amazon sells universal knobs on its site it may work
Oct 04, 2014 | Euro-Pro TO161 Toaster Oven with...
Top burner does not heat up
If the top element no longer works then you can check for a replacement. Check out the Black and Decker website for help. Then if they can't get it, try this address. It will bring up a list of places on the web that you can check at. You will probably will want to copy & paste it into the address bar.
netshoppers.com/search/index.php?phrase=oven+parts&uid=d5d00793c96dccbcaa9b5f3ca3d412cd&kuid=4c4a6ef184c15b7eeffee322a7d94921&src=7s
ToasterandConvectionOvens.com
Feb 06, 2011 | Black & Decker CTO650 1500 Watts Toaster...
Our CTO650 toaster oven dosn't toast, but the oven works fine. How do I get into it, and can this problem be fixed?
I called the 800 number on the instructions (800-231-9786),. I suffered through a confusing phone tree AND a 10 minute wait on hold. I was told that my 3 year old toaster oven is "fairly old" and that parts are no longer made for it.
Very frustrating. I expect a toaster over 1) to work and 2) to have parts available for 10 years after I purchase it. The ideas of a toaster oven as a "consumable" has terrible implications for our environment.
Feb 01, 2010 | Black & Decker CTO650 1500 Watts Toaster...
Labels on black and decker toaster oven worn off CT0650C
Top dial is Bake/Broil knob, it goes left to right. Starts with OFF @ 9 0-clock next is 100 dgre then @12 o-clock 180 Deg. is at top center next is 250 Deg. next 350 located opposite of off. Next @ 4 o-clock is 400 Deg. Next @ 5 o-clock is 450 Deg. and finally at the bottom at the 6 o-clock position is BROIL. The Center Knob is BAKE TIMER . Starts @ off position as 0, next @ 10 o-clock is 10-mins. Next @ 12 o-clock position is 20 mins. Next @ 2 o-clock pos. is 30 mins. Next @ 3 o-clock pos. is 40 mins. Next @ 5 o-clock pos. is 50 mins. Next and finial pos. is 60 mins. The Bottom knob is TOAST @ the 9 o-clock is is 0 next @ 11 o-clock pos. is Light , Next between the 12 & 1 o-clock pos. is MEDIUM and the final pos. @ 3 o-clock is DARK. TOAST.
Jun 13, 2009 | Black & Decker CTO650 1500 Watts Toaster...
Delonghi toaser oven
I need a Euro-Prox toster oven manual
M# TO160L
could you please help me.
Aug 04, 2008 | DeLonghi AR1070 Retro 1500 Watts Toaster...
Top element not heating
I found that the heating element in the top front was burned off at the end. I removed the side cover and the ceramic insulator from the broken end. I then grabbed the broken end of the spring inside the glass tube and stretched it to where I could re-attach it to the connector. It now works after getting it back together.
If you attempt this repair, UNPLUG THE OVEN FIRST!
There is also a security screw at the bottom of the side cover.
Dec 26, 2007 | Black & Decker CTO649 Toaster Oven with...
Parts for ge 168947
I have three heating elements available.
Contact me direct at:
tlowery@pobox.com
Dec 23, 2007 | GE 168947 Toaster Oven with Convection...
Black & decker toster oven
Black and Decker Toast-R-Oven Countertop Oven/Broiler Mfg Part No: CTO650
same problem here, toaster works, then when I go turn on the oven ........nothing!
Oct 29, 2007 | Black & Decker CTO649 Toaster Oven with...
Black & Decker CTO650 1500 Watts Toaster Oven with Convection Cooking Logo
294 people viewed this question
Top Black & Decker Toaster Ovens Experts
Steve
Are you a Black & Decker Toaster Oven Expert? Answer questions, earn points and help others
