I have a toshiba theatreview rear projection tv. i was wondering where to find theconvergence chips because i think they need replaced.
  • bradysrental Jan 31, 2010
    i have to run to my house and check where is the model number located?
  • 2,335 Answers
What is the model number for your Toshiba TheaterView TV?
Older TV's allow you to adjust convergence by turning a screw for a potentiometer, newer TV's do it via a service menu using the remote control. I can help with either provided I know exactly which set you have.
Posted on Jan 31, 2010
Toshiba 43hx70 Cinema projection TV-where are the IC relays?
DID you ever get this fixed I am wanting to replace mine, I paid big $$ for this tv back 6 or so years ago, the picture cinvergence isnt real bad, but I cant line u the red and blues in the menu as good as they need to be. I was also wondering If i replace the lamp if the tv would be brighter. I have most my setting turned up but...The picture is not as bright and crisp as it used to be any one have a suggestion on this also..
Jan 02, 2010 | Toshiba TN43V71 43" Rear Projection...
No sound
More than likely you need to go into your menu settings. Check to ensure that your TV speakers are enabled. The previous owners may had it hooked to theater system
Oct 20, 2009 | Toshiba TP50G60 50" Rear Projection...
Everything functions fine but the picture is very dark and beyond adjustment through normal menu options, I can move the brightness all the way and it doesnt help any, is there a backlit bulb that might be...
I think you answered your own question. You have a rear projection television. It sounds like the lamp is not functioning correctly.
All projection lamps have a recommended life measured in hours. I checked the web and this model appears to be about 3 or 4 years old. from 2005 or so.
The lamp in my Samsung is rated at 3000 to 5000 hours, I had 12,800 when the service Tech was in changing another part.
3 or 4 years running one lamp is a good run. This is why DLP has lost favor for table top sets, Most are LCD or Plasma now.
Check you TV for it's lamp model and them shop around allot. Lamps are not cheap however some suppliers offer much better pricing that others. Care should be taken to make sure you order and purchase real replacement lamp and not a clone / compatible model. Original parts should produce the picture you are expecting
Jul 08, 2009 | Toshiba 57H81 57" Rear Projection...
Projection is off and blurry
change theconvergence amplifiers STK 392-040 also check all resistors in the convergence circut if you want to test it first press MUTE 183 on the remote "DO NOT PRESS ANY ADJUSTMENTS AS YOU WLL TOTALLY SCREW UP THE PICTURE THIS IS ONLY SO YOU CAN SEE WHAT THECONVERGENCE IS LIKE"
Jun 10, 2009 | Samsung HCP4252W 42" Rear Projection...
Convergence Problem
There is a convergence board located inside the set that regulates the alignment procedure. this board is malfunctioning and there is a chip set on the board that has failed. you will need to replace this board in order to restore proper convergence functions.
May 21, 2009 | Toshiba TheaterWide 46HM94 46" Rear...
Tv shows double images
Look for the convergence menu in the manual and try to align it.
Apr 02, 2009 | Toshiba TP55H60 55" Rear Projection...
This is a problem within the convergence circuit. If you can solder you should be able to repair this yourself. Let me know if you wish to attempt the repair and I'll provide additional details and instructions.
Dan
Jan 27, 2009 | Toshiba 55H70 55" Rear Projection...
Just wondering when to replace the blulbs on my Toshiba 57H81 CRT
Hello, Im Ismail A, and I would love to help you with your problem. Ok, well you should change your bulb every 2 years.
Jan 12, 2009 | Toshiba 57H81 57" Rear Projection...
Theatre View Toshiba Rear Projection TV 50 Inch with no sound or picture and a red light keeps blinking
I have the sames t.v you have to go in the back flip the power cord switch...then reboot the t.v.
Jun 27, 2008 | Televison & Video
Televison & Video Logo
47 people viewed this question
Top Televison & Video Experts
