I have re started my computer, I am using the installation disk, when I plug in the usb cable it stalls at 7/8 done. I have a new, as of January 2008 and , office jet and all in one 5610 and HP pxvillion.
  • 97 Answers
Disable the firewall and antivirus software
Posted on Feb 19, 2008
Set-up won't recognize that the USB cable is connected to both printer and computer and therefore printer won't work. What's up with that??
1. Confirm the USB port on the computer you are connecting your printer to is being recognized by your computer. The easiest way to do this would be to plug a known good USB Memory stick into the USB port you want to use. If you can read the contents of the USB Memory stick then the port should work. Remove the Memory stick, start the printer installation program (Make sure you don't the printer connected), want until the setup program tells you to connect the printer before you attach the Printer's USB cable.
If the printer isn't recognized try a different USB port, when picking a new USB port to try select a higher priority port, for example in increasing priority from, an external USB hub, a powered external hub, a monitor based hub, USB ports on the front of the computer, up to the USB ports at the computer rear. For USB ports on the same circuit select an USB 2.0 before an USB 3.0 port
Aug 04, 2015 | HP OFFICEJET PRO 6830 E-ALL-IN-ONE PRINTER
Tip
Steps to create a bootable Vista or Windows 7 USB flash drive for the purpose of...
<b>Steps to create a bootable USB flash drive for the purpose of installing a Vista or Windows 7 OS<br /> <br /> <br /> Microsoft Provides a tool to do this for you - Windows 7 USB/DVD Download Tool which is available for <a href="http://images2.store.microsoft.com/prod/clustera/framework/w7udt/1.0/en-us/Windows7-USB-DVD-tool.exe">download here</a>. If you need instructions on how to use the tool, see the Microsoft Store Help on the ISO-Tool (<a href="http://store.microsoft.com/Help/ISO-Tool">http://store.microsoft.com/Help/ISO-Tool</a>).<br /> <br /> or <br /> <br /> <br /> <span style="text-decoration: underline;">Please follow the steps below</span><br /> <br /> </b> <b>Required:</b><br /> <ul> <li>USB Flash Drive (4GB+)</li> <li>Microsoft OS Disk (Vista / Windows 7)</li> <li>A computer running Vista / Windows 7</li></ul> <b>Step 1: Format the Drive<br /> </b>The steps here are to use the command line to format the disk properly using the <i>diskpart</i> utility. [Be warned: this will erase everything on your drive. Be careful.]<br /> <ol> <li>Plug in your USB Flash Drive</li> <li>Open a command prompt as administrator (Right click on Start &gt; All Programs &gt; Accessories &gt; Command Prompt and select "Run as administrator"</li> <li>Find the drive number of your USB Drive by typing the following into the Command Prompt window:<br /> <span>diskpart<br /> list disk</span><br /> The number of your USB drive will listed. You'll need this for the next step. I'll assume that the USB flash drive is disk 1.</li> <li>Format the drive by typing the next instructions into the same window. Replace the number "1" with the number of your disk below.<br /> <span>select disk 1<br /> clean<br /> create partition primary<br /> select partition 1<br /> active<br /> format fs=NTFS<br /> assign<br /> exit<br /> </span><span>When that is done you'll have a formatted USB flash drive ready to be made bootable.</span></li></ol> <b>Step 2: Make the Drive Bootable <br /> </b>Next we'll use the <i>bootsect</i> utility that comes on the Vista or Windows 7 disk to make the flash drive bootable. In the same command window that you were using in Step 1:<br /> <ol> <li>Insert your Windows Vista / 7 DVD into your drive.</li> <li>Change directory to the DVD's boot directory where <i>bootsect</i> lives:<br /> <span>d:<br /> cd d:\boot</span></li> <li>Use <i>bootsect</i> to set the USB as a bootable NTFS drive prepared for a Vista/7 image. I'm assuming that your USB flash drive has been labeled disk G:\ by the computer:<br /> <span>bootsect /nt60 g:</span></li> <li>You can now close the command prompt window, we're done here.</li></ol> <b>Step 3: Copy the installation DVD to the USB drive<br /> </b>The easiest way is to use Windows explorer to copy all of the files on your DVD on to the formatted flash drive. After you've copied all of the files the disk you are ready to go.<br /> <b>Step 4: Set your BIOS to boot from USB<br /> </b>This is where you're on your own since every computer is different. Most BIOS's allow you to hit a key at boot and select a boot option.<br /> <br />
on May 19, 2011 | Computers & Internet
How do I download songs on my eclipse mp3 player
Things You'll Need
Microsoft Windows 7 computer with an open USB port and iMesh installed
USB cable compatible with Eclipse MP3 players
Instructions
  • 1 Plug a USB cable into the Eclipse MP3 player. Plug the other end of the USB cable into an open port on the Windows 7 computericon1.png.
  • 2 Click the "Start" button on the Windows 7 desktop taskbar and click "Computer" in the menu that appears. Click the "Music" item located in the left pane of the "Computer" window that appears. Double-click on the "iMesh" folder. For Windows 7, XP and Vista. Recommended. Download Now.
  • 3 Click the "Start" button on the Windows 7 taskbar and click "Computer" and then double-click on the "Removable disk" icon that represents the Eclipse MP3 player device. A window will appear displaying the contents of the Eclipse MP3 player storageicon1.png area.
  • 4 Right-click on a music file in the "iMesh" directory that has the "mp3" suffix, and click "Copy" in the menu that appears.
  • 5 Right-click on empty space in the "Removable disk" window and click "Paste" to copy the music file to the Eclipse MP3 player device. Repeat for each file you wish to download to the Eclipse MP3 player.
    To copy multiple music files at one time to the Eclipse MP3 player, press and hold the "Shift" key on the keyboard. Click once on each file you wish to copy. Right-click on one of the highlighted MP3 music files and click "Copy" in the menu that appears. Right-click on empty space in the Eclipse "Removable disk" window and click "Paste."
Oct 21, 2014 | Audio Players & Recorders
I dont have installer driver hp 695c
You can download a driver from the manufacturers website which is located at www.hp.com. Click on support and then download drivers/software. Enter the model number of your printer and follow the prompts to download and install the drivers. Do not connect your printer to your pc until the drivers and/or software is installed.
Jul 06, 2011 | HP DeskJet 695c InkJet Printer
My cd/dvd drive G:\ (hl dt st rw dvd gcc h21n version.1.00) does not reads windows 7 dvd .. and it only reads cd-r/cd-rw.... plzzz help i want to install windows 7... plzz help...
It sounds like your drive is having issues, you can always install windows 7 from a flash drive (so long as your computer supports booting to one). Instructions on setting this up are here: http://www.intowindows.com/how-to-install-windows-7vista-from-usb-drive-detailed-100-working-guide/ You will need to do this from a computer with a working DVD drive to transfer the info to a flash drive.
Jun 28, 2011 | Computers & Internet
My Hp SimpleSave 1TB just quit working on windows 7. When I plug it in my computer realizes I have a drive in the usb but it doesnt open or anything.
The external storage device has several major components:
* USB cable
* external power-supply
* disk-drive inside the enclosure
* USB-to-disk-drive adapter inside the enclosure.
Try a different USB cable.
Try a different USB port on your computer.
Try a USB port on a different computer.
Take a multi-meter, and measure the output voltage/amperage of the power-supply,
and compare with the specifications on the label of the power-supply.
Open the enclosure, and remove the disk-drive, and attach it as a "slave" drive in a desktop computer, to see if bypassing the USB-to-disk-drive adapter bypasses the problem.
Look at the label on the disk-drive, for manufacturer, product-number, serial-number, and manufacture date. Access the manufacturer's web-site, and use "check warranty status" to see if the warranty still is valid. If so, the drive can be replaced, at minimal cost to you.
Buy a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Search online for a professional "data recovery service". For a significant fee, they can repair your disk-drive, just long-enough to copy your files to a new disk-drive.
Nov 04, 2010 | HP SimpleSave 1 TB USB 20 Hard Drive
My desktop computer is done and I need to get the information from the hard drive. It is a Samsung Spin point Sv0813h/TGM. I bought the IDE to USB kit. How do I make it all work?
It is really easy. If your using Windows 7, plug the IDE to USB connector to your Samsung Hard drive. Then using the provided USB cable, plug in the USB cable to the Hard drive. Then plug it into an available USB port on your other PC. Window will automatically install the needed drivers for you. Then navigate to Start/Computer/Local Disk E. Assuming there is no 2nd hard drive or partitions installed. And there will lye your Samsung Drive.
Aug 30, 2010 | Samsung SpinPoint V60 SV0813H 80 GB...
Massstorage
This will walk through the steps to create a bootable USB flash drive for the purpose of installing a Vista or Windows 7 OS. These instructions assume that you have a computer with Windows Vista installed on it.
Required:
· USB Flash Drive (4GB+)
· Microsoft OS Disk (Vista / Windows 7)
· A computer running Vista / Windows 7
The steps here are to use the command line to format the disk properly using the diskpart utility. [Be warned: this will erase everything on your drive. Be careful.]
Open a command prompt as administrator (Right click on Start > All Programs > Accessories > Command Prompt and select “Run as administrator”
diskpart
list disk
The number of your USB drive will listed. You’ll need this for the next step. I’ll assume that the USB flash drive is disk 1.
Format the drive by typing the next instructions into the same window. Replace the number “1” with the number of your disk below.
select disk 1
clean
select partition 1
active
format fs=NTFS
assign
exit
When that is done you’ll have a formatted USB flash drive ready to be made bootable.
Next we’ll use the bootsect utility that comes on the Vista or Windows 7 disk to make the flash drive bootable. In the same command window that you were using in Step 1:
Change directory to the DVD’s boot directory where bootsect lives:
d:
cd d:\boot
Use bootsect to set the USB as a bootable NTFS drive prepared for a Vista/7 image. I’m assuming that your USB flash drive has been labeled disk G:\ by the computer:
bootsect /nt60 g:
You can now close the command prompt window, we’re done here.
The easiest way is to use Windows explorer to copy all of the files on your DVD on to the formatted flash drive. After you’ve copied all of the files the disk you are ready to go.
This is where you’re on your own since every computer is different. Most BIOS’s allow you to hit a key at boot and select a boot option.
I used these instructions to get my new Dell Mini 9 laptop loaded with Windows 7 (the PDC bits). HTH.
Jan 23, 2009 | Computers & Internet
New computer does not recognize pentax 33l
Optio 33L and Vista
Plug camera into USB port using the cable supplied, and switch the camera on. Computer will display the "found new hardware" sign, and ask you to insert the disk that came with the 33L into the disk drive. That done, the drivers will be installed in the usual manner. AT LEAST, THAT'S HOW I DID IT - AND IT WORKS!
de VK5QV
Feb 18, 2008 | Pentax Optio 33L Digital Camera
Installation
Hi, If you are running WIndows 98 you will need the driver downloaded and installed. Here is the link: http://www.vivitar.com/support.asp?model_id=16&modelname=ViviCam3815 Otherwise, you just need to plug camera into the laptop with the USB cable, turn it on, and the laptop should detect it. Folllow the instructions below: 1. Connect one end of the USB cable to an available USB port on your computer. 2. Connect the other end of the USB cable to the USB connector on the camera. 3. Turn the camera on. Your computers operating system will recognize the camera. 4. From the Windows desktop double click on ?My Computer? 5. Look for a new ?removable disk? icon. This ?removable disk? is actually the memory (or memory card) in your camera. Typically, the camera will be assigned drive letter ?e? or higher. 6. Double click on the removable disk and locate the DCIM folder. 7. Double click on the DCIM folder to open it to find more folders such as ?100CAMEA? 8. Your recorded images and video clips will be inside these folders 9. Copy & Paste or Drag-N-Drop image and video files to a folder on your computer When the camera is turned on and connected to your computer, it is considered to be a disk drive, just like a floppy disk or CD. You can download (transfer) images by copying them from the ?removable disk? (?untitled? disk on a Macintosh) to your computer hard driver as described in the prior section. Tip of the Day: Delete the images from the memory card using the menu system in the camera. Don't delete them using your computer. Hope this helps. Let me know if it works. NewMediaMan
Jul 05, 2007 | Vivitar ViviCam 3815 Digital Camera
Computers & Internet Logo
48 people viewed this question
Alun Cox
David Payne
David Payne
